Which wireless system? RFXCOM? Z-Wave? Or other?
pascalspits
Post by pascalspits »
Which wireless system should I use for controlling switches, dimmers, sensors, ...
Z-wave ?
RFXCOM ?
which one is better / cheaper / relyable / easier / ... ?
I'll be running Domoticz on my Synology DS414 NAS ...
so which USB-stick should I get to set up the wireless stuff ?
please advise which is the "best" way to go and why ...
Pascal
Reason: Made title more clear
RasPi2 - Aeotec Z-Stick S2 - Fibaro multisensors - Fibaro RGBW dimmers - ETH08 relais boards
Banjer
Re: which wireless stick should I use ?
Post by Banjer »
The best way to go is to start by thinking about what you want to controll, and then see what can be used to controll those..
pascalspits
normal stuff, like garage door, dimmers, wall switches, temp sensors, doorlocks ...
but I haven't bought any of this stuff yet, so I'm wondering which is the best way to go ?
I'm starting from scratch, so ...
pvm
Domoticz version: 4.10538
Post by pvm »
Cheap via kaku or similar. More control using zwave
pwhooftman
Post by pwhooftman »
The main advantages of Zwave are a) active state feedback to the controller (especially important for garage doors etc, with kaku you only know you have sent a command, not if it is executed ) and b) great reange because the zwave nodes communicate with eachother, passing through commands. Disadvantage is the higher price.
Good read in dutch: http://www.wirelesswonen.nl/zwave
Domoticz v 1.16xx
1X RFXtrx433 USB 433.92MHz Transceiver Firmware version: 71
1X Synology Nas DS918+ DSM 7 (12Gb RAM mod)
ThinkPad
Post by ThinkPad »
Also, you aren't limited to just one system. You can use a RFXCOM for devices that are not 'mission critical'. And combine it with a Z-Wave stick for devices where you need more reliability (like the garage door that 'pwhooftman' mentioned).
No problem in Domoticz :)
Ron
Domoticz version: 2.2284
Re: Which wireless system? RFXCOM? Z-Wave? Or other?
Post by Ron »
Both!
RFXCom for temperature sensors and Kaku and Zwave for more critical stuff.
pascalspits
temperature sensors ...
isn't this a better solution ?
http://pl1047889931.trustpass.alibaba.c ... _WAVE.html
all sensors in 1 small Z-wave device
and I put one of these in each room ...
or is that a stupid (too expensive) idea ?
any thoughts ?
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
I use both the RFXCom and ZWave.
For sensors (X10 motion, temp, etc) I use the RFXCom and for dimming and switching ZWave stuff.
I tested the KaKu/CoCo dimmers but the ZWave dimmers are far superior in features and quality.
And they also provide status feedback for Domoticz.
And it doesn't stop there, you can also connect Hue lamps etc. So in the end it will always be a combination of protocols.
thaui
Domoticz version: 2023.2
Post by thaui »
Can I use two transceiver modules in one raspberry system? I am already running Razberry and want to extend with an enocean usb module. Anybody who can help?
amymcpherson
Post by amymcpherson »
Garage doors are wireless?
