Z4D plugin problem on Trixie
Posted: Wednesday 31 December 2025 16:34
by Fredom
Dear members,
I'm currently switching to Trixie. I've installed everything without any problems, but unfortunately, the Z4D plugin just won't work. I've carefully followed the wiki instructions, but I keep getting an error message that I can't figure out. Does anyone have a solution for me? Below is what I did and the error message.
fredom@raspberrypi:~ $ python3 -m pip install -r requirements.txt --upgrade -t /home/fredom/Domoticz_Python_Environment
ERROR: Could not open requirements file: [Errno 2] Bestand of map bestaat niet: 'requirements.txt'
fredom@raspberrypi:~ $ sudo python3 -m pip install -r requirements.txt --upgrade -t /home/fredom/Domoticz_Python_Environment
fredom@raspberrypi:~ $ cd /home/fredom/domoticz/plugins/Domoticz-Zigbee
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ python3 -m pip install -r requirements.txt --upgrade -t /home/fredom/Domoticz_Python_Environment
Re: Z4D plugin problem on Trixie
Posted: Wednesday 31 December 2025 17:19
by jannl
I was planning about moving to trixy as well. However some problems and reading about that made me gonto bookworm. Trixy is not stable enough to run on a pi, at least not for me on a production system.
Tip: us full-upgrade so you don't accidently brick your system a I did, because of missing dependencies.
Posted: Wednesday 31 December 2025 17:25
by waltervl
If you do an ls in ~/domoticz/plugins/Domoticz-Zigbee is there a requirements.txt ?
Posted: Wednesday 31 December 2025 18:37
by Fredom
waltervl wrote: Wednesday 31 December 2025 17:25
No it's emty
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ ls
Posted: Wednesday 31 December 2025 21:19
by waltervl
Then you did not follow the instructions
https://zigbeefordomoticz.github.io/wik ... g-on-linux
But instead of the option to use the –break-system-packages use the python venv option as you already followed
https://zigbeefordomoticz.github.io/wik ... alEnv.html
Posted: Wednesday 31 December 2025 23:33
by Fredom
Hi Walter,
I've tried both links and keep running into the same problem, see below. I also tried using AI in various ways, and then I managed to install the plugin, but of course, it didn't work. The domoticz log was full of errors. I'm afraid this won't work on Trixie.
Posted: Wednesday 31 December 2025 23:52
by waltervl
Then the following command did go wrong in folder
git clone https://github.com/zigbeefordomoticz/Domoticz-Zigbee.git
Posted: Thursday 01 January 2026 10:38
by Fredom
waltervl wrote: Wednesday 31 December 2025 23:52
Hi Walter,
You made my day. Your suggestion solved the problem. It works now. I did see an error, and I'm not sure if I need to do anything about it, but Z4D does work. Thanks a lot!
fredom@raspberrypi:~/domoticz/plugins $ git clone https://github.com/zigbeefordomoticz/Domoticz-Zigbee.git
Cloning into 'Domoticz-Zigbee'...
remote: Enumerating objects: 57939, done.
remote: Counting objects: 100% (1634/1634), done.
remote: Compressing objects: 100% (304/304), done.
remote: Total 57939 (delta 1538), reused 1350 (delta 1330), pack-reused 56305 (from 3)
Receiving objects: 100% (57939/57939), 112.24 MiB | 6.88 MiB/s, done.
Resolving deltas: 100% (39293/39293), done.
fredom@raspberrypi:~/domoticz/plugins $ cd /home/fredom/domoticz/plugins/Domoticz-Zigbee
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
types-flask-migrate 4.0 requires Flask-SQLAlchemy>=3.0.1, which is not installed.
pyopenssl 25.0.0 requires cryptography<45,>=41.0.5, but you have cryptography 40.0.2 which is incompatible.
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo systemctl restart domoticz.service
Warning: The unit file, source configuration file or drop-ins of domoticz.service changed on disk. Run 'systemctl daemon-reload' to reload units.
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo systemctl daemon-reload
fredom@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ cd
