Zendure SolarFlow 2400 AC+
Henry
Domoticz version: 2024.7
Post by Henry »
Good morning,
I recently got a Zendure SolarFlow 2400 AC+ and want to see some stats on the dashboard. I can't find an integration for this so what is the best approach for this? I'm running Domoticz 2026.2 and mosquitto.
Henry
Re: Zendure SolarFlow 2400 AC+
Post by Henry »
I found out that the stats can be collected from http://[ZENDURE_IP]/properties/report. I've created a DZVents script that collects the data every minute and store it in some dummy devices. Now I have the battery in the Energy Dashboard and on my dynamic home dashboard.
There is also this topic where the MQTT option was discussed: viewtopic.php?t=42929
Henry
Post by Henry »
Thank you. The topic is a bit older but I guess it's worth trying mqtt. For now the direct api works ok.
pgit
Post by pgit »
Henry wrote: Thursday 06 August 2026 12:51 I found out that the stats can be collected from http://[ZENDURE_IP]/properties/report. I've created a DZVents script that collects the data every minute and store it in some dummy devices. Now I have the battery in the Energy Dashboard and on my dynamic home dashboard.
Great, I'm trying to do the same thing, but programming in LUA is not really my thing;
I'm struggling to togle virtual switches from the values (0 or 1) from the report page...
Would you mind sharing your script?
And which property did you use in the energy dashboard?
I see there is one for battery charge power and a seperate one for battery discharge power, but I can only add one of them in the dashboard...
How did you combine them into one?
Thanks in advance!
Henry
Post by Henry »
This is the lua script i'm using:
    Zendure SolarFlow 2400 AC+  ->  Domoticz (via lokale zenSDK-API)
    Plaats dit bestand in:  <domoticz>/scripts/dzVents/scripts/zendure_local.lua
    (of plak de inhoud in Setup -> More Options -> Events -> dzVents nieuw script)
    Werkt naast de Zendure-cloud: de HEMS/lokale API is een extra uitgang,
    je app blijft gewoon live data tonen.
    Bevestigd endpoint:  http://[ZENDURE_IP]/properties/report
    Data zit onder .properties ; accu's onder .packData[]
    Aanmaken in Domoticz (Dummy hardware -> Virtual Sensors):
      - Percentage      : SoC totaal, en evt. per pack
      - Custom Sensor W : laden, ontladen, zon, naar huis, grid
      - Temperature     : apparaattemperatuur
      - Custom Sensor dBm (optioneel): WiFi-signaal
    Noteer van elk het idx en vul hieronder in. idx = 0 -> overslaan.
-- >>> AANPASSEN <<<
local ZENDURE_IP = '[ZENDURE_IP]'
local IDX = {
    -- kern
    soc       = 0,   -- Percentage      (electricLevel, %)
    charge    = 0,   -- Custom Sensor W (outputPackPower = laden)
    discharge = 0,   -- Custom Sensor W (packInputPower  = ontladen)
    solar     = 0,   -- Custom Sensor W (solarInputPower)
    toHome    = 0,   -- Custom Sensor W (outputHomePower)
    grid      = 0,   -- Custom Sensor W (gridInputPower)
    netPower  = 0,   -- Custom Sensor W (netto accuvermogen: + = laden, - = ontladen)
    netGrid   = 0,   -- Custom Sensor W (netto verbruik: gridInputPower - laadvermogen)
    remainOut = 0,   -- Custom Sensor min (remainOutTime, resterende ontlaadtijd)
    -- extra (optioneel)
    temp      = 0,   -- Temperature     (hyperTmp / 100)
    wifi      = 0,   -- Custom Sensor dBm (rssi)
    pack1soc  = 0,   -- Percentage      (packData[1].socLevel)
    pack2soc  = 0,   -- Percentage      (packData[2].socLevel)
    pack1temp = 0,   -- Temperature     (packData[1].maxTemp / 100)
    pack2temp = 0,   -- Temperature     (packData[2].maxTemp / 100)
    updated   = 0,   -- Text            (rapporttijd, uit timestamp)
    -- Voor het ingebouwde Energiedashboard:
    batPower  = 0,   -- Usage (Electric)            netto accuvermogen (Watt-veld "Batterij")
    batVolt   = 0,   -- Voltage                     (BatVolt / 100)
    energyIn  = 0,   -- Electric (Instant+Counter)  laadenergie  (In)
    energyOut = 0,   -- Electric (Instant+Counter)  ontlaadenergie (Uit)
    netUsed   = 0,   -- kWh  netto verbruik (netGrid > 0)
    netBack   = 0,   -- kWh  netto teruglevering (netGrid < 0)
    p1        = 1,     -- BESTAAND P1-device (Slimme Meter) - niet aanmaken, alleen uitlezen
-- >>> EINDE AANPASSEN <<<
        timer         = { 'every minute' },
        httpResponses = { 'zendureReport' },
    data = {
        lastTs = { initial = 0 },   -- laatste meetmoment (voor kWh-integratie)
