Domoticz crash when 'Dummy' is enabled
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
voyo
Post by voyo »
Im having issue with Domoticz :(
It started on last Sunday, Domoticz started to crashing, I noticed after some time. After attempts to fix I gave up as it was late, and I just restored db from last day. I tought it could be cause by PluginManager which I enabled, added some new plugins etc.
Anyway - I restored backup and removed all new stuff that I added. It helped. I tough I will check later what was wrong.
But today - again, Domoticz is crashing , and I didnt touch it yet... Again - helping is just restoring old DB backup. But well... this is not an acceptable approach on long run :/
TLDR - Guilty is Dummy hardware device, and I need help troubleshooting it further :(
Context, environment and troubleshoot steps so far:
Domoticz x86, running on Docker on fast (enough) server.
Status: Domoticz V2025.1 (build 16611) (c)2012-2025 GizMoCuz
2025-09-09 00:04:25.251 Status: Build Hash: 506720457, Date: 2025-04-03 16:12:32
Database - no visible issues, I checked with integrity_check , recovery, and dump'ed everything to fresh file. No joy.
I disabled hardware, one by one , to find problematic one (update hardware set Enabled=0 where id=xx; )
Removed all my plugins , and scripts - physically, as files.
Even with everything removed, when only 'Dummy' is enabled - Domoticz is crashing very quickly.
I have plenty of devices based on 'Dummy', disabling them one by one is will be loooong night...
I really need good suggestions.
Docker is run with
EXTRA_CMD_ARG="-loglevel normal,status,error,debug -debuglevel normal,hardware,received,webserver,eventsystem,python,thread_id"
and here is crash:
(I just noticed there are still scripts enabled, probably autogenerated Blockly, dont know how to disable them .. but still - this is something I didnt touch).
2025-09-09 00:11:17.565 Launch: Begin container self-repair
2025-09-09 00:11:18.110 Launch: End container self-repair
2025-09-09 00:11:18.168 Status: Domoticz V2025.1 (build 16611) (c)2012-2025 GizMoCuz
2025-09-09 00:11:18.168 Status: Build Hash: 506720457, Date: 2025-04-03 16:12:32
2025-09-09 00:11:18.168 Status: Startup Path: /opt/domoticz/
2025-09-09 00:11:18.188 Sunrise: 06:08:00 SunSet: 19:07:00
2025-09-09 00:11:18.188 Day length: 13:00:00 Sun at south: 12:38:00
2025-09-09 00:11:18.188 Civil twilight start: 05:35:00 Civil twilight end: 19:40:00
2025-09-09 00:11:18.188 Nautical twilight start: 04:56:00 Nautical twilight end: 20:20:00
2025-09-09 00:11:18.188 Astronomical twilight start: 04:13:00 Astronomical twilight end: 21:02:00
2025-09-09 00:11:18.226 Status: PluginSystem: Started, Python version '3.9.2', 0 plugin definitions loaded.
2025-09-09 00:11:18.230 Active notification Subsystems: email, telegram (2/13)
2025-09-09 00:11:18.232 Status: WebServer(HTTP) started on address: :: with port 8080
2025-09-09 00:11:18.239 Status: WebServer(SSL) started on address: :: with port 443
2025-09-09 00:11:18.241 Status: Camera: settings (re)loaded
2025-09-09 00:11:18.242 Starting shared server on: :::6144
2025-09-09 00:11:18.242 Status: TCPServer: shared server started...
2025-09-09 00:11:18.244 Status: RxQueue: queue worker started...
2025-09-09 00:11:19.281 Status: [web:8080] Incoming connection from: 10.0.20.6
2025-09-09 00:11:20.209 Status: [web:8080] Incoming connection from: 10.0.20.129
2025-09-09 00:11:20.245 Status: NotificationSystem: thread started...
2025-09-09 00:11:20.246 Status: EventSystem: reset all events...
2025-09-09 00:11:20.250 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/CWU.lua
2025-09-09 00:11:20.250 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/przyciski rolet.lua
2025-09-09 00:11:20.251 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/deszczówka_average.lua
2025-09-09 00:11:20.251 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/timeKeeper-LampaGarderoba.lua
2025-09-09 00:11:20.252 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/timeKeeper-LampaPralnia.lua
2025-09-09 00:11:20.252 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/timeKeeper-LampaPiwnica.lua
2025-09-09 00:11:20.253 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/timeKeeper-LampaWiatrołap.lua
2025-09-09 00:11:20.254 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/timeKeeper-LampaHol.lua
2025-09-09 00:11:20.254 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/timeKeeper-LampaKorytarzDoPiwnicy.lua
2025-09-09 00:11:20.255 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/energy cost.lua
2025-09-09 00:11:20.256 Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/isHoliday.lua
2025-09-09 00:11:20.256 Status: EventSystem: reset all device statuses...
