[Bash/Lua] Presence Detection via MAC Address
dadogiobbe
Post by dadogiobbe »
i wrote a script to detect presence of 1 or multiple devices in the home using MAC address of devices...
i obtain it using arp-scan
you have to create:
a virtual switch for every device to poll;
a variable (PRESENCE_LIST) in this format: MAC_Address1;IDX1|MAC2;IDX2 ....
if you have only 1 device it's like 11:22:33:44:55:66;100
i have a time script that launch a bash script to poll the device and send json command to domoticz to switch on or off the assigned virtual switch.
it's perfect and very quick (~2 seconds in my lan with 15 devices connected) and it's IP independent...
this is the script_time_Presence.lua
function splitString(str, delim, maxNb)
    -- Eliminate bad cases...
    if string.find(str, delim) == nil then
        return { str }
    if maxNb == nil or maxNb < 1 then
        maxNb = 0    -- No limit
    local result = {}
    local pat = "(.-)" .. delim .. "()"
    local nb = 0
    local lastPos
    for part, pos in string.gmatch(str, pat) do
        nb = nb + 1
        result[nb] = part
        lastPos = pos
        if nb == maxNb then break end
    -- Handle the last field
    if nb ~= maxNb then
        result[nb + 1] = string.sub(str, lastPos)
    return result
maclist= uservariables['PRESENCE_LIST']
Lines=splitString(maclist,"|")
for i,line in pairs(Lines) do
	--print (i.." "..line)
	macs=splitString(line,";")
	print ("MAC Address to Poll: "..macs[1].." On IDX:"..macs[2])
        execcommand="sudo /home/pi/domoticz/scripts/bash/Check_MAC.sh "..macs[1].." "..macs[2].." &"
 	os.execute(execcommand)
and this the Check_MAC.sh bash script
#!/bin/bash
MAC=$1
IDX=$2
sudo arp-scan --localnet | grep -e $MAC
if [ $? -eq 1 ]
then
echo "Device $MAC Not in LOCAL LAN"
curl "http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=$IDX&switchcmd=Off"
echo "Device $MAC in LOCAL LAN"
curl "http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=$IDX&switchcmd=On"
fi
jannl
Domoticz version: 2022.2
Re: [Bash/Lua] Presence Detection via MAC Address
Post by jannl »
I think this depends on how many switches you have in your network......
And this also depends on wifi being on.
dadogiobbe
i have 4 switches and 2 access points...
10 devices are on cable lan and 5 in wireless...
if you want you could filter hosts to check with arp-scan filters...like ip range, hostnames,....
in this way it's faster...
rijo78
Domoticz version: V4.10717
Post by rijo78 »
Hi, I love this idea, but I don't seem to get this working.
Maybe I have the mac-dress in the wrong place?
I have placed this script in domoticz/scripts/lua folder. The bash script is placed in the bash folder.
Could you help me out?
return { str }
local result = {}
local nb = 0
local lastPos
nb = nb + 1
result[nb] = part
lastPos = pos
if nb ~= maxNb then
return result
maclist= uservariables '44:xx:eb:xx:xx:xx;77|xx:6c:xx:xx:94:xx;78'
execcommand="sudo /home/pi/domoticz/scripts/bash/Check_MAC.sh "..macs[1].." "..macs[2]..$
Immo
Post by Immo »
Useless for iphones or any other phone that switches off the wifi in standby.
it will keep telling you you're home and left every other minute or so..
rijo78
Post by rijo78 »
I don't have that problem. My Android phone does not switch off wifi
rijo78
Post by rijo78 »
I have got it working now with another script from http://www.domoticz.com/forum/viewtopic ... 20#p27020.
ceedebee
Post by ceedebee »
Nice script, I took the liberty to change it a bit so you don't need to use the bash script anymore.
Why did you use this bash script anyway? It seems to me it's a bit nicer to have it all in one script.
realwheel
Post by realwheel »
Can you please post your version of the script which does not require the bash script anymore?
ceedebee
Post by ceedebee »
I am just a beginner in lua coding, so maybe some improvements do apply (the script is not tested through and through):
    return { str }
  local result = {}
  local nb = 0
  local lastPos
    nb = nb + 1
    result[nb] = part
    lastPos = pos
  if nb ~= maxNb then
  return result
--Get the list of phones to check on
phoneslist= uservariables['Telefoonlijst']
--Do an arp-scan on the localnet
--and search for the mac adresses
if phoneslist ~= nil then
  local newphonelist =""
  local currenttime = os.time()
  local outdoorsdelay = 5 * 60
  --do the arp scan and store the result
  local command = "sudo arp-scan --interface=eth0 192.168.xxx.1-192.168.xxx.yyy --retry=5 --ignoredups"
  local handle = io.popen(command)
  local result = handle:read("*all")
  handle:close()
  --Get a list of all phones
  phones=splitString(phoneslist,"|")
  --Search arp-scan result for presence of MAC for each phone
  for i,line in pairs(phones) do
    --Get the data for this phone
    phone=splitString(line,";")
    --and the switch state
    switchstate = otherdevices[phone[2]]
    --Fill a new list with phones
    if i > 1 then newphonelist = newphonelist.."|" end
    newphonelist = newphonelist..phone[1]..";"..phone[2]
    -- If phone detected write current time and switch on
    -- else switch off after the given delay time
    if string.find(result, string.lower(phone[1])) ~= nil then
      phone[3]= currenttime
      if string.lower(switchstate) == 'off' then commandArray[phone[2]] = 'On' end
      if tonumber(currenttime) > (tonumber(phone[3]) + outdoorsdelay) and string.lower(switchstate) == 'on' then
        commandArray[phone[2]] = 'Off'
        print(phone[2].."; now:"..os.date("%Y-%m-%d %H:%M:%S", currenttime).."; last seen: "..os.date("%Y-%m-%d %H:%M:%S",tonumber(phone[3])))
    newphonelist = newphonelist..";"..phone[3]
  --print(newphonelist)
  commandArray['Variable:Telefoonlijst']= newphonelist
  print("Uservariable 'Telefoonlijst' not found!")
