Make EM6590 smoke alarm beep?
arjanvdwiel
Domoticz version: V2.2284
Post by arjanvdwiel »
I have a few Eminent EM6590 smoke detectors, which i can detect in domoticz.
When i press the (test) button on the smoke alarm, the domoticz-status is changed to 'on'.
But is there any way to trigger the alarms from domoticz? This way i can sync them so they all go off simultaneously? :roll:
RPi - RFXtrx433E - Mi Light - ICY Thermostat - Rubicson TX95 - HomeEasy EU - SelectPlus Chime - Elro AB400 - PT2262 Door sensors
D'rMorris
Re: Make EM6590 smoke alarm beep?
Post by D'rMorris »
Yes, there is :). For example, if you have a PIR and you want the smoke detector to go off on motion you use:
if (devicechanged['PIR'] == 'On')
then
print('Motion detected')
commandArray['SendNotification']='Motion detected#Motion detected somewhere!#2'
commandArray['SMOKEDETECTOR']='On'
Derik
Post by Derik »
D'rMorris wrote:Yes, there is :). For example, if you have a PIR and you want the smoke detector to go off on motion you use:
then
And where do i have to place this?
D'rMorris
Post by D'rMorris »
Start by reading how to use LUA in the wiki: http://domoticz.com/wiki/Main_Page
arjanvdwiel
The smoke detector is shown as a switch. When i switch it 'on' in domoticz, it doesnt start beeping..
So i guess a lua script wont work..
Egregius
Domoticz version: v2024.7
Post by Egregius »
I guess something else is wrong then.
I can test my smoke detectors by clicking the icon and let them beep with blocky. Should be possible in LUA also then.
D'rMorris
Post by D'rMorris »
arjanvdwiel wrote:The smoke detector is shown as a switch. When i switch it 'on' in domoticz, it doesnt start beeping..
It should be shown as a KD-101 and a fire icon, not a switch. Perhaps you can post a screenshot of the culprit?
arjanvdwiel
This is how i see them in domoticz
Egregius
Post by Egregius »
Clicking on the round icon with flames does nothing?
Nevermind the KD-101 type, that's 433Mhz version (like mine and D'rMorris).
arjanvdwiel
Clicking on the flames turns them on, and reset turns them off.
But no sound..
rik82
Post by rik82 »
I have the same problem. Can't send on signal to pt2262 smoke detector...
proohu01
Post by proohu01 »
arjanvdwiel wrote:Image
Hi arjanvdwiel,
Would you mind sharing you smoke detector icon on the forum? (or PM) I like it and there is nothing in Domoticz like that by default.
Also, how did you get a reset button and how do you send this command to the smoke detector?
Pi 2 B | Pi Camera | PiFace 2 | RFXtrx433E (KaKu + Oregon Scientific) | Plugwise (9 Circles) | Aeon Z-Wave stick (Fibaro - dimmers, sockets, RGB, screens/blinds) | RFXMeter (Kwh/water/gaz) | WOL | Onkyo Receiver | RTC | Hikvision | Netatmo | Satel Integra
jvdz
Domoticz version: 4.107
Post by jvdz »
The shown Icon and reset button are there with a standard installation for me (Everspring SF812 Smoke Alarms)
Jos
proohu01
Post by proohu01 »
My bad! Looking in the wrong place. Found it. Sorry for hijacking this post.
adsernl
Post by adsernl »
All,
i got the same problem with my pt2262 smoke detector. How can i make it beep?
thanks already