terminate called after throwing an instance of 'std::invalid_argument'
what(): stoull
2025-09-09 00:11:20.286 Error: Domoticz(pid:1, tid:33('MainWorker')) received fatal signal 6 (Aborted)
2025-09-09 00:11:20.286 Error: siginfo address=0x1, address=0x7fc55ba0ed51
2025-09-09 00:11:20.310 Error: Failed to start gdb, will use backtrace() for printing stack frame
2025-09-09 00:11:20.318 Error: #0 /opt/domoticz/domoticz : + 0x418a43 [0x555cfd191a43]
2025-09-09 00:11:20.318 Error: #1 /opt/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x29d [0x555cfd19252d]
2025-09-09 00:11:20.318 Error: #2 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x13140 [0x7fc55bd21140]
2025-09-09 00:11:20.318 Error: #3 /lib/x86_64-linux-gnu/libc.so.6 : gsignal + 0x141 [0x7fc55ba0ed51]
2025-09-09 00:11:20.318 Error: #4 /lib/x86_64-linux-gnu/libc.so.6 : abort + 0x123 [0x7fc55b9f8537]
2025-09-09 00:11:20.318 Error: #5 /opt/domoticz/domoticz : + 0x30a693 [0x555cfd083693]
2025-09-09 00:11:20.318 Error: #6 /opt/domoticz/domoticz : __cxxabiv1::__terminate(void (*)()) + 0x6 [0x555cfd912846]
2025-09-09 00:11:20.318 Error: #7 /opt/domoticz/domoticz : + 0xb998b1 [0x555cfd9128b1]
2025-09-09 00:11:20.318 Error: #8 /opt/domoticz/domoticz : + 0xb99a05 [0x555cfd912a05]
2025-09-09 00:11:20.318 Error: #9 /opt/domoticz/domoticz : std::__throw_invalid_argument(char const*) + 0x3d [0x555cfd085165]
2025-09-09 00:11:20.318 Error: #10 /opt/domoticz/domoticz : + 0x35a374 [0x555cfd0d3374]
2025-09-09 00:11:20.318 Error: #11 /opt/domoticz/domoticz : CEventSystem::GetCurrentStates() + 0xf00 [0x555cfd0f7ec0]
2025-09-09 00:11:20.318 Error: #12 /opt/domoticz/domoticz : CEventSystem::StartEventSystem() + 0x110 [0x555cfd0f8420]
2025-09-09 00:11:20.318 Error: #13 /opt/domoticz/domoticz : MainWorker::Do_Work() + 0x49c [0x555cfd15aa4c]
2025-09-09 00:11:20.318 Error: #14 /opt/domoticz/domoticz : + 0xc132f0 [0x555cfd98c2f0]
2025-09-09 00:11:20.319 Error: #15 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x7ea7 [0x7fc55bd15ea7]
2025-09-09 00:11:20.319 Error: #16 /lib/x86_64-linux-gnu/libc.so.6 : clone + 0x3f [0x7fc55bad1acf]
2025-09-09 00:11:20.319 Error: Domoticz(pid:1, tid:33('MainWorker')) received fatal signal 11 (Segmentation fault) while backtracing
2025-09-09 00:11:20.319 Error: siginfo address=(nil), address=0x7fc55b9f8602
2025-09-09 00:11:20.325 Error: #0 /opt/domoticz/domoticz : + 0x418a43 [0x555cfd191a43]
2025-09-09 00:11:20.325 Error: #1 /opt/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x280 [0x555cfd192510]
2025-09-09 00:11:20.325 Error: #2 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x13140 [0x7fc55bd21140]
2025-09-09 00:11:20.325 Error: #3 /lib/x86_64-linux-gnu/libc.so.6 : abort + 0x1ee [0x7fc55b9f8602]
2025-09-09 00:11:20.326 Error: #4 /opt/domoticz/domoticz : + 0x30a693 [0x555cfd083693]
2025-09-09 00:11:20.326 Error: #5 /opt/domoticz/domoticz : __cxxabiv1::__terminate(void (*)()) + 0x6 [0x555cfd912846]
2025-09-09 00:11:20.326 Error: #6 /opt/domoticz/domoticz : + 0xb998b1 [0x555cfd9128b1]
2025-09-09 00:11:20.326 Error: #7 /opt/domoticz/domoticz : + 0xb99a05 [0x555cfd912a05]
2025-09-09 00:11:20.326 Error: #8 /opt/domoticz/domoticz : std::__throw_invalid_argument(char const*) + 0x3d [0x555cfd085165]
2025-09-09 00:11:20.326 Error: #9 /opt/domoticz/domoticz : + 0x35a374 [0x555cfd0d3374]
2025-09-09 00:11:20.326 Error: #10 /opt/domoticz/domoticz : CEventSystem::GetCurrentStates() + 0xf00 [0x555cfd0f7ec0]
2025-09-09 00:11:20.326 Error: #11 /opt/domoticz/domoticz : CEventSystem::StartEventSystem() + 0x110 [0x555cfd0f8420]
2025-09-09 00:11:20.326 Error: #12 /opt/domoticz/domoticz : MainWorker::Do_Work() + 0x49c [0x555cfd15aa4c]
2025-09-09 00:11:20.326 Error: #13 /opt/domoticz/domoticz : + 0xc132f0 [0x555cfd98c2f0]
2025-09-09 00:11:20.326 Error: #14 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x7ea7 [0x7fc55bd15ea7]
2025-09-09 00:11:20.326 Error: #15 /lib/x86_64-linux-gnu/libc.so.6 : clone + 0x3f [0x7fc55bad1acf]
2025-09-09 00:11:20.326 Error: Domoticz(pid:1, tid:33('MainWorker')) received fatal signal 11 (Segmentation fault)
2025-09-09 00:11:20.327 Error: siginfo address=(nil), address=0x7fc55b9f8602
2025-09-09 00:11:20.347 Error: Failed to start gdb, will use backtrace() for printing stack frame
2025-09-09 00:11:20.351 Error: #0 /opt/domoticz/domoticz : + 0x418a43 [0x555cfd191a43]
2025-09-09 00:11:20.351 Error: #1 /opt/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x29d [0x555cfd19252d]
2025-09-09 00:11:20.351 Error: #2 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x13140 [0x7fc55bd21140]
2025-09-09 00:11:20.351 Error: #3 /lib/x86_64-linux-gnu/libc.so.6 : abort + 0x1ee [0x7fc55b9f8602]
2025-09-09 00:11:20.351 Error: #4 /opt/domoticz/domoticz : + 0x30a693 [0x555cfd083693]
2025-09-09 00:11:20.351 Error: #5 /opt/domoticz/domoticz : __cxxabiv1::__terminate(void (*)()) + 0x6 [0x555cfd912846]
2025-09-09 00:11:20.351 Error: #6 /opt/domoticz/domoticz : + 0xb998b1 [0x555cfd9128b1]
2025-09-09 00:11:20.351 Error: #7 /opt/domoticz/domoticz : + 0xb99a05 [0x555cfd912a05]
2025-09-09 00:11:20.351 Error: #8 /opt/domoticz/domoticz : std::__throw_invalid_argument(char const*) + 0x3d [0x555cfd085165]
2025-09-09 00:11:20.352 Error: #9 /opt/domoticz/domoticz : + 0x35a374 [0x555cfd0d3374]
2025-09-09 00:11:20.352 Error: #10 /opt/domoticz/domoticz : CEventSystem::GetCurrentStates() + 0xf00 [0x555cfd0f7ec0]
2025-09-09 00:11:20.352 Error: #11 /opt/domoticz/domoticz : CEventSystem::StartEventSystem() + 0x110 [0x555cfd0f8420]
2025-09-09 00:11:20.352 Error: #12 /opt/domoticz/domoticz : MainWorker::Do_Work() + 0x49c [0x555cfd15aa4c]
2025-09-09 00:11:20.352 Error: #13 /opt/domoticz/domoticz : + 0xc132f0 [0x555cfd98c2f0]
2025-09-09 00:11:20.352 Error: #14 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x7ea7 [0x7fc55bd15ea7]
2025-09-09 00:11:20.352 Error: #15 /lib/x86_64-linux-gnu/libc.so.6 : clone + 0x3f [0x7fc55bad1acf]
^C
voyo
Re: Domoticz crash when 'Dummy' is enabled
Post by voyo »
One more crash, I managed to disable all scripts (blockly etc), and data push to Influx.
