Rasperry Pi 2 + Razberry + OpenZWave not working
Posted: Tuesday 24 March 2015 10:13
I have RPI2 and a Razberry Pi board, previously I´ve used the HTTP hardware plugin to communicate to their software.
This however din´t always work as I wanted so I started working on using OpenZWave instead.
However, I can´t manage to get it to work.
I´ve followed the guide on vesternet: http://www.vesternet.com/resources/appl ... REnvHrF-ur
If I go to the OpenZWave-controller, I get the following error:
Any ideas on how to proceed?
2015-03-24 10:06:31.777 Error, mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
pi@razberry /opt/domoticz/Config $ sudo cat OZW_Log.txt
2015-03-24 09:59:48.795 Always, OpenZwave Version 1.3.1021 Starting Up
2015-03-24 09:59:51.798 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 09:59:55.794 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 09:59:58.795 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 10:00:01.797 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 10:00:04.799 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 10:03:09.415 Error, mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
2015-03-24 10:03:29.349 Error, mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
2015-03-24 10:03:30.560 Error, mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
2015-03-24 10:03:50.355 Error, mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
2015-03-24 10:06:51.405 Error, mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