        whIn   = { initial = 0 },   -- cumulatieve laadenergie   (Wh)
        whOut  = { initial = 0 },   -- cumulatieve ontlaadenergie (Wh)
        whUsed = { initial = 0 },   -- cumulatief netto verbruik      (Wh)
        whBack = { initial = 0 },   -- cumulatieve netto teruglevering (Wh)
    logging = {
        level  = domoticz.LOG_ERROR,   -- zet op LOG_INFO om mee te kijken
        marker = 'Zendure',
        -- 1) Elke minuut de lokale API opvragen
        if item.isTimer then
            domoticz.openURL({
                url      = 'http://' .. ZENDURE_IP .. '/properties/report',
                method   = 'GET',
                callback = 'zendureReport',
            return
        -- 2) Antwoord verwerken
        if not (item.ok and item.isJSON) then
            domoticz.log('Geen geldige JSON van de Zendure', domoticz.LOG_ERROR)
            return
        local p     = item.json.properties or {}
        local packs = item.json.packData   or {}
        local function setPct(idx, val)
            if idx and idx > 0 and val ~= nil then
                domoticz.devices(idx).updatePercentage(val)
        local function setW(idx, val)
                domoticz.devices(idx).updateCustomSensor(val)
        local function setTemp(idx, val)
                domoticz.devices(idx).updateTemperature(val)
        local function setText(idx, val)
                domoticz.devices(idx).updateText(val)
        -- kern
        setPct(IDX.soc,       p.electricLevel)
        setW(IDX.charge,      p.outputPackPower)
        setW(IDX.discharge,   p.packInputPower)
        setW(IDX.solar,       p.solarInputPower)
        setW(IDX.toHome,      p.outputHomePower)
        setW(IDX.grid,        p.gridInputPower)
        -- netto accuvermogen: laden positief, ontladen negatief
        local charge    = p.outputPackPower or 0
        local discharge = p.packInputPower  or 0
        setW(IDX.netPower, charge - discharge)
        -- netto verbruik: WERKELIJKE netafname (P1) minus wat er naar de accu gaat.
        -- gridInputPower van de Zendure is alleen zijn eigen laadstroom (~= outputPackPower),
        -- dus dat geeft altijd 0. De P1-meter is de echte huis-netafname.
        local p1net = 0
        if IDX.p1 > 0 then
            local p1 = domoticz.devices(IDX.p1)
            if p1 then p1net = (p1.usage or 0) - (p1.usageDelivered or 0) end
        local net = p1net - charge
        setW(IDX.netGrid, net)
        -- === Ingebouwd Energiedashboard ===
        -- Netto accuvermogen als Usage-device (Watt-veld "Batterij")
        if IDX.batPower > 0 then
            local pdev = domoticz.devices(IDX.batPower)
            if pdev then pdev.updateEnergy(charge - discharge) end
        -- Accuspanning
        if IDX.batVolt > 0 and p.BatVolt ~= nil then
            local vdev = domoticz.devices(IDX.batVolt)
            if vdev then vdev.updateVoltage(p.BatVolt / 100.0) end
        -- kWh-tellers: vermogen zelf integreren op basis van verstreken tijd
        local now = os.time()
        local dt  = 0
        if domoticz.data.lastTs > 0 then dt = now - domoticz.data.lastTs end
        domoticz.data.lastTs = now
        if dt < 0 or dt > 300 then dt = 0 end   -- gaten na uitval niet meetellen
        domoticz.data.whIn  = domoticz.data.whIn  + charge    * dt / 3600.0
        domoticz.data.whOut = domoticz.data.whOut + discharge * dt / 3600.0
        if IDX.energyIn > 0 then
            local d = domoticz.devices(IDX.energyIn)
            if d then d.updateElectricity(charge, domoticz.data.whIn) end
        if IDX.energyOut > 0 then
            local d = domoticz.devices(IDX.energyOut)
            if d then d.updateElectricity(discharge, domoticz.data.whOut) end
        -- netto verbruik/teruglevering als kWh-tellers (net = P1 - laadvermogen, zie boven)
        if net >= 0 then
            domoticz.data.whUsed = domoticz.data.whUsed + net    * dt / 3600.0
            domoticz.data.whBack = domoticz.data.whBack + (-net) * dt / 3600.0
        if IDX.netUsed > 0 then
            local d = domoticz.devices(IDX.netUsed)
            if d then d.updateElectricity(net > 0 and net or 0, domoticz.data.whUsed) end
        if IDX.netBack > 0 then
            local d = domoticz.devices(IDX.netBack)
            if d then d.updateElectricity(net < 0 and -net or 0, domoticz.data.whBack) end
        -- resterende ontlaadtijd: alleen zinvol tijdens ontladen.
