What's up with MQTT ?
Posted: Thursday 31 July 2025 7:48
by Varazir
Hello
I removed 3 devices and one came back when I turned the hardware on and off.
I did a test with one device and it worked (now ID 911) so I thought it would work and deleted the other 2
Did it due to I hade issue that the other 2 device's didn't update, showed red.
It's the same physical hardware.
It should have a temperaturer and moist device as well.
As you can see in the MQTT explorer it's there and updated.
Why doesn't the battery get updated in Domoticz along with the other devices?
Re: What's up with MQTT ?
Posted: Thursday 31 July 2025 16:34
by waltervl
Did you also remove the retained MQTT config topics of this object in your MQTT broker?
https://wiki.domoticz.com/MQTT#Delete_retained_topic
Posted: Friday 01 August 2025 0:03
by Varazir
I have few retained but non what I could find that are red.
Posted: Friday 01 August 2025 8:24
by Varazir
Looked like my HA settings in Z2M was messed up as it was converted from an older version. Fixed now but I got bunch of new devices again. Oh well just redo the replace again
Posted: Friday 01 August 2025 14:18
by Varazir
I have a red device again, how can I TS that ?
Posted: Friday 01 August 2025 15:02
by BartSr
As Waltervl arready told: remove all retained values.
Posted: Friday 01 August 2025 15:24
by Varazir
BartSr wrote: Friday 01 August 2025 15:02
There non.
Posted: Friday 01 August 2025 15:31
by Varazir
I think it's zwave JSU server sux, it stops sending kWh value and when I go to the web GU and update the meter It just push everything in one go to DOmoticz.
and I get this
after doing the refresh it starts to report to the MQTT again.
Posted: Saturday 02 August 2025 15:19
by gizmocuz
If you are using ZWaveJS or Zigbee2MQTT and you do not want to see a sensor value in Domoticz, make sure it does not send it
Another way is to put a $ character in front of the name in Domoticz, and it will not show up in the main tabs (but do in devices )
Posted: Thursday 07 August 2025 16:27
by Varazir
gizmocuz wrote: Saturday 02 August 2025 15:19
I do that with some, like Ikea spots that are in a group as well.
This is kWh, based of a zwave device. That randomly stop.
Posted: Friday 08 August 2025 7:24
by gizmocuz
Can you see it updating in ZWaveJS-UI? If not, it is either a faulty device, or you have a MESH network issue.
When you add a new device to your ZWave network, you include it on the location where the device is installed right?
(Not always behind your computer for example).
This is important so it can talk to it's neighbors and create a good network. (same for Zigbee)
Your initial screenshot displays a Zigbee2MQTT configuration with a TUYA node, you are now talking about ZwaveJS-UI
