Emax-W6 via RTL_433 [SOLVED]
Posted: Friday 13 March 2026 14:29
by JeanBonnot
Hi everybody,
I recently installed an Emax-W6 weather station that transmits its data on 433 MHz. I'm using RTL_433, which recognizes the station perfectly, and Domoticz displays several devices from the Emax-W6.
BUT, only temperature and humidity are visible in Temp. page and emax-w6 LUX (luminosity?) appears in measurements page.
Other parameters such as UV radiation, rainfall, wind speed and direction have no associated devices.
The measurements page does not contain any of these devices.
The graphs for all emax-w6 devices are accessible (only) from the "Setting" - "Devices" page.
How to have emax-w6 devices displayed in"Measurements" page ???
Thx
OS: dietpi
Hardware: Orangepi 5
Version: 2025.2 (build 16997)
dzVents Version: 3.1.8
Python Version: 3.13.5
Re: Emax-W6 via RTL_433
Posted: Friday 13 March 2026 15:35
Wind and UV device appears in weather tab.
Posted: Friday 20 March 2026 8:16
by JeanBonnot
waltervl wrote: Friday 13 March 2026 15:35 Wind and UV device appears in weather tab.
Thx for reply, but ... "weather" tab does not exists ! (?), only "Utility" tab (Mesures in french).
No tab weather
No tab weather
Furthermore, I have two devices in "temperature", including the wind sensor ( but both only display the temperature).
temp only
temp only
temp only.png (80.81 KiB) Viewed 2659 times
And when I display the wind log, it's the temperature that's displayed....
Log wind
Log wind
Posted: Friday 20 March 2026 10:02
Go to Menu Setup-Users and activate the weather tab for the users you have. See wiki:
https://wiki.domoticz.com/User_Management
Posted: Tuesday 24 March 2026 8:08
by JeanBonnot
🙏 Thanks Walter, I'm a little ashamed I didn't look into that... Everything is working fine now.