        -- Laadt/idle -> apparaat geeft een placeholder (42000/59940 min); dan 0 tonen.
        if p.remainOutTime ~= nil then
            local rot = 0
            if discharge > 0 then rot = p.remainOutTime end
            setW(IDX.remainOut, rot)
        -- extra
        if p.hyperTmp ~= nil then setTemp(IDX.temp, p.hyperTmp / 100.0) end
        setW(IDX.wifi, p.rssi)
        if item.json.timestamp ~= nil then
            setText(IDX.updated, os.date('%Y-%m-%d %H:%M:%S', item.json.timestamp))
        if packs[1] then
            setPct(IDX.pack1soc, packs[1].socLevel)
            if packs[1].maxTemp ~= nil then setTemp(IDX.pack1temp, packs[1].maxTemp / 100.0) end
        if packs[2] then
            setPct(IDX.pack2soc, packs[2].socLevel)
            if packs[2].maxTemp ~= nil then setTemp(IDX.pack2temp, packs[2].maxTemp / 100.0) end
        domoticz.log('Zendure bijgewerkt: SoC=' .. tostring(p.electricLevel)
            .. '%  laden=' .. tostring(p.outputPackPower)
            .. 'W  ontladen=' .. tostring(p.packInputPower) .. 'W', domoticz.LOG_INFO)
I'm only reading the vaules, not writing anything. I hope the description in the code says enough.
pgit
Post by pgit »
Fantastic, thank you!
I will add the missing virtual sensors and try your script a.s.a.p.
I assume packData[2] is for one extra battery.
I have added two AB300L's so I wil also try to adapt your script to include packData[3] values.
Henry
Post by Henry »
I indeed have 1 extra pack. You can enter the link in a browser to check the json.
Good luck
pgit
Post by pgit »
Dear Henry,
Sorry to bother again but... what type of virtual sensors did you use for:
I don't seem to understand how / where they are being used...
Whether I use a Custom Sensor, Usage (Electric), Text, or Counter, I keep getting the following errors in the log:
2026-08-21 01:18:00.631 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh netto verbruik (netGrid > 0)" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
2026-08-21 01:18:00.632 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh netto teruglevering (netGrid < 0)" (deviceType=General, deviceSubType=Custom Sensor). If you believe this is not correct, please report.
2026-08-21 01:53:00.937 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh ELECTRIC netto verbruik (netGrid > 0)" (deviceType=Usage, deviceSubType=Electric). If you believe this is not correct, please report.
2026-08-21 01:53:00.938 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh ELECTRIC netto teruglevering (netGrid < 0)" (deviceType=Usage, deviceSubType=Electric). If you believe this is not correct, please report.
2026-08-21 01:54:01.213 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh TEXT netto verbruik (netGrid > 0)" (deviceType=General, deviceSubType=Text). If you believe this is not correct, please report.
2026-08-21 01:54:01.214 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh TEXT netto teruglevering (netGrid < 0)" (deviceType=General, deviceSubType=Text). If you believe this is not correct, please report.
2026-08-21 02:13:00.950 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh COUNTER netto verbruik (netGrid > 0)" (deviceType=RFXMeter, deviceSubType=RFXMeter counter). If you believe this is not correct, please report.
2026-08-21 02:13:00.951 Error: dzVents: Zendure: Method updateElectricity is not available for device "kWh COUNTER netto teruglevering (netGrid < 0)" (deviceType=RFXMeter, deviceSubType=RFXMeter counter). If you believe this is not correct, please report.
Yes, I'm having a (very) late night struggle ;-)
Thanks (again) for any help!
pgit
Post by pgit »
I just figured out they work when I choose them to be Electric (Instant + Counter), right?
But I am yet to grasp their use...
How are the different from the measurements of the P1 meter?
How did you configure them in the settings of the energy dashboard?
(It's still night time, I haven't seen their behaviour when there is solar input from my panels yet)
Henry
Post by Henry »
The type is type Electric (Instant+Counter) indeed. I’m not at home right now so it’s a bit hard for me to check but some devices are there just for testing. I’ve attached a screenshot of my energy daahboard settings.
pgit
Post by pgit »
Thanks a lot, Henry! :D
Looks like I have my energyboard working now.
(Maybe it's not a very good moment to show you, though, while the batteries are fully charged and the panels are supplying more then demanded, but I couldn't wait )
Next (and the real) challenge will be to be able to use Domoticz as a HEMS for the Zendure... :geek:
Henry
Post by Henry »
Looking good. Let me know if you succeed in controling the battery with domiticz
BartSr
Domoticz version: V2024.7
Post by BartSr »
Any news on this topic?
I tend to buy same type.
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
