[Python Plugin] Automatic Watering System – Open-Meteo & Soil Moisture Control
szelessavmuhely
Post by szelessavmuhely »
Hello everyone,
I would like to share our **Automatic Watering System (AWS_OA)**, a free and open-source Python plugin for Domoticz, developed as part of the Szélessáv Smart Home project.
The plugin controls irrigation based on user-defined schedules, soil moisture measurements and precipitation data from **Open-Meteo**.
The goal is simple: avoid unnecessary watering while keeping the system flexible and easy to configure.
**Main features**
- Three operating modes: Off / On / Automatic
- 1–24 watering cycles per day
- Configurable watering duration from 1 to 30 minutes
- Adjustable starting time
- Soil moisture monitoring with multiple sensors (average value)
- Precipitation monitoring for the previous 24 hours
- Forecast precipitation monitoring for the next 24 hours
- Independent rainfall thresholds from 1 to 50 mm
- Support for multiple irrigation valves controlled together
- Operation without soil moisture sensors
- Automatic watering disabled if required weather data is unavailable
- Custom HTML dashboard with irrigation and weather history
- 16 language translations
**Dashboard**
**Weather data**
The current version (1.4.0) uses Open-Meteo. Weather information is updated every 30 minutes using the geographical coordinates configured in Domoticz.
No separate weather service account or API key is required for the integration.
**Irrigation and weather history**
The custom dashboard displays soil moisture, rainfall during the previous 24 hours, forecast precipitation for the next 24 hours, and irrigation activity.
*The graph contains illustrative demo data.*
**Hardware compatibility**
The plugin works with irrigation valves, relays and soil moisture sensors already integrated into Domoticz. It is not limited to Zigbee devices.
All configured valves are controlled together. Independent watering schedules for individual zones are not currently supported.
**Plugin configuration**
**Source code and installation**
GitHub:
https://github.com/szelessavalapitvany/ ... ing-System
**Documentation**
Overview:
https://www.szelessavmuhely.hu/en/irrigation_control
The plugin is designed to run on a local Domoticz installation. An internet connection is only needed for retrieving Open-Meteo weather information when weather monitoring is enabled.
Feedback, bug reports and suggestions are welcome, either here or through GitHub Issues.
Best regards,
Szélessáv Műhely
