The topic title says it all I guess.
I'm building my own LED dimmer using LUA scripts (You can find all the information in this topic: http://www.domoticz.com/forum/viewtopic.php?f=23&t=4723). Currently the best resolution that is available is using a LightwaveRF dimmer which is able to do 3% steps. This translates in 32 values available maximum.
It would be awesome if we could change it to having 1% steps available. Although using the slider interface this would be a bit hard, using scene's it would be very nice!
[372] Dimmer with 1% resolution
- Quindor
http://www.campzone.nl World's Largest Outdoor LANParty, 1750+ people gather for 11 days! 10Gbit routed network, 1Gbit full-duplex internet, etc.
Re: [372] Dimmer with 1% resolution
+1 for that!
Why would you need that? Can you see the difference between 50% brightness and 51% brightness with the naked eye
I am not stopping you from asking to implement it, but in a practical way i don't see the benefit of it.
- Quindor
My dimmer implementation has 1024 values (0 to 1023), the way light and LED's work is that steps in the lower region are much more visible then steps in the higher region. So going from 10 to 50 is VERY visible, but going from 750 to 800, while rising the same amount of light production, it isn't as visible directly.ThinkPad wrote:Why would you need that? Can you see the difference between 50% brightness and 51% brightness with the naked eye?
Currently if you look at what I get from Domoticz, value 0=0, value 1=33 and value 2=66. That is a huge difference! I would just like some more control over it, with a scale of 100 it would also map nicely to 1=10, 2=20, 3=30, etc.. Having a maximum of 1000 is fine, I never drive my LED strips with max output anyway because the efficiency curve goes down quite a lot above 85% to 90% of max output.
In the future I'm thinking of implementing some sort of Logarithmic scale to even this out a bit and to make the values correspond better to the actual perceived light levels then the PWM level, but that's something for in the future.
I have about the same request, but I would rather make the sliders customisable in order to keep everybody happy. Instead of having a fixed range 0-32, I would add 2 extra fields in the Edit section of the switch (when type dimmer is chosen). With these fields you could then set the min-value and the max-value of the slider. When no values are set, you default to 0 and 32.
It's true that for higher values, this setting doesn't make difference on the visual aspect of the lights, but in the low range (<10%) it makes a huge difference.
This would be a nice addition for my project where I use a dimmer to light the individual steps of stairs with RGB strips. During the night I keep my strips at 0.5% when they are turned off, power consumption is extremely low and this adds some extra safety to the stairs.
Grtz,
Patrick
Patrick
To get something bit more usefull it might be possible to have a 32 entry table and then do a lookup.
As the LED is not linear anyway, you could have a finer resolution in the lower values.
Something like this:
http://electromotiveforces.blogspot.dk/ ... nging.html
I've made a logarithmic scaled LUA dimmer script, for anyone that might be interested.
Its hosted here on GitHub
Genius, you get more precise control with dimmer. I just built Quindorians PWM control. He is using svalue*33 formula.dacora wrote:I've made a logarithmic scaled LUA dimmer script, for anyone that might be interested.
Comparing your logarithmic vs *33 formula:
1*33 = 33 8
2*33 = 66 8
3*33 = 99 9
4*33 = 132 16
5*33 = 165 25
6*33 = 198 36
7*33 = 231 49
8*33 = 264 64
9*33 = 297 81
10*33 = 330 100
11*33 = 363 121
12*33 = 396 144
13*33 = 429 169
14*33 = 462 196
15*33 = 495 225
16*33 = 528 256
17*33 = 561 289
18*33 = 594 324
19*33 = 627 361
20*33 = 660 400
21*33 = 693 441
22*33 = 726 484
23*33 = 759 529
24*33 = 792 576
25*33 = 825 625
26*33 = 858 676
27*33 = 891 729
28*33 = 924 841
29*33 = 957 900
30*33 = 990 961
31*33 = 1023 1023
