Watermeter with wireless door sensor and TCRT5000 ?
Posted: Thursday 15 January 2015 21:30
by sheriff
I use a wireless doorsensor on my gasmeter like the KAKU wireless doorsensor project, and it works very well.
Now i would like to monitor my water meter with a TCRT5000, but do not want to use piface or raspberry gpio.
Would it be possible to use one of my wireless doorsensors, remove the reed contact and attach the digital or analog output of the TCRT5000 to these contacts ?
The removed reed contact just makes connection between the two contacts, is the TCRT5000 usable to replace the reed contact ?
This setup would make a very cheap wireless watermeter counter.
Re: Water meter with wireless door sensor and TCRT5000 ?
Posted: Thursday 15 January 2015 22:15
by sincze
sheriff wrote:I use a wireless doorsensor on my gasmeter like the KAKU wireless doorsensor project, and it works very well.
Why not connect this sensor directly to GPIO pins 3,3v / GND & GPIO? Instructions are available on the forum
Posted: Thursday 15 January 2015 22:21
by sheriff
Because i am not using my raspberry for domoticz, only as xbmc media player. I run domoticz on my ubuntu server.
Posted: Thursday 15 January 2015 22:44
by sincze
Clear in that case it is an interesting setup
Posted: Sunday 22 March 2015 10:16
by Gerwin1967
Interesting looking for such a solution as well, did you succeed, can you share some pictures and the script you used?
Posted: Sunday 22 March 2015 10:19
by ThinkPad
You could also build this with MySensors:
http://www.mysensors.org/build/pulse_water
Build an Ethernet gateway (Arduino + W5100 Ethernetshield) or Serial gateway (Arduino connected with USB to your server) and receive the data from the watermeter node (another Arduino, but this one measures the watermeter with TCRT5000).
The needed parts can be obtained cheaply from China, by buying from eBay or so.
MySensors is supported since a few weeks ago, in the beta release of Domoticz.
Posted: Sunday 22 March 2015 11:20
by mvveelen
I'm interested too in a cheap (preferably ready-to-use) solution for logging the water-usage. Maybe, in due time, there will be something I can use for my watermeter.
Posted: Sunday 22 March 2015 12:14
by sincze
Gerwin1967 wrote:Interesting looking for such a solution as well, did you succeed, can you share some pictures and the script you used?
TCRT 5000 can be used for watemeter just fine.
I would not suggest to use the interrupt routines. It gave me a lot of false positives in the beginning.
Posted: Sunday 22 March 2015 12:33
by mvveelen
What would one advice for metering the water usage with a meter like this:
I know there are ready-to-use solutions, but they cost about 80 euro's and for that amount of money I can use a lot of water... So I prefer a cheaper way to monitor the usage and.....something that is easy to make for a n00b as me
Posted: Monday 23 March 2015 15:49
by jossie67
mvveelen,
I'm working on a TCRT5000, directly connected to GPIO.
It detects the metalpart of the arrow.
Now I have to change the it, so it only sends a puls to my domoticz when the status changes from 0V to 3.3V.
Posted: Monday 23 March 2015 15:54
by mvveelen
Will that work flawlessly, or is this perhaps a better way:
http://www.domoticz.com/forum/viewtopic ... 1103#p6746 ?
That might even be easier to build or mount to the water meter, wouldn't it?
Posted: Tuesday 24 March 2015 15:43
by jossie67
Not sure, I made a small Python script to detect a one rotation. That is working fine now.
Next step is to upload the "puls"to domoticz. Since I running domoticz on Ubuntu VMware session.
Posted: Tuesday 24 March 2015 21:46
by sincze
mvveelen wrote:What would one advice for metering the water usage with a meter like this:
tcrt-5000 will do just fine with this meter.
Re: Watermeter with wireless door sensor and TCRT5000 ?
Posted: Sunday 10 January 2016 17:34
by mistysnip
Would the TCRT5000 work with this type of water meters?
Posted: Sunday 10 January 2016 17:44
by sincze
Hmm , Probably not as there is not a lot of reflective area the sensor can use
Sent from my SM-G925F using Tapatalk
