Page 1 of 2
Cheap 433Mhz single channel LED strip controller from eBay?
Posted: Monday 27 April 2015 19:40
by ThinkPad
I am looking for a cheap 433Mhz dimmer for my LED-strip (single color, warmwhite).
Basically the ACM-LV24 from KaKu does what i want.
However, i am a big fan of shopping in China, and found this: http://www.ebay.com/itm/12V-RF-Wireless ... 1316838983 a LOT cheaper :lol:
Does anyone have experience with a dimmer like that, in combination with RFXCOM and Domoticz?
According to the specs it is 433.92Mhz. It also has 10 dimming levels (apart from the 100%, 50%, 25% buttons), which is sufficient for me.
Re: Cheap 433Mhz single channel LED strip controller from eB
Posted: Monday 27 April 2015 20:42
by Mooseknuckle
I just ordered the one from ebay. I don't know if it is going to work but it's too cheap to not give it a try :D . And so the waiting starts...........
Posted: Monday 27 April 2015 20:50
by ThinkPad
That was also my idea if i wouldn't get any response to this topic. But maybe someone had already ordered it and knew it would work, or not...
Posted: Tuesday 28 April 2015 11:02
by ThinkPad
I posted this question also on domoticaforum.eu and got a PM from 'b_weijenberg' (guy behind RFXCOM i thought):
It looks a lot similar to this one i tested:
http://www.ultraleds.co.uk/mini-dimmer- ... ximum.html
But i have often seen that our Chinese friends change the protocol every now and then, so it is not sure if yours is gonna work.
Downside is also that the dimmer has no on/off, but uses a toggle.
And as far as i know it is not yet implemented in Domoticz.
I think i'll wait until Mooseknuckle receives his, and can give us any more information. It's not that i don't want to try for myself, but i already have a lot of stuff lying around here :lol:
Let's see what Mooseknuckle kan pick up with RFXCOM connected to Windows PC and then run RFXmngr and pressing some buttons on the remote.... Maybe we can send that information back to 'b_weijenberg'.
I also asked b_weijenberg if it isn't already supported by the RFXCOM (Lighting4 or something?) and he said:
It is Lighting5 - MDREMOTE and i don't think you can use that already in Domoticz.
Besides that you also need a whole range of buttons with that device then. Have look in RFXmngr when you choose MDREMOTE, you will see which commands you can use.
I now also see there already is a topic about this, where b_weijenberg has also posted: http://www.domoticz.com/forum/viewtopic ... =682#p3481
Posted: Sunday 03 May 2015 15:46
by Mooseknuckle
Well I received the controller already and it works with the remote. Unfortunately it doesn't give any info in rfxmgr. I followed the manual from rfx.com: enable x10, undec on and push some buttons, but no code appears in rfxmgr. Even after flashing to ext_241 firmware I received nothing. So it looks like a dead end with this controller. Anything else I could try?
Greetings,
Posted: Friday 08 May 2015 21:20
by dijkdj
Same here, just a remote controllable led strip :)
Posted: Friday 08 May 2015 23:30
by Raspberry Piet
Mooseknuckle wrote:Hi,
Greetings,
Mentioned in the RFXtrx_User_Guide: MDremote signal from the remote is not received but you can use your RFXtrx to send the MDremote signals.
I think it never will be supported by Domoticz.
Posted: Friday 08 May 2015 23:36
by RayAmsterdam
Those controllers are very poor quality. I already fried a couple of them.
Posted: Saturday 09 May 2015 0:39
by dijkdj
Ok, any idea how to know what signal to send ? :)
Posted: Saturday 09 May 2015 8:41
by Raspberry Piet
Just checked.
In RFXMNGR set undec on
Push a button on your MDREMOTE.
It returns:
Packettype        = UNDECODED RF Message
UNDECODED NEC:20348401B3
20348401B3
My MDREMOTE ID is 34 84
Send signals via RFXMNGR:
Posted: Sunday 10 May 2015 22:06
by dijkdj
UNDECODED ARC:2D010000009040
But ID: 0100 did not work
Posted: Tuesday 12 May 2015 9:50
by dijkdj
Anyone got an idea?
Posted: Tuesday 12 May 2015 11:43
by chimit
I got one in as well. Following this thread.
Posted: Tuesday 09 June 2015 10:33
by dijkdj
Raspberry Piet?
Posted: Tuesday 09 June 2015 18:12
by Raspberry Piet
It is useless for Domoticz. It is not and i'm reasonable sure it never will be implemented in Domoticz.
(better not ask for support in Domoticz as it will really upset gizmocuz :lol: )
http://www.domoticz.com/forum/viewtopic.php?f=31&t=682
http://www.domoticz.com/forum/tracker.php?p=2&t=104
http://www.domoticz.com/forum/tracker.php?p=2&t=108
Posted: Sunday 03 January 2016 23:03
by pepeEL
Re: Cheap 433Mhz single channel LED strip controller from eBay?
Posted: Wednesday 30 March 2016 21:36
by Teknor
This works with Domoticz using RFXTRX433e with firm ware version 251.
Posted: Thursday 31 March 2016 18:01
by deennoo
Works great on RFLink, each remote switch is reconize as a push on button.
Posted: Saturday 09 April 2016 15:11
by Treve
I just bought this controller by AliX And it works great under Domoticz when you learn each remote button as a on/off switch.
http://nl.aliexpress.com/item/DC12V-24V ... 57510.html
But i like it to use as a dimmer with a slider so i can make a blockly to set the brightnes, is this possibele?
led single color dimmer inside.jpg (62.06 KiB) Viewed 7668 times
Posted: Saturday 27 August 2016 1:24
by madrian
I am using a LED controller, which is in the first post. It works pretty well, unless that there is no dedicated on/off button on the remote.
Is there any way to setup a switch to use the dimmer function with Domoticz? A slider, or a 3 state button (100%, 50%, 25%) or a + - button.
On the remote I have 3 dedicated buttons for 100%, 50%, 25%.
100%
sudo ./codesend 16776967
50%
sudo ./codesend 16776968
25%
sudo ./codesend 16776969
...and a + - button.
I am also planning to buy this controller, where is a dedicated on/off button:
http://www.aliexpress.com/item/Foxanon- ... 62006.html
