since the update to v2025.2 (build 17186), all my dzvents lua automations are not triggered anymore. For example I see that a switch changes state, but the lua script is not triggered. (Also the CPU is much lower than before the update)
Anybody else seeing the same issue?
dzvents lua scripts are not triggered anymore (build 17186)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
arnout
Re: dzvents lua scripts are not triggered anymore (build 17186)
I have exactly the same issue, is there any way to downgrade to an older bèta version?
meal
- Domoticz version: 2025.2
The same in Domoticz version 17188
LUA event are not triggered
BR
BR
meal
rugspin
I'm not exactly sure, but I think there is no real downgrade to older versions in form of a script.arnout wrote: Thursday 19 February 2026 20:06 I have exactly the same issue, is there any way to downgrade to an older bèta-vuile version?
The way to be able to do this, is a full backup of the domoticz installation folder, make the update and if something goes wrong revert back to the backup.
Now, there is a issue filed on github, so I will just wait a little. There was a lot of work done recently and I'm sure the next update will fix the issue.
meal
I created the issue #6587 and found a fix to that issue which I tested successfully on my system.
We have to wait to the next release implementing the fix I suggested.
BR
BR
meal
Users browsing this forum: Amazon [Bot], heggink and 1 guest
