2025.2 beta 17265 fails to start
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Dave21w
Domoticz version: Stable
Post by Dave21w »
Just updated my test system from 2025.2 17252 to 17265 and it fails to restart. Update counter goes all the way to 99 which is unusual. First i thought we had the old issue back again so did a stop and start from cmd line but nothing. Performing a stop and start and then a systemctl status gets me this, but no gui and despite it saying it's started none of my switches work so i'd say it's not actually running.
Feb 25 07:21:47 domoticz systemd[1]: Starting domoticz.service - LSB: Home Automation System...
Feb 25 07:21:47 domoticz domoticz.sh[1699517]: Time synchronized, starting Domoticz...
Feb 25 07:21:47 domoticz domoticz.sh[1699525]: 2026-02-25 07:21:47.607 Status: Domoticz V2025.2 (build 17265) (c)2012-2026 GizMoCuz
Feb 25 07:21:47 domoticz domoticz.sh[1699525]: 2026-02-25 07:21:47.608 Status: Build Hash: 66fd1d463, Date: 2026-02-25 05:51:29
Feb 25 07:21:47 domoticz domoticz.sh[1699525]: 2026-02-25 07:21:47.608 Status: Startup Path: /home/pi/domoticz/
Feb 25 07:21:47 domoticz domoticz.sh[1699525]: domoticz: Domoticz is starting up....
Feb 25 07:21:47 domoticz domoticz[1699525]: Domoticz is starting up....
Feb 25 07:21:47 domoticz systemd[1]: Started domoticz.service - LSB: Home Automation System.
Update. Rolled back to 17252 and all good.
Last edited by Dave21w on Wednesday 25 February 2026 11:10, edited 2 times in total.
pfloryann
Re: 2025.2 beta 17265 fails to start
Post by pfloryann »
same here...i posted on github...i checked the logs in console...domoticz changed port from webserver in my case.
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
Dave21w
Post by Dave21w »
Thats interesting, I tried to toggle a zigbee relay using a zigbee push button and that did not work, as thats all via mqtt i would have thought even if the webserver had changed it's port the switch should have functioned, maybe it wasn't only the webserver port that changed.
Mithrandir99
Post by Mithrandir99 »
Same here to.
Seems that the webserver component crashes on startup.
The Domoticz backend and database and also the mqtt connections are working normal, but no webinterface.
Dave21w
Post by Dave21w »
There was no mqtt operation for me
Mithrandir99
For me mqtt explorer shows expected messages with sensor data on domotics/out topic.
Running Mosquitto on the same Server / IP as Domoticz.
Rik60
Post by Rik60 »
Strange, i did have this problem in the ealier versions of the beta. When updating from beta 171252 to 17265 for me no issues, after the update Domoticz was back online without manual restarting the domoticz service.
Dave21w
Post by Dave21w »
I'll risk another update and see whjat happens, I can always restore to 17252.
Dave21w
Post by Dave21w »
Nope definitely broken again,
pi@domoticz:~ $ systemctl status domoticz.service
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: activating (start) since Wed 2026-02-25 14:43:08 GMT; 1min 54s ago
Job: 1866
Invocation: 5de633cd37924070ac1c8e3a796560cf
Docs: man:systemd-sysv-generator(8)
Cntrl PID: 14018 (domoticz.sh)
Tasks: 6 (limit: 4759)
CPU: 363ms
CGroup: /system.slice/domoticz.service
├─13908 bash -c "#!/bin/bash\n\n# Domoticz Update Script\n# Created by GizMoCuz, 2026, version>
├─14010 sudo service domoticz.sh start
├─14012 systemctl start domoticz.service
├─14018 /bin/sh /etc/init.d/domoticz.sh start
└─14026 /home/pi/domoticz/domoticz -daemon -www 8080 -sslwww 443
Feb 25 14:43:08 domoticz systemd[1]: Starting domoticz.service - LSB: Home Automation System...
Feb 25 14:43:08 domoticz domoticz.sh[14018]: Time synchronized, starting Domoticz...
