Wizard suggestions
Posted: Tuesday 14 July 2026 8:56
Hi, I tested several scenarios and for the wizard there would be 2 more complex suggestions:
1. For text sensors there is only the on and off condition like a normal switch, but they can take any value, so it would be good to have an additional field (like a level switch) where the value can be entered. The same situation for variables, it can only be used when the variable is updated.
Maybe it would be ideal to have conditions depending on the type of switch/sensor and I will give an example the air conditioner has several switches, power (which can be used in the wizard), but it has a selector type to set the operating mode heating, cooling, ventilation an others for which there is no condition. That's why maybe it would be good if they loaded these values after selecting the device so that they could be selected depending on each device.
2. Support for multiple conditions of type "and" and "or"
