Rasperry Pi 2 + Razberry + OpenZWave not working
dhanjel
Domoticz version: 3.5146
Post by dhanjel »
I have RPI2 and a Razberry Pi board, previously I´ve used the HTTP hardware plugin to communicate to their software.
This however din´t always work as I wanted so I started working on using OpenZWave instead.
However, I can´t manage to get it to work.
I´ve followed the guide on vesternet: http://www.vesternet.com/resources/appl ... REnvHrF-ur
If I go to the OpenZWave-controller, I get the following error:
2015-03-24 10:06:31.777 Error, mgr, Manager::GetDriver failed - Home ID 0x00000000 is unknown
pi@razberry /opt/domoticz/Config $ sudo cat OZW_Log.txt
2015-03-24 09:59:48.795 Always, OpenZwave Version 1.3.1021 Starting Up
2015-03-24 09:59:51.798 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 09:59:55.794 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 09:59:58.795 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 10:00:01.797 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 10:00:04.799 Error, contrlr, ERROR: Dropping command, expected response not received after 3 attempt(s)
2015-03-24 10:03:09.415 Error, mgr,     Manager::GetDriver failed - Home ID 0x00000000 is unknown
2015-03-24 10:03:29.349 Error, mgr,     Manager::GetDriver failed - Home ID 0x00000000 is unknown
2015-03-24 10:03:30.560 Error, mgr,     Manager::GetDriver failed - Home ID 0x00000000 is unknown
2015-03-24 10:03:50.355 Error, mgr,     Manager::GetDriver failed - Home ID 0x00000000 is unknown
2015-03-24 10:06:51.405 Error, mgr,     Manager::GetDriver failed - Home ID 0x00000000 is unknown
Any ideas on how to proceed?
dhanjel
Re: Rasperry Pi 2 + Razberry + OpenZWave not working
Post by dhanjel »
Actually, the tweaking-part of http://www.domoticz.com/wiki/Preparing_ ... r_Domoticz seems to be the magic that makes it work
gizmocuz
Post by gizmocuz »
So its working now?
You last link to the wiki was not correct
Immo
Post by Immo »
my razberry is recognised as TTYAMA0 with one of the recent updates of domoticz.
No need to do the trick anymore
dhanjel
Post by dhanjel »
Yes, now it works perfectly fine.
Just need to buy some new batteries for my fibaro motion sensors :)
Add a ) to the end of the url, the forum didn´t include it in the link for some reason.
Egregius
Domoticz version: v2024.7
Post by Egregius »
I guess http://www.domoticz.com/wiki/Preparing_ ... r_Domoticz is the correct link to the wiki?
qrn77
Post by qrn77 »
The tweak for the 8.0 debian version, for removing the tty like in former inittab is :
edit the
/boot/cmdline.txt
look for console=ttyA<something>
you should have something like
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 <....>
Hope it helps
