Hi everybody,
I recently installed an Emax-W6 weather station that transmits its data on 433 MHz. I'm using RTL_433, which recognizes the station perfectly, and Domoticz displays several devices from the Emax-W6.
BUT, only temperature and humidity are visible in Temp. page and emax-w6 LUX (luminosity?) appears in measurements page.
Other parameters such as UV radiation, rainfall, wind speed and direction have no associated devices.
The measurements page does not contain any of these devices.
The graphs for all emax-w6 devices are accessible (only) from the "Setting" - "Devices" page.
How to have emax-w6 devices displayed in"Measurements" page ???
Thx
OS: dietpi
Hardware: Orangepi 5
Version: 2025.2 (build 16997)
dzVents Version: 3.1.8
Python Version: 3.13.5
Emax-W6 via RTL_433 [SOLVED] Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- JeanBonnot
- Domoticz version: 2025.2
- Domoticz version: 2026.3
Re: Emax-W6 via RTL_433
Wind and UV device appears in weather tab.
- JeanBonnot
Thx for reply, but ... "weather" tab does not exists ! (?), only "Utility" tab (Mesures in french). Furthermore, I have two devices in "temperature", including the wind sensor ( but both only display the temperature). And when I display the wind log, it's the temperature that's displayed....
Go to Menu Setup-Users and activate the weather tab for the users you have. See wiki:
https://wiki.domoticz.com/User_Management
- JeanBonnot
