dzvents lua scripts are not triggered anymore (build 17186)
Posted: Thursday 19 February 2026 19:27
by rugspin
since the update to v2025.2 (build 17186), all my dzvents lua automations are not triggered anymore. For example I see that a switch changes state, but the lua script is not triggered. (Also the CPU is much lower than before the update)
Anybody else seeing the same issue?
Re: dzvents lua scripts are not triggered anymore (build 17186)
Posted: Thursday 19 February 2026 20:06
by arnout
I have exactly the same issue, is there any way to downgrade to an older bèta version?
Posted: Thursday 19 February 2026 20:11
by meal
The same in Domoticz version 17188
LUA event are not triggered
BR
Posted: Thursday 19 February 2026 20:27
by rugspin
arnout wrote: Thursday 19 February 2026 20:06
I have exactly the same issue, is there any way to downgrade to an older bèta-vuile version?
I'm not exactly sure, but I think there is no real downgrade to older versions in form of a script.
The way to be able to do this, is a full backup of the domoticz installation folder, make the update and if something goes wrong revert back to the backup.
Now, there is a issue filed on github, so I will just wait a little. There was a lot of work done recently and I'm sure the next update will fix the issue.
Posted: Thursday 19 February 2026 21:24
by meal
I created the issue #6587 and found a fix to that issue which I tested successfully on my system.
We have to wait to the next release implementing the fix I suggested.
BR
Posted: Thursday 19 February 2026 23:11
rugspin wrote: Thursday 19 February 2026 20:27
For the next time you want to revert back to a previous version check the wiki
https://wiki.domoticz.com/Raspberry_Pi# ... ect_update
Posted: Friday 20 February 2026 9:34
by meal
The issue has been fixed in Domoticz Version 17192
BR
Posted: Friday 13 March 2026 21:12
by bboy19
It's not working on ver. 17366. I had to rollback to ver. 17030
Posted: Thursday 02 April 2026 8:31
by Henry
I'm not sure if this is related, but I upgraded to V2025.1 and now the dzvents scripts aren't triggered anymore. Due to an old pi os I can't upgrade to a newer version (working on that).
Posted: Thursday 02 April 2026 8:53
by azonneveld
rugspin wrote: Thursday 19 February 2026 19:27
What does your uptime counter says? (goto setup>about)
In my case the external watchdog kept restarting domoticz every ~2 minutes.