And build Domoticz freshly from git.
$ git status
On branch development
Your branch is up to date with 'origin/development'.
$ git log
commit b67ec555ddb9fb968d2b4e41643301da4b47c4d8 (HEAD -> development, origin/development, origin/HEAD)
Author: GizMoCuz <[email protected]>
Date: Sun Aug 31 08:16:47 2025 +0200
Implemented: MQTT-AD, allow publishing messages
commit 3b2b01e39477e7bdd367a643bfa1c735635df6dc
Merge: 911a727e8 1fa1ef8ef
Author: KidDigital <[email protected]>
Date: Thu Aug 28 20:13:18 2025 +0200
Merge pull request #6379 from kiddigital/fix/compilewarningenphase
Fix Linux compile warnings EnphaseAPI
Interesting fact is, that when I start Domoticz (with Dummy hardware disabled) , then I enable it in UI - it works (until restart).
And devices based on Dummy - works, can be updated etc.
But when Domoticz is (re)started with Dummy enabled - it crashed miserably... so this is something what is affecting only during initilization.
voyo@swarog:~/domoticz.git$ ./domoticz -loglevel normal,status,error,debug -debuglevel normal,hardware,received,webserver,eventsystem,python,thread_id
2025-09-09 02:14:09.806 [7f3ff0e21e00] Status: Domoticz V2025.1 (build 16776) (c)2012-2025 GizMoCuz
2025-09-09 02:14:09.806 [7f3ff0e21e00] Status: Build Hash: b67ec555d, Date: 2025-08-31 08:16:47
2025-09-09 02:14:09.806 [7f3ff0e21e00] Status: Startup Path: /home/voyo/domoticz.git/
2025-09-09 02:14:09.839 [7f3ff0e21e00] Sunrise: 06:08:00 SunSet: 19:07:00
2025-09-09 02:14:09.839 [7f3ff0e21e00] Day length: 13:00:00 Sun at south: 12:38:00
2025-09-09 02:14:09.839 [7f3ff0e21e00] Civil twilight start: 05:35:00 Civil twilight end: 19:40:00
2025-09-09 02:14:09.839 [7f3ff0e21e00] Nautical twilight start: 04:56:00 Nautical twilight end: 20:20:00
2025-09-09 02:14:09.839 [7f3ff0e21e00] Astronomical twilight start: 04:13:00 Astronomical twilight end: 21:02:00
2025-09-09 02:14:09.914 [7f3ff0e21e00] Status: PluginSystem: Started, Python version '3.11.2', 1 plugin definitions loaded.
2025-09-09 02:14:09.926 [7f3ff0e21e00] Active notification Subsystems: (0/13)
2025-09-09 02:14:09.927 [7f3ff0e21e00] Debug: CWebServer::StartServer() : settings : 'server_settings[is_secure_=false, www_root='/home/voyo/domoticz.git/www', listening_address='::', listening_port='8080', vhostname='', php_cgi_path='']'
2025-09-09 02:14:09.929 [7f3ff0e21e00] Status: WebServer(HTTP) started on address: :: with port 8080
2025-09-09 02:14:09.932 [7f3ff0e21e00] Debug: [web:8080] Adding IPv4 network (127.0.0.*) to list of trusted networks.
2025-09-09 02:14:09.933 [7f3ff0e21e00] Debug: [web:8080] Adding IPv4 network (10.0.20.*) to list of trusted networks.
2025-09-09 02:14:09.933 [7f3ff0e21e00] Debug: [web:8080] Adding IPv4 network (172.16.0.*) to list of trusted networks.
2025-09-09 02:14:09.933 [7f3ff0e21e00] Debug: [web:8080] Adding IPv4 network (172.17.0.*) to list of trusted networks.
2025-09-09 02:14:09.933 [7f3ff0e21e00] Debug: [web:8080] Adding IPv4 network (10.0.21.*) to list of trusted networks.
