RFID Reader to stop a PIR sensor from signals
Ritmeester
Post by Ritmeester »
I want to buy a RFID reader for my work garage.
Situation:
In my garage I have a PIR sensor. I walk there all the day, so the log file of this PIR sensor goes very fast to >5000 entries.
My idea is to buy a RFID card reader (key fob or numeric) to close the data line from this PIR sensor while I been in my garage. On the RFID reader must be a green (open) or a red (close) LED installed. My idea is t have the RFID reader outside and the electronics inside the garage.
I did a search on eBay and there is lot to buy. But what do I need and is safe to use? Does anyone else have this RFID readers and can help me to the right direction?
(iets met bomen en bos) :-)
ThinkPad
Re: RFID Reader to stop a PIR sensor from signals
Post by ThinkPad »
You could also change the log to keep track of fewer entries :) I have set it to 7 days. I am not interested if a device was turned on/off three weeks ago or so...
Setup > Log history
Your idea sounds like a dirty workaround for a problem that is not really critical to be honest :P
Ritmeester
Thanks. Maybe this is a better idea.
If I change the log setting for “Light/Switches” to, for example 2 days, than this setting works for ALL Switches.
It would be nice to implement a feature that you can set per Switch (in this case a PIR sensor) a separate LOG time to overrule the standard setting in the Log History for this particular Switch.
Edgar
Post by Edgar »
Does this pir sensor have a way to set the re-arm time out? Then it would only reset and trigger again xx seconds after last detection. My zwave motion detectors work that way. During the day I see only a few events; the time someone is in the room and moving is one event so to say.
Only Robinson Crusoe had everything done by Friday
jenbaker
Post by jenbaker »
hi
for the RFID reader outside and the electronics inside the garage,
i think this UHF RFID Integrated Reader http://syncotek.com/product/sr_ru_101r_ ... range.html matches your need.
a high performance UHF long rang rfid reader for parking application with effect distance up to14m (adjustable).It supports RS232, RS485, RJ45, Wiegand interface and supports ISO18000-6C (EPC C1G2) protocol tag.
*Self-intellectual property
*Support ISO 18000-6C (EPC C1G2) protocol tag
*840~868MHz/902~928MHz frequency band (frequency customization optional)
*FHSS or Fix Frequency transmission
*RF output power up to 30dbm (adjustable)
*10dbi antenna optional with effect distance up to 14m (adjustable)
*Support command, polling and trigger mode
*Low power dissipation with single +12 DC power supply
*Support RS232, RS485, RJ45, Wiegand interface
*Support EPC, TID and USER inventory
DonCroogerz
Post by DonCroogerz »
Ritmeester wrote: Friday 01 May 2015 18:41 I want to buy a RFID reader for my work garage.
Situation:
There are a lot of substitute for your sensor how about magnetic card reader where you can just scan it then doors or any compartment will be open?
It's so much cooler than a sensor because most of the time sensor fails. https://www.lintechtt.com/. Try this you might find something here that might help you.
