Removing the old API (json.htm?type=devices with rid) in version 2025.1 has completely broken my setup.
I’ve been using Domoticz for years to automate solar panels, irrigation, and lighting — all controlled through Python scripts using the old API. After the update, none of it works anymore.
How can I download and install an older version of Domoticz that still supports the classic API?
Thank you.
Waltervl: splitted to a new topic
[2025.1] Pythpn scipts not working due to old API
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- jvdz
- Domoticz version: 4.107
Re: Domoticz version 2025.1 released
Why not simply adapt the used api url?
.. but else you simply restore it from backup.
- Domoticz version: 2025.1
In your python script changekupfer007 wrote: Friday 01 August 2025 17:25 Removing the old API (json.htm?type=devices with rid) in version 2025.1 has completely broken my setup.
json.htm?type=devices Code: Select all
json.htm?type=command¶m=getdevicesSee wiki for more simple examples.... https://wiki.domoticz.com/Domoticz_API/ ... and_newer)
