Domoticz Home Automation Guide
elzorrovega
Domoticz version: 2025.2
Post by elzorrovega »
Hello All,
Please find this modest contribution as a guide to numerous encountered issues.
GUIDE TOPICS
Table Of Contents
Topic                                         Page
Introduction                                  3
Platform Choice                               4
RPI Domoticz Server                           4
RPI2 Sandbox                                  4
LINUX                                         8
Image Burning                                 11
USB Booting                                   13
Raspberry Pi 4B                               13
Raspberry Pi 3B+                              14
Docker Installation                           15
Install Docker                                15
MQTT Installation                             17
Wiki Documentation Links                      19
Domoticz Configuration                        19
Install Mosquitto                             19
Install Zwave-JS                              19
Install Zwave-JS-UI                           19
Zwave-JS-UI/Domoticz Configuration            21
Domoticz MQTT Gateways                        23
New Devices from Zwave-JS-UI                  24
Zwave-JS-UI Control Panel Page 1              25
Zwave-JS-UI Control Panel Page 2              25
Zwave-JS-UI Provisioning Entities             26
Zwave-JS-UI Settings                          27
Zwave-JS-UI Debug                             31
Zwave-JS-UI Store                             31
Zwave-JS-UI Network                           32
Zwave-JS-UI Debug Errors with localhost IP    33
Remote Access                                 34
VNC                                           34
DuckDNS                                       34
NAT Router set-up                             36
Certificate with snapd & certbot              36
Scripts                                       37
mdown.sh                                      37
updom.sh                                      37
rpidia.sh                                     38
inadyn.sh                                     38
smeagol.sh                                    38
Glossary                                      39
Attached is link to guide along with bash and DzVents script in Github.
https://github.com/elzorrovega/Domoticz ... tion-Guide
Please indulge me for I am new to Github.
I hope this will be of use to others.
Thanks to the Domoticz team who keep this project moving forward! :D
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bookworm 64 bit OS 6.12.47+rpt-rpi-v8
Domoticz Version: 2025.2
zwave-js-ui: 10.4.2.d3a89a7
zwave-js: 15.3.1
home id: 3714679688
home hex: 0xdd698388
Domoticz version: 2025.1
Re: Domoticz Home Automation Guide
Thanks for sharing this! Perhaps add in the github readme on github and perhaps your first post with the (rough) content overview of your guide? I think it would be easier for the users to find topics. Edit: I see they are added now, thanks!
I see you also touch Setup of Docker, MQTT, ZwaveJSUI etc.
JustDude
Domoticz version: Latest
Post by JustDude »
Thanks! I would also untar and upload all scripts in a separate folder. So one can see the source and pick your cherries from the list.
Measuring is knowing