2025-09-09 02:14:09.934 [7f3ff0e21e00] Debug: WebServer(HTTP) started with 245 Registered Commands
2025-09-09 02:14:09.934 [7f3ff0e21e00] Debug: cWebEm Registration: 10 pages, 9 actions, 4 whitelist urls, 11 whitelist commands
2025-09-09 02:14:09.936 [7f3ff0e21e00] Debug: CWebServer::StartServer() : settings : ssl_server_settings['server_settings[is_secure_=true, www_root='/home/voyo/domoticz.git/www', listening_address='::', listening_port='443', vhostname='', php_cgi_path='']', ssl_method='tls', certificate_chain_file_path='./server_cert.pem', ca_cert_file_path='./server_cert.pem', cert_file_path=./server_cert.pem', private_key_file_path='./server_cert.pem', private_key_pass_phrase='', ssl_options='single_dh_use', tmp_dh_file_path='./server_cert.pem', verify_peer=false, verify_fail_if_no_peer_cert=false, verify_file_path='']
2025-09-09 02:14:09.940 [7f3fed5fc6c0] Debug: [web:8080] Host:10.0.20.129 Uri:/json.htm?type=command&param=udevice&idx=1804&nvalue=0&svalue=0.00;11744.00;0.00&rssi=5
2025-09-09 02:14:09.940 [7f3fed5fc6c0] Debug: [web:8080] Request Headers:
Host: domoticz.castle.conserit.pl:8080
User-Agent: ESP Easy/20669/Nov 30 2023 19:13:53
Connection: close
Accept-Encoding: identity;q=1,chunked;q=0.1,*;q=0
2025-09-09 02:14:09.941 [7f3fed5fc6c0] Debug: [web:8080] IP (10.0.20.129) is within Trusted network range!
2025-09-09 02:14:09.941 [7f3fed5fc6c0] Debug: CWebServer::GetJSonPage: udevice : /json.htm?type=command&param=udevice&idx=1804&nvalue=0&svalue=0.00;11744.00;0.00&rssi=5
2025-09-09 02:14:09.944 [7f3fed5fc6c0] Debug: SQLH UpdateValueInt Woda HwID:3 DevID:83804 Type:243 sType:28 nValue:0 sValue:0.00;11744.00;0.00 IDX: 1804
2025-09-09 02:14:09.945 [7f3fed5fc6c0] Status: [web:8080] Incoming connection from: 10.0.20.129
2025-09-09 02:14:09.946 [7f3fed5fc6c0] Debug: Web ACLF: 10.0.20.129 - - [09/Sep/2025:02:14:09.940 +0200] "GET /json.htm?type=command&param=udevice&idx=1804&nvalue=0&svalue=0.00;11744.00;0.00&rssi=5 HTTP/1.1" 200 49 - "ESP Easy/20669/Nov 30 2023 19:13:53"
2025-09-09 02:14:09.946 [7f3ff0e21e00] Debug: [web:443] Enabled ciphers (TLSv1.2) ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
2025-09-09 02:14:09.952 [7f3ff0e21e00] Debug: [web:443] 'DH PARAMETERS' found in file ./server_cert.pem
2025-09-09 02:14:09.954 [7f3ff0e21e00] Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied, trying ::
2025-09-09 02:14:09.955 [7f3ff0e21e00] Debug: [web:443] Enabled ciphers (TLSv1.2) ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
2025-09-09 02:14:09.958 [7f3ff0e21e00] Debug: [web:443] 'DH PARAMETERS' found in file ./server_cert.pem
2025-09-09 02:14:09.958 [7f3ff0e21e00] Status: WebServer(SSL) startup failed on address :: with port: 443: bind: Permission denied, trying 0.0.0.0
2025-09-09 02:14:09.959 [7f3ff0e21e00] Debug: [web:443] Enabled ciphers (TLSv1.2) ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
2025-09-09 02:14:09.962 [7f3ff0e21e00] Debug: [web:443] 'DH PARAMETERS' found in file ./server_cert.pem
2025-09-09 02:14:09.962 [7f3ff0e21e00] Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2025-09-09 02:14:09.962 [7f3ff0e21e00] Error: WebServer(SSL) check privileges for opening ports below 1024
2025-09-09 02:14:09.963 [7f3ff0e21e00] Status: Camera: settings (re)loaded
2025-09-09 02:14:09.964 [7f3ff0e21e00] Starting shared server on: :::6144
2025-09-09 02:14:09.965 [7f3fe7fff6c0] Status: TCPServer: shared server started...
2025-09-09 02:14:09.965 [7f3ff0e21e00] Status: mDNS: Service started
2025-09-09 02:14:09.967 [7f3fe67fc6c0] Status: RxQueue: queue worker started...
2025-09-09 02:14:09.967 [7f3fe77fe6c0] Debug: mDNS: Local IPv4 address: 0.0.0.0
2025-09-09 02:14:09.967 [7f3fe77fe6c0] Debug: mDNS: Local IPv6 address: ::
2025-09-09 02:14:09.968 [7f3fe77fe6c0] mDNS: Service: _http._tcp.local.:443 for Hostname: włosań (2 sockets)
2025-09-09 02:14:09.968 [7f3fe77fe6c0] Debug: mDNS: Sending mDNS announce
2025-09-09 02:14:10.121 [7f3fed5fc6c0] Debug: [web:8080] Host:10.0.20.69 Uri:/json
2025-09-09 02:14:10.121 [7f3fed5fc6c0] Debug: [web:8080] Request Headers:
Host: 10.0.20.6:8080
Connection: Upgrade
Pragma: no-cache
Cache-Control: no-cache
Upgrade: websocket
Origin: http://10.0.20.6:8080
Sec-WebSocket-Version: 13
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/140.0.0.0 Safari/537.36
Accept-Encoding: gzip, deflate
Accept-Language: en-US,en;q=0.9,pl;q=0.8
Cookie: grafana_session=5f3d4056db89daca1edbffcd2ebf97fe; grafana_session_expiry=1757377332
Sec-GPC: 1
Sec-WebSocket-Key: isjfV0cieKUC1MgBOecclQ==
Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits
Sec-WebSocket-Protocol: domoticz
2025-09-09 02:14:10.121 [7f3fed5fc6c0] Debug: [web:8080] IP (10.0.20.69) is within Trusted network range!
