No domoticz after update
Posted: Saturday 03 January 2026 15:18
I launched the update today, but something works wrokng during the update.
I rebboted the raspberry, abd after the domoticz service run but I can't be connected to domoticz webpage.
I tried to reinstall the domoticz with this solution:
viewtopic.php?t=43467
But I continue t have the same issue.
When I check the status, I have this error : raspberrypi domoticz.sh[407]: /home/pi/domoticz/domoticz: error while loading shared libraries: libssl.so.3: cannot open shared object file: No such file or directory
Version : The last
Platform : raspberry 3+
Could you help me please?
sudo service domoticz.sh status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Sat 2026-01-03 15:09:09 CET; 8min ago
Docs: man:systemd-sysv-generator(8)
Process: 407 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Jan 03 15:09:08 raspberrypi systemd[1]: Starting LSB: Home Automation System...
Jan 03 15:09:09 raspberrypi domoticz.sh[407]: /home/pi/domoticz/domoticz: error while loading shared libraries: libssl.so.3: cannot open shared object file: No such file or directory
Jan 03 15:09:09 raspberrypi systemd[1]: Started LSB: Home Automation System.
Version : The last
