i'm new to Domoticz (coming from Zipato) and using it to control my Danfoss LC_13 Thermostats.
The timer function is working fine to control them time based.
Now i'm trying to use it under the events section with an Fibaro Door Sensor (which is working fine).
So i want to set the thermostat to off/4 Degrees (what is the same in this case).
But what ive seen is that i cant use an Utility with an set command, so how can i do this?
Domoticz Windows Version 2186
thx,
maugrim
Danfoss LC_13 Events - use setpoint value
mfranken
Re: Danfoss LC_13 Events - use setpoint value
I'm trying the same, and would be very happy with this feature too
Raspberry, RFX, Zwave, JeeNodes, MySensors, OTGW, Domotix iPhone App
maugrim
Hi, maybe there is any update on this? ive seen that setpoint in blockly is supportet, but i cant understand how to use it?
Anyone have an advice for me?
Thx
Im now on v2455 on an RPI2
Thx
any news? Could you post here a blocky snapshot?
thanks in advance!
thanks in advance!
any LUA or Blockly example with these devices?
thanks in advance
EDIT: a little contribution
dummy switch and a LC13 with IDx 9
How can I create It with Blockly??
thanks in advance
if (devicechanged['Calefaccion'] == 'On') then
commandArray['SendNotification']='Calefaccion Encendida#Calefaccion Encendida#0'
commandArray['UpdateDevice']="9|0|21"
elseif (devicechanged['Calefaccion'] == 'Off') then
commandArray['SendNotification']='Calefaccion Apagada#Calefaccion Apagada#0'
commandArray['UpdateDevice']="9|0|18"
- Plaagje
- Domoticz version: Latest
Thanks for the lua script, i have a few questions about the numbers;zofiel wrote:any LUA or Blockly example with these devices?
thanks in advance
How can I create It with Blockly??Code: Select all
commandArray = {} if (devicechanged['Calefaccion'] == 'On') then commandArray['SendNotification']='Calefaccion Encendida#Calefaccion Encendida#0' commandArray['UpdateDevice']="9|0|21" elseif (devicechanged['Calefaccion'] == 'Off') then commandArray['SendNotification']='Calefaccion Apagada#Calefaccion Apagada#0' commandArray['UpdateDevice']="9|0|18" end return commandArray
"9|0|18"
9 = the idx of the device
18 = the setpoint of the device.
what does the "0" represent?
@zofiel: i guess the blocky would look something like this