2025-09-09 02:14:10.122 [7f3fed5fc6c0] Debug: Web ACLF: 10.0.20.69 - - [09/Sep/2025:02:14:10.121 +0200] "GET /json HTTP/1.1" 101 0 - "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/140.0.0.0 Safari/537.36"
2025-09-09 02:14:10.136 [7f3fed5fc6c0] Debug: [web:8080] Host:10.0.20.69 Uri:/json
2025-09-09 02:14:10.136 [7f3fed5fc6c0] Debug: [web:8080] Request Headers:
Connection: Upgrade
Pragma: no-cache
Upgrade: websocket
Sec-GPC: 1
Sec-WebSocket-Key: aC8Ka6SNfaEDGYaF6CZmuQ==
2025-09-09 02:14:10.136 [7f3fed5fc6c0] Debug: [web:8080] IP (10.0.20.69) is within Trusted network range!
2025-09-09 02:14:10.137 [7f3fed5fc6c0] Debug: Web ACLF: 10.0.20.69 - - [09/Sep/2025:02:14:10.136 +0200] "GET /json HTTP/1.1" 101 0 - "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/140.0.0.0 Safari/537.36"
2025-09-09 02:14:10.459 [7f3fed5fc6c0] Debug: [web:8080] Host:10.0.20.6 Uri:/
2025-09-09 02:14:10.459 [7f3fed5fc6c0] Debug: [web:8080] Request Headers:
User-Agent: Monit/5.33.0
Accept: */*
Connection: close
2025-09-09 02:14:10.459 [7f3fed5fc6c0] Debug: [web:8080] IP (10.0.20.6) is within Trusted network range!
2025-09-09 02:14:10.460 [7f3fed5fc6c0] Debug: [web:/] modified to (/home/voyo/domoticz.git/www/index.html).
2025-09-09 02:14:10.463 [7f3fed5fc6c0] Status: [web:8080] Incoming connection from: 10.0.20.6
2025-09-09 02:14:10.463 [7f3fed5fc6c0] Debug: Web ACLF: 10.0.20.6 - - [09/Sep/2025:02:14:10.459 +0200] "GET / HTTP/1.1" 200 75754 - "Monit/5.33.0"
2025-09-09 02:14:11.968 [7f3fd7fff6c0] Status: NotificationSystem: thread started...
2025-09-09 02:14:11.969 [7f3fe6ffd6c0] Status: EventSystem: reset all events...
2025-09-09 02:14:11.970 [7f3fe6ffd6c0] Debug: EventSystem: Events (re)loaded
2025-09-09 02:14:11.970 [7f3fe6ffd6c0] Status: EventSystem: reset all device statuses...
what(): stoull
2025-09-09 02:14:12.011 [7f3fe6ffd6c0] Error: Domoticz(pid:1268, tid:1278('MainWorker')) received fatal signal 6 (Aborted)
2025-09-09 02:14:12.011 [7f3fe6ffd6c0] Error: siginfo address=0x3e8000004f4, address=0x7f3ff1aa9eec
2025-09-09 02:14:13.344 [7f3fe6ffd6c0] Error: Did not find stack frame for thread (LWP 1278)), printing full gdb output:
2025-09-09 02:14:13.344 [7f3fe6ffd6c0] Error: > [New LWP 1269]
2025-09-09 02:14:13.344 [7f3fe6ffd6c0] Error: > [New LWP 1270]
2025-09-09 02:14:13.344 [7f3fe6ffd6c0] Error: > [New LWP 1271]
2025-09-09 02:14:13.344 [7f3fe6ffd6c0] Error: > [New LWP 1272]
2025-09-09 02:14:13.344 [7f3fe6ffd6c0] Error: > [New LWP 1273]
2025-09-09 02:14:13.344 [7f3fe6ffd6c0] Error: > [New LWP 1274]
2025-09-09 02:14:13.344 [7f3fe6ffd6c0] Error: > [New LWP 1275]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [New LWP 1276]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [New LWP 1277]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [New LWP 1278]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [New LWP 1279]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [New LWP 1280]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [New LWP 1281]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [New LWP 1282]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [New LWP 1283]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [New LWP 1293]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > [Thread debugging using libthread_db enabled]
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 0x00007f3ff1aee545 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7ffdd03ccc50, rem=0x7ffdd03ccc50) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:48
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 48 ../sysdeps/unix/sysv/linux/clock_nanosleep.c: No such file or directory.
