Moderators: leecollings , remb0
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
azonneveld
Posts: 179 Joined: Wednesday 02 October 2019 7:37
Domoticz version: 2024.4
Post
by azonneveld » Thursday 04 September 2025 12:14
Has this something to do with anti-ddos on this site?
Here's the output from the install:
sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Checking for libssl1.1... installed!
::: Checking for libcurl4... installed!
::: Checking for libusb-0.1... installed!
::: Downloading Domoticz
::: Current User: pi
HTTP Port: 8088
::: Destination folder=/home/pi/domoticz
--2025-09-04 12:09:56-- http://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l
Resolving www.domoticz.com (www.domoticz.com)... 104.21.112.1, 104.21.80.1, 104.21.48.1, ...
Connecting to www.domoticz.com (www.domoticz.com)|104.21.112.1|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l [following]
--2025-09-04 12:09:56-- https://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l
Connecting to www.domoticz.com (www.domoticz.com)|104.21.112.1|:443... connected.
HTTP request sent, awaiting response... 403 Forbidden
2025-09-04 12:09:56 ERROR 403: Forbidden.
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
RNEE
Posts: 55 Joined: Sunday 05 August 2018 10:13
Domoticz version: 2025.1
Post
by RNEE » Thursday 04 September 2025 15:12
trying to install fresh on Ubuntu 24.04.3 LTS (for testing) (not Docker)
Same errors.
(and a lot more about libssl1.1 with where solved after reading the forum)
same as
viewtopic.php?t=43892
and
viewtopic.php?f=47&t=43029
Domoticz on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek Homebattery 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|
azonneveld
Post
by azonneveld » Thursday 04 September 2025 16:40
Installed manually.
This topic can be closed.
Posts: 6678 Joined: Monday 28 January 2019 18:48
Post
by waltervl » Thursday 04 September 2025 17:16
Install/update should be working now, ddos protection is switched off for the download section of Domoticz.com
