I am trying to make an automatic reset for the Somfy Tahoma Switch box. During testing i saw this: After unplugging the Somfy box power adapter and resetting the Somfy plugin, the Connection_Status of the box is wrong, adapter still unplugged, connection status Ok. I like to use the text in the 'Somfy_Connection_Status' device to do a reset of the box.
Is it possible to have an actual connection status, even when there is no communication?
Wrong Somfy connection status Topic is solved
Rik60
- Domoticz version: 2026.3
- Somfy_error.png (52.53 KiB) Viewed 3474 times
- Somfy_status.png (14.6 KiB) Viewed 3476 times
Rik60
Re: Wrong Somfy connection status
Problem solved, see: https://github.com/MadPatrick/domoticz_somfy/issues/91