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > Id Target Id Frame
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > * 1 Thread 0x7f3ff0e21e00 (LWP 1268) "domoticz" 0x00007f3ff1aee545 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7ffdd03ccc50, rem=0x7ffdd03ccc50) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:48
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 2 Thread 0x7f3ff05ff6c0 (LWP 1269) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 3 Thread 0x7f3fefdfe6c0 (LWP 1270) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 4 Thread 0x7f3feedff6c0 (LWP 1271) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 5 Thread 0x7f3fee5fe6c0 (LWP 1272) "MQTTPush" syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 6 Thread 0x7f3feddfd6c0 (LWP 1273) "Webem_ssncleane" 0x00007f3ff1b27ee6 in epoll_wait (epfd=13, events=0x7f3feddfc4c0, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 7 Thread 0x7f3fed5fc6c0 (LWP 1274) "WebServer_8080" 0x00007f3ff1b27ee6 in epoll_wait (epfd=9, events=0x7f3fed5fb500, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 8 Thread 0x7f3fecdfb6c0 (LWP 1275) "Scheduler" syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 9 Thread 0x7f3fe7fff6c0 (LWP 1276) "TCPServer" 0x00007f3ff1b27ee6 in epoll_wait (epfd=16, events=0x7f3fe7ffe530, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 10 Thread 0x7f3fe77fe6c0 (LWP 1277) "mDnsWorker" 0x00007f3ff1b1d99c in __GI___select (nfds=21, readfds=0x7f3fe77fd8f0, writefds=0x0, exceptfds=0x0, timeout=0x7f3fe77fd820) at ../sysdeps/unix/sysv/linux/select.c:69
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 11 Thread 0x7f3fe6ffd6c0 (LWP 1278) "MainWorker" 0x00007f3ff1af2c17 in __GI___wait4 (pid=1284, stat_loc=0x7f3fe6ffb7e4, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:30
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 12 Thread 0x7f3fe67fc6c0 (LWP 1279) "MainWorkerRxMsg" __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x7f3fe67fbbb0, op=137, expected=0, futex_word=0x558ec758d3e8 <m_mainworker+6184>) at ./nptl/futex-internal.c:57
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 13 Thread 0x7f3fe5ffb6c0 (LWP 1280) "Watchdog" 0x00007f3ff1aee545 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7f3fe5ffac20, rem=0x7f3fe5ffac20) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:48
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 14 Thread 0x7f3fe57fa6c0 (LWP 1281) "WebServer_8080" syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 15 Thread 0x7f3fe4ff96c0 (LWP 1282) "WebServer_8080" syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.345 [7f3fe6ffd6c0] Error: > 16 Thread 0x7f3fd7fff6c0 (LWP 1283) "NotificationSys" __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x7f3fd7ffec00, op=137, expected=0, futex_word=0x558ec758cb3c <m_mainworker+3964>) at ./nptl/futex-internal.c:57
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > 17 Thread 0x7f3fd77fe6c0 (LWP 1293) "Plugin_ASIO" __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0, futex_word=0x558ec8887438) at ./nptl/futex-internal.c:57
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > Thread 17 (Thread 0x7f3fd77fe6c0 (LWP 1293) "Plugin_ASIO"):
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #0 __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x0, op=393, expected=0, futex_word=0x558ec8887438) at ./nptl/futex-internal.c:57
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x558ec8887438, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0, cancel=cancel@entry=true) at ./nptl/futex-internal.c:87
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #2 0x00007f3ff1aa4f7b in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x558ec8887438, expected=expected@entry=0, clockid=clockid@entry=0, abstime=abstime@entry=0x0, private=private@entry=0) at ./nptl/futex-internal.c:139
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #3 0x00007f3ff1aa75d8 in __pthread_cond_wait_common (abstime=0x0, clockid=0, mutex=0x558ec88873d8, cond=0x558ec8887410) at ./nptl/pthread_cond_wait.c:503
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #4 ___pthread_cond_wait (cond=0x558ec8887410, mutex=0x558ec88873d8) at ./nptl/pthread_cond_wait.c:618
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #5 0x0000558ec7121c24 in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #6 0x0000558ec71220d1 in Plugins::BoostWorkers() ()
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #7 0x0000558ec7252a57 in thread_proxy ()
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #8 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #9 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > Thread 16 (Thread 0x7f3fd7fff6c0 (LWP 1283) "NotificationSys"):
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #0 __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x7f3fd7ffec00, op=137, expected=0, futex_word=0x558ec758cb3c <m_mainworker+3964>) at ./nptl/futex-internal.c:57
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x558ec758cb3c <m_mainworker+3964>, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7f3fd7ffec00, private=private@entry=0, cancel=cancel@entry=true) at ./nptl/futex-internal.c:87
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #2 0x00007f3ff1aa4f7b in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x558ec758cb3c <m_mainworker+3964>, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7f3fd7ffec00, private=private@entry=0) at ./nptl/futex-internal.c:139
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #3 0x00007f3ff1aa7baf in __pthread_cond_wait_common (abstime=<optimized out>, clockid=1, mutex=0x558ec758cae8 <m_mainworker+3880>, cond=0x558ec758cb10 <m_mainworker+3920>) at ./nptl/pthread_cond_wait.c:503
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #4 ___pthread_cond_clockwait64 (abstime=<optimized out>, clockid=1, mutex=0x558ec758cae8 <m_mainworker+3880>, cond=0x558ec758cb10 <m_mainworker+3920>) at ./nptl/pthread_cond_wait.c:682
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #5 ___pthread_cond_clockwait64 (cond=0x558ec758cb10 <m_mainworker+3920>, mutex=0x558ec758cae8 <m_mainworker+3880>, clockid=1, abstime=<optimized out>) at ./nptl/pthread_cond_wait.c:670
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #6 0x0000558ec6c2a631 in CNotificationSystem::QueueThread() ()
2025-09-09 02:14:13.346 [7f3fe6ffd6c0] Error: > #7 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: >
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > Thread 15 (Thread 0x7f3fe4ff96c0 (LWP 1282) "WebServer_8080"):
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #1 0x0000558ec72d60f6 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #2 0x0000558ec7201797 in http::server::CWebsocketHandler::Do_Work() ()
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #3 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #4 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #5 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > Thread 14 (Thread 0x7f3fe57fa6c0 (LWP 1281) "WebServer_8080"):
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > Thread 13 (Thread 0x7f3fe5ffb6c0 (LWP 1280) "Watchdog"):
