Domoticz version 2025.2 released
News and/or updates regarding Domoticz or things related to Domoticz will be placed here.
Twitter: https://twitter.com/Domoticz | Facebook: https://www.facebook.com/domoticz | Changelog: Github
Moderator: remb0
Locked
gizmocuz
Post by gizmocuz »
Time again for a new stable release!
This could not have happened without the help of everyone who contributed to make this happen!
Forum moderators, users, beta testers and specially all those who contributed with code! Thank you once again!!!
As always, PLEASE make a FULL backup of your Domoticz folder (or in case of an embedded system, your SD card!)
This way you can always return to the previous version you were running before this update!
Thanks to all volunteers who helped with the implementation! I know it was a lot of work with a lot of stress!
Please note that this release is using OpenSSL 3.0, you need a Debian version Bookworm or newer (Debian 13 Trixie),
on Ubuntu 24.04 or newer (due to gcc requirements). You can also move to the Docker installation if you do not want to upgrade the OS of your system.
To update your OS from bullseye to bookwork you can use this guide: https://www.cyberciti.biz/faq/update-up ... -bookworm/
Here are the most important changes (there are way too many changes to list them all):
Version 2025.2 (October 13th 2025)
- Implemented: EnergyDashboard, add option for (Outside) Temperature Sensor
- Implemented: Enever, Added Pure Energy, removed obsolete providers
- Implemented: Enphase, display a error is a IQ inverter has not been received for more then a day
- Implemented: Kodi, support for 'tvshow' type
- Implemented: MQTT-AD, added support for Climate action_template/state
- Implemented: MQTT-AD, added support for IR Blaster (Tuya iH-F8260)
- Implemented: MQTT-AD, handling battery low boolean sensors
- Implemented: MQTT-AD, allow publishing messages
- Implemented: P1 Chart, Report: Added Total Column (Usage-Return)
- Implemented: Rain Rate notification
- Implemented: Support for Humidity only graph
- Fixed: MQTT-AD, fix issue where brightness and RGB command topic are different
- Fixed: MQTT-AD, preserve select options when updating a device
- Fixed: Replace device now also copies 'Options' field
- Changed: Enphase query Token method
- Changed: mDNS, hostname now lowercase
- Changed: MQTT-AD, added support for color_temp_command_template
- Changed: TADO, Added fixed API endpoint
- Changed: TADO, Add poll interval option
- Changed: MQTT, not publishing devices that are not used
- Changed: Philips Hue now uses HTTPS to be compliant with new Hue Bridge
- Fixed: mDNS, possible crash when web server (non) SSL was disabled, or a invalid port was specified
- Fixed: Charts, after deleting a datapoint, the browser was not correctly refreshed
- Updated: Windows libraries
For a full detailed overview visit:
https://github.com/domoticz/domoticz/commits/master/
You can also update manually by going to your Domoticz folder and issue the following command: ./updaterelease
Up up and away :mrgreen: !
If you encounter update issues please start a new topic in the Bugs and Problems subforum viewforum.php?f=6
This announcement is locked to prevent mixes of reported issues.
Locked
