Which wireless system? RFXCOM? Z-Wave? Or other?
Posted: Friday 06 March 2015 11:40
by pascalspits
Which wireless system should I use for controlling switches, dimmers, sensors, ...
Z-wave ?
RFXCOM ?
which one is better / cheaper / relyable / easier / ... ?
I'll be running Domoticz on my Synology DS414 NAS ...
so which USB-stick should I get to set up the wireless stuff ?
please advise which is the "best" way to go and why ...
Pascal
Re: which wireless stick should I use ?
Posted: Friday 06 March 2015 23:43
by Banjer
The best way to go is to start by thinking about what you want to controll, and then see what can be used to controll those..
Posted: Saturday 07 March 2015 9:03
by pascalspits
normal stuff, like garage door, dimmers, wall switches, temp sensors, doorlocks ...
but I haven't bought any of this stuff yet, so I'm wondering which is the best way to go ?
I'm starting from scratch, so ...
Posted: Saturday 07 March 2015 10:07
by pvm
Cheap via kaku or similar. More control using zwave
Posted: Saturday 07 March 2015 10:31
by pwhooftman
The main advantages of Zwave are a) active state feedback to the controller (especially important for garage doors etc, with kaku you only know you have sent a command, not if it is executed ) and b) great reange because the zwave nodes communicate with eachother, passing through commands. Disadvantage is the higher price.
Good read in dutch: http://www.wirelesswonen.nl/zwave
Posted: Saturday 07 March 2015 11:09
by ThinkPad
Also, you aren't limited to just one system. You can use a RFXCOM for devices that are not 'mission critical'. And combine it with a Z-Wave stick for devices where you need more reliability (like the garage door that 'pwhooftman' mentioned).
No problem in Domoticz :)
Re: Which wireless system? RFXCOM? Z-Wave? Or other?
Posted: Monday 09 March 2015 23:01
by Ron
Both!
RFXCom for temperature sensors and Kaku and Zwave for more critical stuff.
Posted: Thursday 12 March 2015 10:21
by pascalspits
temperature sensors ...
isn't this a better solution ?
http://pl1047889931.trustpass.alibaba.c ... _WAVE.html
all sensors in 1 small Z-wave device
and I put one of these in each room ...
or is that a stupid (too expensive) idea ?
any thoughts ?
Posted: Thursday 12 March 2015 11:11
by bbqkees
I use both the RFXCom and ZWave.
For sensors (X10 motion, temp, etc) I use the RFXCom and for dimming and switching ZWave stuff.
I tested the KaKu/CoCo dimmers but the ZWave dimmers are far superior in features and quality.
And they also provide status feedback for Domoticz.
And it doesn't stop there, you can also connect Hue lamps etc. So in the end it will always be a combination of protocols.
Posted: Friday 01 May 2015 13:38
by thaui
Can I use two transceiver modules in one raspberry system? I am already running Razberry and want to extend with an enocean usb module. Anybody who can help?
Posted: Saturday 27 February 2016 6:58
by amymcpherson
Garage doors are wireless?
