Venetian Blinds virtual switch
easyherve
Domoticz version: 2024.7
Post by easyherve »
I am using venetian blind as a virtual switch and as this device has 3 function button (Open, Stop, Close), I am looking to read the "STOP" event button into blocky (Open and Close event are ok).
- Open state = On
- Close state = Off
- Stop state = ??? I don't know which logic value I should write to get this state !
Somebody can help ? Thank you !
Ronny
Re: Venetian Blinds virtual switch
Post by Ronny »
Did you already succeeded? I am strugling with nearly the same problem. I would like to use in in LUA scripts.
cazadeis
Post by cazadeis »
idem
toto2882
Post by toto2882 »
Did u manage to find a solution ? I'm in the same case :S
Thank's a lot
gogofram
Post by gogofram »
I also want the stop action with the Venetian Blinds to control my Fernotron blinds. Will it be possible in future update please?
nizaga
Post by nizaga »
Hi, did you ever find a solución for this? I have a silimar issue.
I have a motor i to control my awning. I am using broadlink so i need the open, clase and stop button.
My current approach is to have 2 virtual switches, one to open - stop, and the other to close-stop.
This is why i was wondering if i could use the venetian blinds (in fact i have 4 ASA motors controlled with RFXCom and it is working great, however the awning motor is not supported by RFXCom.
Nim
capitalT
Post by capitalT »
