Which setting determine the Y range in a graph?
I have two different domoticz servers, one is showing the daily graph of temperature and percentage with the lower Y value determined by the min value of the data whereas the other always is relative to 0 (zero).
Would be nice if anyone could tell how to get control of this
No, this is type General, Percentage. It is actually the charge % for mye EV.
But I observe the same behavior for type Temp, LaCrosseTX3 and for type General, Custom Sensor.
I think this comes from a global setting, but can't find which setting.
Ah, I misread your question.
This is probably because you clicked on the Y-axis label. It then switches between 0 to highest value range and optimal band range. There is no global setting for it.
And perhaps the implementation for percentage is not the same as for temperatures....
But it also looks like you have 2 versions of Domoticz running. Filled in graphs is new in 2025.2. Or it is a browser cache issue. Perhaps look are the same Domoticz instance with the browser in incognito/private mode.