p.s. change the xxx and yy in the ip addresses to your own range
I added an extra field in the user variable to store the latest time the phone has been seen. With a delay on this time the switch is switched off when the phone is out of reach. The second field in the user variable is changed to the name of the switch to switch on/off, one switch for every phone each.
Cannon
Domoticz version: 3.5877
Post by Cannon »
Hi Ceedebee
Would you mind providing a step by step on how to set this up?
I'm happy if you just PM if no one else wants the info.
Cheers for your help
ceedebee
Post by ceedebee »
At first: one bugfix, I programmed a print statement for logging the case a phone gets out of reach (somewhere around line 73). The function 'date()' is wrong, must be 'os.date()'. I fixed it in the code, like I said: not all was checked although the scripts works just fine. It detects the presence of phone correctly, with the remark of course that the wifi must always be switched on.
Then the setup: I added three switches in domoticz with the name of the phone owners, but this name can be anything. After that I added a uservariable with the name 'Telefoonlijst' wich means 'Phonelist'. In this variable, per phone, separated by ";" sign three variables: MAC, name of the switch, 0. Followed by "|" symbol before the next phone entry. For example 00:11:22:33:44:55;Phone1;0|66:77:88:88:AA:BB;Phone2;0
The last field is the 'last time seen' field. Initially set to 0 but filled with the current time if the phone is detected on the network. Each minute the network is checked via arp-scan for the presence of phones. I changed the original arp-scan command a bit because I know my router isn't assigning IP addresses above the "100" so scanning all the range to 256 is not necessary . I also added the retry parameter and the ignore dups parameter.
The advantage of the script is that it only does one arp-scan each minute and not one for each phone listed like the original. So I could add some retries.
p.s. don't forget to install the arp-scan program via: sudo apt-get install arp-scan
zmaster
Domoticz version: Latest
Post by zmaster »
Your script works like a charm ceedebee! I just installed it. Phones going into standby is a bit tricky but I think the timeout in the script could minimize the flapping noise it might cause.
ceedebee
Post by ceedebee »
Nice to hear. I don't know if there is a better alternative to detect if the users are indoors. I considered use a geofence app but this is using wifi and gps so more battery drain. I hope the topic starter appreciates my changes to the original script.
rijo78
Post by rijo78 »
Hi ceedebee, I like the script. It seems pretty straight forward. Where exactly do I have to place the mac-address, switchname and 0? Do I have to replace something?
ceedebee
Post by ceedebee »
Just make a uservariable named 'Telefoonlijst' (Dutch for telephone list) or name it like you wish. And fill it with your phones MAC and switch names as follows:
MAC1;switchname1;0|MAC2;switchname2;0
ps if you change your variable name you have to change the line "phoneslist= uservariables['Telefoonlijst']" accordantly
rijo78
Post by rijo78 »
Aah! I finally got it working.
two things I did wrong. 1st setting user variables, 2nd name of the script. When I got both correct, it was working like a charm. Great work ceedebee! Really great script (once you know how it is working).
For those who are struggling with this as well:
1st: The user variables have to be set in Domoticz (Setup>More Options)
2nd: The name of the script has to start with 'script_time_' (don't think the rest is that important for the functionality of the script)
ceedebee
Post by ceedebee »
Well, credits are for the topic starter. I only changed it a bit.
rijo78
Post by rijo78 »
You are right.
Dadogiobbe Thanks for sharing your work! Greatly appreciated
BigDog
Domoticz version: V3.9269
Post by BigDog »
great script btw
thanks i am using it now
but how do i change the time that the script is scanning the mac adreses?
thanks in advance!
BigDog
1X Raspberry4B : Domoticz Version 2023.1 [Linux 5.10.63-v7l+ armv7l]
1X Conbee II : 2.25.3 - 26720700
1X RFXtrx433 USB Firmware:183
1X Mysensors Gateway 1.5 -3
6X ESP8266: Tosmota firmware
Zigbee : 6 Operators, 13 Sensors
