RTL_433
qqlapraline
RTL_433
Post by qqlapraline »
Hello everyone,
I have tried using RTL_433 with a popular (and cheap :)) OEM weather station: Sainlogic FT0300.
RTL_433 is retrieving all the necessary sensors data (Temp, Humidity, Wind speed and direction, rain, UV and Light) with the latest version of the tool.
Unfortunately, Domoticz is not able to retrieve the UV value.
It seems that the code is not consistent.
Here is how RTL_433 is sending back information in
cotech_36_7959.c
    data = data_make(
            "model",            "",                 DATA_STRING, "Cotech-367959",
            //"subtype",          "Type code",        DATA_INT, subtype,
            "id",               "ID",               DATA_INT,    id,
            "battery_ok",       "Battery",          DATA_INT,    !batt_low,
            "temperature_F",    "Temperature",      DATA_FORMAT, "%.1f F", DATA_DOUBLE, temp_c,
            "humidity",         "Humidity",         DATA_FORMAT, "%u %%", DATA_INT, humidity,
            "rain_mm",          "Rain",             DATA_FORMAT, "%.1f mm", DATA_DOUBLE, rain * 0.1f,
            "wind_dir_deg",     "Wind direction",   DATA_INT,    wind_dir,
            "wind_avg_m_s",     "Wind",             DATA_FORMAT, "%.1f m/s", DATA_DOUBLE, wind * 0.1f,
            "wind_max_m_s",     "Gust",             DATA_FORMAT, "%.1f m/s", DATA_DOUBLE, gust * 0.1f,
            "light_lux",        "Light Intensity",  DATA_COND, light_is_valid, DATA_FORMAT, "%u lux", DATA_INT, light_lux,
            "uvi",              "UV Index",         DATA_COND, light_is_valid, DATA_FORMAT, "%.1f", DATA_DOUBLE, uvi * 0.1f,
            "mic",              "Integrity",        DATA_STRING, "CRC",
            NULL);
And here is how Domoticz is parsing it in
Rtl433.cpp
	if (FindField(data, "uv"))
		uvi = (float)atof(data["uv"].c_str());
		haveUV = true;
Obviously, when it refers to UV Index, these two guys are not talking the same language :)
On my side, I have fixed it by adjusting the rtl_433 source on my device (I know, it's bad :)). But the best way is probably to adjust it on Domoticz side.
Have a good day,
QQ.
3 Raspberry PI (Raspbian + Rfxcom, teleinfo or mysensors gateway)
Bunch of OS THGR810n (5)
Some THN122
1 WGR800 and PCR800
Some BMP085
Bunch of TS34C (4)
Bunch of DIO plugs (3)
Teleinfo
Many Mysensors devices (Temp, Hygro, ...)
Re: RTL_433
The best way is that you create a Pull Request on the Domoticz source code repository so everyone can enjoy the UV index value... :D
https://github.com/domoticz/domoticz?ta ... ixing-bugs
FlyingDomotic
Re: RTL_433
Post by FlyingDomotic »
I'm using UV index for a while, but sending only integer value from 0 to 9 (or 10, I don't remind highest value)
IanDury
Re: RTL_433
Post by IanDury »
Reported as issue https://github.com/domoticz/domoticz/issues/6534 and has been fixed.
