Gree AC Local Plugin for Domoticz
A local LAN plugin for controlling Gree air conditioners directly from Domoticz.
No cloud. No MQTT.
The IP and MAC of the AC must be added to the plugin. Supports multiple units.
The plugin communicates directly with the indoor unit using the local Gree protocol.
Features
Local LAN communication
No cloud dependency
One hardware instance per air conditioner
Power ON/OFF
Operation Modes
Target Temperature
Room Temperature
Fan Speed
Vertical Swing
Turbo Mode
Display Light Control
Raw Status (Debug)
Automatic Reconnect
Virtual Environment Installer
https://github.com/blooesky/Domoticz-Gree-Ac
*It may also work with other brands that use Gree compressors.
(Also please check for more domoticz plugins https://github.com/blooesky?tab=repositories&q=plugin)
New Plugin for Gree Air Conditioner
pfloryann
- Domoticz version: 2026.3
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pfloryann
Re: New Plugin for Gree Air Conditioner
v1.0.8 has been released:
Fix Gree communication stability and add full fan speed support
- Improved Gree device discovery reliability
- Added retry logic during startup
- Fixed asyncio event loop conflicts in Domoticz
- Improved command response time
- Added all 6 fan speed levels
- Added protection against false OFF/Auto states
- Improved Power, Mode, Fan, Swing, Light and Turbo state handling
- Improved support for multiple plugin instances
