Domotics version 2510-2 don't work on Raspbian Bullseye.
Posted: Sunday 14 December 2025 16:45
by tomaso
Tried to update Domoticz on my Raspbian Bullseye but update crashed. By default a backup should have been created but there is none. Trying to install current domoticz version fails because bullseye have OpenSSL 1.1.x and latest domotics require OpenSSL 3.
Is there any possibility to get the previous (2025-1) version that worked with Bullseye?
Re: Domotics version 2510-2 don't work on Raspbian Bullseye.
Posted: Sunday 14 December 2025 18:27
Try with docker.... You can run with the latest Domoticz version on bullseye.
https://wiki.domoticz.com/Docker
And if there was no backup made you were updating from a very old version so then it would be wise to make a manual backup anyway.
Posted: Sunday 14 December 2025 18:48
by elzorrovega
Hello Tomaso,
I believe that latest Domoticz version and SSL were meant to be compatible with bookworm. I hope that you have at least a recent database backup before your upgrade. I read somewhere in a response from gizmocus that you could probably run latest version of Domoticz in docker on top bullseye. You probably need to remove docker from bullseye. If docker is not to your taste then I guess that you must reinstall bookworm + Domoticz.
I have Domoticz on bookworm + mosquitto via docker + JS Zwave UI via docker. I recently tried to update my own system database and I was lucky to have an recent image of my entire system. I only lost some battery level data stored in global variables.
I strongly recommend to backup you entire system. Investing about two hours of your time will save you many hours of frustration.
If you interested in system backup, I blurbed something which might be outdated but can still give you some ideas.
viewtopic.php?t=40308
I hope this helps.
Posted: Monday 15 December 2025 12:55
by tomaso
Thanks for all suggestions.
I do have plans to update both hardware and software to latest versions.As it will take some time to achieve I beleive that installing the previous version of Domotics would be an easy quick fix to get Domoticz runnig while I prepare new hardware and software.
So I still want to get hold of the 2025-1 version.
Posted: Monday 15 December 2025 14:45
by jvdz
Posted: Wednesday 17 December 2025 14:08
by tomaso
Thanks for the tip! My Domoticz is now up and runnig on version 2510-1 again.