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #0 0x00007f3ff1aee545 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7f3fe5ffac20, rem=0x7f3fe5ffac20) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:48
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #1 0x00007f3ff1af2e53 in __GI___nanosleep (req=<optimized out>, rem=<optimized out>) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #2 0x0000558ec6bc6fed in sleep_milliseconds(long) ()
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #3 0x0000558ec6c47db6 in Do_Watchdog_Work() ()
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #4 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #5 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.347 [7f3fe6ffd6c0] Error: > #6 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: >
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > Thread 12 (Thread 0x7f3fe67fc6c0 (LWP 1279) "MainWorkerRxMsg"):
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #0 __futex_abstimed_wait_common64 (private=0, cancel=true, abstime=0x7f3fe67fbbb0, op=137, expected=0, futex_word=0x558ec758d3e8 <m_mainworker+6184>) at ./nptl/futex-internal.c:57
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #1 __futex_abstimed_wait_common (futex_word=futex_word@entry=0x558ec758d3e8 <m_mainworker+6184>, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7f3fe67fbbb0, private=private@entry=0, cancel=cancel@entry=true) at ./nptl/futex-internal.c:87
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #2 0x00007f3ff1aa4f7b in __GI___futex_abstimed_wait_cancelable64 (futex_word=futex_word@entry=0x558ec758d3e8 <m_mainworker+6184>, expected=expected@entry=0, clockid=clockid@entry=1, abstime=abstime@entry=0x7f3fe67fbbb0, private=private@entry=0) at ./nptl/futex-internal.c:139
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #3 0x00007f3ff1aa7baf in __pthread_cond_wait_common (abstime=<optimized out>, clockid=1, mutex=0x558ec758d398 <m_mainworker+6104>, cond=0x558ec758d3c0 <m_mainworker+6144>) at ./nptl/pthread_cond_wait.c:503
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #4 ___pthread_cond_clockwait64 (abstime=<optimized out>, clockid=1, mutex=0x558ec758d398 <m_mainworker+6104>, cond=0x558ec758d3c0 <m_mainworker+6144>) at ./nptl/pthread_cond_wait.c:682
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #5 ___pthread_cond_clockwait64 (cond=0x558ec758d3c0 <m_mainworker+6144>, mutex=0x558ec758d398 <m_mainworker+6104>, clockid=1, abstime=<optimized out>) at ./nptl/pthread_cond_wait.c:670
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #6 0x0000558ec6c14257 in MainWorker::Do_Work_On_Rx_Messages() ()
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #7 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #8 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #9 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > Thread 11 (Thread 0x7f3fe6ffd6c0 (LWP 1278) "MainWorker"):
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #0 0x00007f3ff1af2c17 in __GI___wait4 (pid=1284, stat_loc=0x7f3fe6ffb7e4, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:30
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #1 0x0000558ec6c47605 in dumpstack_gdb(bool) ()
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #2 0x0000558ec6c47c15 in signal_handler(int, siginfo_t*, void*) ()
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #3 <signal handler called>
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #4 __pthread_kill_implementation (threadid=<optimized out>, signo=signo@entry=6, no_tid=no_tid@entry=0) at ./nptl/pthread_kill.c:44
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #5 0x00007f3ff1aa9f4f in __pthread_kill_internal (signo=6, threadid=<optimized out>) at ./nptl/pthread_kill.c:78
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #6 0x00007f3ff1a5afb2 in __GI_raise (sig=sig@entry=6) at ../sysdeps/posix/raise.c:26
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #7 0x00007f3ff1a45472 in __GI_abort () at ./stdlib/abort.c:79
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #8 0x0000558ec6b468f2 in __gnu_cxx::__verbose_terminate_handler() [clone .cold] ()
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #9 0x0000558ec72874ca in __cxxabiv1::__terminate(void (*)()) ()
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #10 0x0000558ec7287535 in std::terminate() ()
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #11 0x0000558ec7287688 in __cxa_throw ()
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #12 0x0000558ec6b48399 in std::__throw_invalid_argument(char const*) ()
2025-09-09 02:14:13.348 [7f3fe6ffd6c0] Error: > #13 0x0000558ec6b8e294 in unsigned long long __gnu_cxx::__stoa<unsigned long long, unsigned long long, char, int>(unsigned long long (*)(char const*, char**, int), char const*, char const*, unsigned long*, int) [clone .constprop.0] ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #14 0x0000558ec6bb1af0 in CEventSystem::GetCurrentStates() ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #15 0x0000558ec6bb20c0 in CEventSystem::StartEventSystem() ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #16 0x0000558ec6c127ad in MainWorker::Do_Work() ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #17 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #18 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #19 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > Thread 10 (Thread 0x7f3fe77fe6c0 (LWP 1277) "mDnsWorker"):
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #0 0x00007f3ff1b1d99c in __GI___select (nfds=21, readfds=0x7f3fe77fd8f0, writefds=0x0, exceptfds=0x0, timeout=0x7f3fe77fd820) at ../sysdeps/unix/sysv/linux/select.c:69
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #1 0x0000558ec6d60d14 in domoticz_mdns::mDNS::mDnsMainLoop() ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #2 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #3 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #4 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > Thread 9 (Thread 0x7f3fe7fff6c0 (LWP 1276) "TCPServer"):
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #0 0x00007f3ff1b27ee6 in epoll_wait (epfd=16, events=0x7f3fe7ffe530, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #1 0x0000558ec6dd7016 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #2 0x0000558ec71a3cae in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #3 0x0000558ec71a42f0 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<tcp::server::CTCPServer::StartServer(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#1}> > >::_M_run() ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #4 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #5 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #6 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > Thread 8 (Thread 0x7f3fecdfb6c0 (LWP 1275) "Scheduler"):
