Change Web Path Topic is solved
Cybershot803
Change Web Path
Post by Cybershot803 »
is it/would be possible to be able to change or set web path?
i.e. change http://localhost:8080/ to http://localhost:8080/domoticz/
as this will make it a lot easier to manage and to use IIS reverse proxy (get random results with it trying to run at webroot a the mo)
JohnAdders
Re: Change Web Path
Post by JohnAdders »
I've added the ability to set the webroot, should be in recent builds.
John
pepijn
Re: Change Web Path
Post by pepijn »
When setting -webroot as parameter i receive a HTTP 500 error when i try to access http://domoticz:8080/domoticz.
nayr
Domoticz version: github
Re: Change Web Path
Post by nayr »
dont forget the trailing slash
Damoms
Re: Change Web Path
Post by Damoms »
You're right. This frontpage also doesn't have all devices working. Actually, currently it only works for certain types of devices that I have at home.
รูเล็ต
