dynamic dashboard barometer widget levels
Gravityz
Post by Gravityz »
i am playing with the prediction strings
from the wiki these should be the existing/working levels
Barometer forecast can be one of:
0 = Stable
1 = Sunny
2 = Cloudy
3 = Unstable
4 = Thunderstorm
5 = Unknown
6 = Cloudy/Rain
they all seem to work however
level 4 shows this, if we add animated lightning would be a great change
Scherm­afbeelding 2026-07-07 om 19.18.38.png (61.87 KiB) Viewed 1214 times
level 6 shows this, if we add animated rain would be a great change
Scherm­afbeelding 2026-07-07 om 19.19.06.png (66.94 KiB) Viewed 1214 times
Gravityz
Re: dynamic dashboard barometer widget levels
Post by Gravityz »
second question.
is the domoticz widget responsible for the prediction(in this case cloudy)
and is so is the prediction a 1:1 base on the pressure level or is there a script running in the background which analyzes the history and displays the prediction based on this.
i need to know if the prediction is build in or that i need to write my own code and send the prediction level to the barometer myself
thanks
gizmocuz
Post by gizmocuz »
Good suggestion! I've just committed this to development, so it will be in the next beta:
- The Thunderstorm forecast (level 4) now has its own scene: a darker storm cloud with falling rain and an animated flashing lightning bolt.
- While implementing this I also found why the rain/snow animations never showed in the barometer widget: the raindrops, snowflakes and moon were positioned outside the visible widget area and got clipped away, so you only ever saw the clouds. That's fixed too — all forecast levels now animate properly (sun rays, falling rain, falling snow, storm with lightning). Level 6 (Cloudy/Rain) shows animated rain as well.
One thing to be aware of: when a "Sunny" forecast is shown between sunset and sunrise, the widget displays a clear night sky (moon + stars) instead of a sun. That's intentional , same behavior as the Weather widget.
About your prediction question — it depends on where the barometer device comes from:
- For hardware that reports raw pressure (BMP085/BMP280 on I2C, MySensors, RFLink, Z-Wave, etc.), Domoticz calculates the forecast itself. It's not a 1:1 mapping of the current pressure: it samples the pressure every minute and looks at the pressure trend over a rolling ~4 hour window (based on the NXP AN3914 application note). Quickly falling pressure → Thunderstorm, slowly rising → Sunny, and so on. That's also why a barometer shows "Unknown" for the first ~35 minutes after a restart — it hasn't collected enough history yet (the history is kept in memory only).
- Some integrations (for example MQTT Auto Discovery) do use a simple 1:1 mapping of the absolute pressure: <=980 Thunderstorm, <=995 Rain, >=1029 Sunny, otherwise Cloudy.
- For a virtual/dummy sensor that you update through the JSON API, the forecast level is whatever you send in the svalue — Domoticz does not recalculate it. So there you'd have to supply the level yourself (or calculate it in a script).
Gravityz
Post by Gravityz »
thanks, great job
it is like domoticz gets reinvented all over again (in a good way)
can not wait to try it out.
my barometer is a BME680 in esphome which sends out everything through MQTT autodiscovery.
That is probably the reason it always showed cloudy.
i now included some prediction code in the esphome device so it has the levels stable, sunny, cloudy,cloudy/rain, unstable, thunderstorm.
this is send out every 5 minutes to domoticz/in
{"idx":351,"nvalue":0,"svalue":"1019.7;2"}
last question.
are all these changes also commited to the weather widget because i noticed the trendline is visible in the barometer widget but it is not visible in the weather widget.
Gravityz
Post by Gravityz »
confirme working on the barometer widget
cloudy/rain
Scherm­afbeelding 2026-07-10 om 15.49.49.png (91.99 KiB) Viewed 1029 times
thunderstorm
Scherm­afbeelding 2026-07-10 om 15.49.23.png (101.12 KiB) Viewed 1029 times
also checked the weather widget
Thunderstorm animation working in style 1 and 2
cloudy/rain animation ONLY WORKING IN STYLE 1
trendline for barometer missing
gizmocuz
Post by gizmocuz »
Thank you for also testing.
Should now be fixed in the latest beta version.
No trendline in the weather widget. reason: it contains the temperature, barometer, rain, wind...
Gravityz
Post by Gravityz »
working sweet
Scherm­afbeelding 2026-07-15 om 22.33.41.png (43.15 KiB) Viewed 482 times
