Telldus-core not found on new installation
Posted: Saturday 17 January 2026 22:03
by gnagis_99
Installed Domoticz 2025.2 in Docker on a Raspberry Pi with Debian Bookworm and can access it via the browser, but cannot get the connected Tellstick Duo to, for example, report temperature values to Domoticz.
Under "Setup-Hardware" in Domoticz I have selected Tellstick and it is enabled.
Under "Setup-Devices" none of my wireless thermometers appear.
After starting Domoticz, I see the error message "Tellstick: telldus-core not found" in the log.
Searched the Internet for a solution, but haven't found any answers to this.
Hope someone can help me with tips to solve this.
Regards,
Re: Telldus-core not found on new installation
Posted: Monday 19 January 2026 23:44
by gnagis_99
Hello again
I have now started from scratch on a new SD card.
1. Installed Raspberry Pi OS Debian Bookworm without desktop.
2. Installed Domoticz
3. Added Tellstick in Setup/Hardware
4. Connected Tellstick Duo to my Raspberry Pi 3 B
5. After reboot, these error messages appear in the Log
Status: PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
Status: Tellstick: telldus-core not found
In Domoticz, with the Tellstick Duo connected, I want to be able to control some Nexa switches and receive temperature from several wireless temperature sensors.
I would really appreciate it if someone could help me with this.
Posted: Tuesday 20 January 2026 0:02
Is this a python plugin or a build in integration. If python plugin, what is its GitHub repository?
And for python plugin look at the troubleshooting section in the wiki
https://wiki.domoticz.com/Using_Python_ ... leshooting
Posted: Tuesday 20 January 2026 0:09
by gnagis_99
Thanks for Your quick answer.
The Python-problem is solved, right now. (Installed 3.11)
But I have still problem with my "Telldus Core"
I can“t find any info on how to add telldus-core.
Posted: Tuesday 20 January 2026 4:17
by gizmocuz
Did you compile Domoticz yourself before?
This because by default support for Telldus is not available (See CMakeList.txt)
Posted: Tuesday 20 January 2026 7:59
by gnagis_99
No, I didn't, and I don't know how to do it.
I don't really understand what/how you mean with (See CMakeList.txt).
I have really tried to find information on the internet about how to install the latest version of Domotics on a Raspberry Pi, but a lot of it is old (e.g., from 2016) information and does not work nowadays.
I would really appreciate it if I could get some help understanding this and how I should do it?
Posted: Tuesday 20 January 2026 13:39
On this wiki there is a section about compiling Domoticz with telldus
https://wiki.domoticz.com/Basic_Tellsti ... h_Domoticz
But as it is old instructions you have to update it yourself or find someone who did this recently. Perhaps on some swedish domoticz forum?
Edit: this is the basic instruction to build Domoticz. This instruction is up to date, but does not have the Telldus implementation.
https://wiki.domoticz.com/Build_Domoticz_from_source
Posted: Tuesday 20 January 2026 20:29
by gnagis_99
I have searched the Internet and found some information, and these instructions you mention are some of them, but most are outdated. However, I can't seem to find what I need to get my Tellstick Duo up and running. It seems that I don't have enough knowledge to solve this, so I hope someone will help me, either to get my Tellstick working or to get help starting from scratch.
Posted: Tuesday 20 January 2026 23:01
I see this already outdated instructions for Ubuntu 18
https://github.com/karl-henrik/telldus
But looking at this it will probably not run on newer OS versions as Telduss did not update their libraries.
Posted: Saturday 31 January 2026 0:02
by gnagis_99
So it's basically impossible to get this running as long as Telldus doesn't update their libraries for newer OS versions?
Posted: Saturday 31 January 2026 0:21
Seems like it. But perhaps there is another way to communicate with a telldus stick? Perhaps there is a python api that is up to date?
