Domoticz Hardware section layout tweak
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I was playing around with the layout of the hardware section and made a small tweak
If people like it i'll suggest a PR to Domoticz
Just copy these 2 files in the domoticz directory
Click on the button to switch On/Off
Click on the tile and the settings will popup
www.rar
(11.76 KiB) Downloaded 2 times
Re: Domoticz Hardware section layout tweak
I did not try it but from the screenshot it looks like you want to have the hardware gateways look like devices.
I like it the old way as it is something else and looks like something else.
Also switching a hardware gateway on/of does not have to be a simple click action. In the old way you have to select the gateway, switch off and save. In your proposal it is one simple click. If you click wrong you have an issue. In the old way you cannot accidentally switch a hardware gateway off.
