Dear Henry,
Sorry to bother again but... what type of virtual sensors did you use for:
netUsed = 0, -- kWh netto verbruik (netGrid > 0)
netBack = 0, -- kWh netto teruglevering (netGrid < 0)
I don't seem to understand how / where they are being used...
Whether I use a Custom Sensor, Usage (Electric), Text, or Counter, I keep getting the following errors in the log:
2026-08-21 01:18:00.631 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh netto verbruik (netGrid > 0)" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
2026-08-21 01:18:00.632 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh netto teruglevering (netGrid < 0)" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
2026-08-21 01:53:00.937 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh ELECTRIC netto verbruik (netGrid > 0)" (deviceType=Usage, deviceSubType=Electric). If you believe this is not correct, please report.
2026-08-21 01:53:00.938 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh ELECTRIC netto teruglevering (netGrid < 0)" (deviceType=Usage, deviceSubType=Electric). If you believe this is not correct, please report.
2026-08-21 01:54:01.213 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh TEXT netto verbruik (netGrid > 0)" (deviceType=General, deviceSubType=Text). If you believe this is not correct, please report.
2026-08-21 01:54:01.214 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh TEXT netto teruglevering (netGrid < 0)" (deviceType=General, deviceSubType=Text). If you believe this is not correct, please report.
2026-08-21 02:13:00.950 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh COUNTER netto verbruik (netGrid > 0)" (deviceType=RFXMeter, deviceSubType=RFXMeter counter). If you believe this is not correct, please report.
2026-08-21 02:13:00.951 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh COUNTER netto teruglevering (netGrid < 0)" (deviceType=RFXMeter, deviceSubType=RFXMeter counter). If you believe this is not correct, please report.
Yes, I'm having a (very) late night struggle
Thanks (again) for any help!