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.349 [7f3fe6ffd6c0] Error: > #1 0x0000558ec72d60f6 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #2 0x0000558ec6c3c5cf in CScheduler::Do_Work() ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #3 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #4 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #5 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > Thread 7 (Thread 0x7f3fed5fc6c0 (LWP 1274) "WebServer_8080"):
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #0 0x00007f3ff1b27ee6 in epoll_wait (epfd=9, events=0x7f3fed5fb500, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #1 0x0000558ec6dd7016 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #2 0x0000558ec71f30ce in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #3 0x0000558ec71f86ce in http::server::server_base::run() ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #4 0x0000558ec6ca1268 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#265}> > >::_M_run() ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #5 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #6 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #7 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > Thread 6 (Thread 0x7f3feddfd6c0 (LWP 1273) "Webem_ssncleane"):
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #0 0x00007f3ff1b27ee6 in epoll_wait (epfd=13, events=0x7f3feddfc4c0, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #2 0x0000558ec71c6a21 in boost::asio::detail::scheduler::run(boost::system::error_code&) [clone .isra.0] ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #3 0x0000558ec71c7252 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #4 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #5 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #6 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > Thread 5 (Thread 0x7f3fee5fe6c0 (LWP 1272) "MQTTPush"):
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #1 0x0000558ec72d60f6 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #2 0x0000558ec6d83226 in CMQTTPush::Do_Work() ()
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > Thread 4 (Thread 0x7f3feedff6c0 (LWP 1271) "InfluxPush"):
2025-09-09 02:14:13.350 [7f3fe6ffd6c0] Error: > #2 0x0000558ec6d7e37e in CInfluxPush::Do_Work() ()
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > Thread 3 (Thread 0x7f3fefdfe6c0 (LWP 1270) "PluginMgr"):
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #0 syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #1 0x0000558ec72d60f6 in std::__atomic_futex_unsigned_base::_M_futex_wait_until_steady(unsigned int*, unsigned int, bool, std::chrono::duration<long, std::ratio<1l, 1l> >, std::chrono::duration<long, std::ratio<1l, 1000000000l> >) ()
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #2 0x0000558ec71226f6 in Plugins::CPluginSystem::Do_Work() ()
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #3 0x0000558ec7308373 in execute_native_thread_routine ()
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #4 0x00007f3ff1aa81f5 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #5 0x00007f3ff1b2889c in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > Thread 2 (Thread 0x7f3ff05ff6c0 (LWP 1269) "SQLHelper"):
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #2 0x0000558ec6c6576c in CSQLHelper::Do_Work() ()
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > Thread 1 (Thread 0x7f3ff0e21e00 (LWP 1268) "domoticz"):
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #0 0x00007f3ff1aee545 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7ffdd03ccc50, rem=0x7ffdd03ccc50) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:48
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #1 0x00007f3ff1af2e53 in __GI___nanosleep (req=<optimized out>, rem=<optimized out>) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #2 0x0000558ec6bc6f75 in sleep_seconds(long) ()
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > #3 0x0000558ec6b49510 in main ()
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > Main thread:
2025-09-09 02:14:13.351 [7f3fe6ffd6c0] Error: > [Inferior 1 (process 1268) detached]
Aborted
Domoticz version: 2025.1
Did you check the troubleshooting Wiki? Check the database for inconsistencies? https://wiki.domoticz.com/Troubleshooting
voyo
Post by voyo »
waltervl wrote:Did you check the troubleshooting Wiki? Check the database for inconsistencies? https://wiki.domoticz.com/Troubleshooting
Yes, I explained all my troubleshooting in 1st post. I followed official domoticz wiki for troubleshooting.
Wysłane z mojego SM-S911B przy użyciu Tapatalka
voyo
Post by voyo »
Hey everyone,
Just wanted to post an update on the Domoticz crash I was dealing with and ask the devs to fix this properly.
What was wrong: My Domoticz (V2025.1, build 16611, also tested with 16776 from git development) kept crashing on startup when Dummy hardware was enabled. The logs showed a std::invalid_argument from stoull in CEventSystem::GetCurrentStates()—basically, it was choking while loading device states.
After hours of digging, I found the problem: a Dummy device (ID 1922, "Energy cost", Type 243, SubType 28 - Counter Incremental) had an sValue of "Inf". That’s not a number, and Domoticz couldn’t handle it since it expects a numeric value (like "123" or "123;456") for this device type.
SELECT * FROM DeviceStatus WHERE ID = 1922;
Output:
ID|HardwareID|DeviceID|Unit|Name|Used|Type|SubType|SwitchType|Favorite|SignalLevel|BatteryLevel|nValue|sValue|LastUpdate|Order|AddjValue|AddjMulti|AddjValue2|AddjMulti2|StrParam1|StrParam2|LastLevel|Protected|CustomImage|Description|Options|Color|OrgHardwareID
1922|3|83922|1|Energy cost|1|243|28|3|1|12|255|0|Inf|2025-09-08 22:55:00|1922|0.0|1.0|0.0|1.0|||0|0|0||ValueQuantity:UExO;ValueUnits:UExO||0
Simply fix was (however it took me hours on investigation...)
UPDATE DeviceStatus SET sValue = '0' WHERE ID = 1922;
This stopped the crashes, and Domoticz now starts fine with Dummy enabled.
I’m pretty sure a dzVents script (energy cost.lua) set this bad "Inf" value, maybe from something like math.huge , not sure.
Please fix this. Domoticz needs to be tougher about bad data. Two things:
Check inputs: Don’t let scripts, plugins, or external devices (like via API) write junk values to sValue that don’t match the device type. A quick check before saving to the database would catch this.
Don’t crash: When loading device states, Domoticz should skip or log bad data instead of crashing hard on a stoull error. This would keep things running even if a script messes up.
Big thanks to the Domoticz team for all the work, but I dont have time to dig into the C++ code and make a pull request myself. The logs and SQL I shared should be enough to track this down. Can you guys please make Domoticz more robust so we don’t get burned by bad database values?
Calling @gizmocuz here.
Cheers, Voyo
gizmocuz
Post by gizmocuz »
Thanks for reporting!
In beta version 16781 this exception is now handled.
if people/scripts are storing invalid data anything can happen. (not only by Domoticz, try messing with the Registry in Windows, or config files in /etc under unix)
Users browsing this forum: Dave21w and 1 guest
