Reading TE923 Weather Station
Posted: Monday 12 January 2026 14:30
by PE1IAA
Hello readers,
It seems that TE923 USB Compatible Weather Station is no longer in the hardware list.
Who can i now connect my TE923 to domoticz.
I can read of cours also with RFXCOM - RFXtrx433 USB 433.92MHz Transceiver but than i cannot get the data
from my weatherstation like inside temperature and Barometer values.
Who can help me,
Regards Harry de PE1IAA
Re: Reading TE923 Weather Station
Posted: Tuesday 13 January 2026 21:00
by waltervl
I still have it in my hardware list in 2025.2 stable. And it does niet seems to be removed from latest beta.
On what type of environment are you running?
Posted: Tuesday 20 January 2026 4:12
by gizmocuz
If you own a RFXTrx433, I would suggest to have a look at a 433Mhz Temp+Hum+Baro meter, or buy a Zigbee THB sensor.
Both are not expensive.
If it is still visible under the supported hardware dropdown list, it should still be supported.
The TE923 (as well as a certain Voltcraft CO2 sensor) uses a special LIBUSB driver.
I noticed you have a PWS weather station page... so you should be able to get this data as well in Domoticz?
'73!
Posted: Wednesday 28 January 2026 17:30
by PE1IAA
Hallo Waltervl and gizmocuz,
I run domoticz on window 10 machine as my Rpb4+ does not work anymore with this software 2025.2
I have to update my machine but weewx is also no longer running than.
Ihave the following list in hardware. (see enclosure).
73's