Feb 25 14:43:08 domoticz domoticz.sh[14026]: 2026-02-25 14:43:08.829 Status: Domoticz V2025.2 (build 17270>
Feb 25 14:43:08 domoticz domoticz.sh[14026]: 2026-02-25 14:43:08.829 Status: Build Hash: f4ffe4ac4, Date: >
Feb 25 14:43:08 domoticz domoticz.sh[14026]: 2026-02-25 14:43:08.829 Status: Startup Path: /home/pi/domoti>
Feb 25 14:43:08 domoticz domoticz.sh[14026]: domoticz: Domoticz is starting up....
Feb 25 14:43:08 domoticz domoticz[14026]: Domoticz is starting up....
pi@domoticz:~ $ sudo systemctl stop domoticz
pi@domoticz:~ $ sudo systemctl start domoticz
A stop, start also results in a hung cursor as it doesn't complete the start, you have to ctrl C to get back to a cmd line. Looks like another restore to 17252 for me.
Dave21w
Post by Dave21w »
beta 17270 has just popped up, this also produces the same result :(
Rik60
Post by Rik60 »
I did also the update to beta 17270. The counting stopt on 100, after a few minutes the message Update failed. After starting manually the domoticz service Domoticz was running on Beta 17270, so the update procedure has still some problems. I am going to re-open the issue on Github
Dave21w
Post by Dave21w »
Also fails using this method - just hangs.
root@domoticz:/home/pi/domoticz# ./updatebeta
>> Starting Domoticz beta Update
>> Script: updatebeta (Directory: /home/pi/domoticz)
>> Validating environment...
>> Environment validation passed (arch: aarch64, OS: linux)
>> Checking package dependencies...
>> Package 'libmosquitto1' is already installed
>> All required packages are already installed
>> Downloading latest beta version...
domoticz_update.tgz 100%[======================================================================>] 15.73M 64.9MB/s in 0.2s
>> Download complete. Verifying archive integrity...
>> Archive integrity verified.
>> Checking for updated upgrade script...
>> Found updated script, re-executing...
2026-02-25 16:10:54.541 >> Starting Domoticz beta Update
2026-02-25 16:10:54.542 >> Script: updatebeta (Directory: /home/pi/domoticz)
2026-02-25 16:10:54.542 >> Validating environment...
2026-02-25 16:10:54.549 >> Environment validation passed (arch: aarch64, OS: linux)
2026-02-25 16:10:54.550 >> Checking package dependencies...
2026-02-25 16:10:54.572 >> Package 'libmosquitto1' is already installed
2026-02-25 16:10:54.572 >> All required packages are already installed
2026-02-25 16:10:54.573 >> Running updated script - proceeding with installation...
2026-02-25 16:10:54.574 >> Stopping Domoticz service...
2026-02-25 16:10:55.022 >> Domoticz process stopped.
2026-02-25 16:10:55.023 >> Creating backup: backups/domoticz_backup_20260225_161055.tar.gz
2026-02-25 16:10:58.072 >> Removing old backups...
2026-02-25 16:10:58.074 >> Backup complete.
2026-02-25 16:10:58.075 >> Installing new version...
........................................2026-02-25 16:10:58.380 >> Installation complete.
2026-02-25 16:10:58.381 >> Starting Domoticz service (please wait)...
Rik60
Post by Rik60 »
Just a question, who is running also Zigbee for Domoticz?
mvveelen
Post by mvveelen »
Same problems here after updating to the latest build. Something to do with IPv6 or so?
Hope for a fix soon....
JanJaap
Domoticz version: Dev
Post by JanJaap »
I thought to simply go back to release, this doesn't work either. Service is started but front end doesn't respond......
Any instructions how to roll back to older beta?
gmarchionni
Post by gmarchionni »
if you use the tag:
FROM domoticz/domoticz:2026-beta.17252
i guess it should work, mine did at least.
mvveelen
Post by mvveelen »
After a night of sleep, I just updated Domoticz via the CLI and it's running again.
Beta 2025.2 (build 17277)
Dave21w
Post by Dave21w »
I can also confirm this, gui was only offering 17275 but cli update gave 17277 and despite the cli sitting at Starting Domoticz Service (please wait).... it had actually started and was running OK. ctrl c at the cli then showed the remaining 2 lines of info stating all was ok.
