Moderators: leecollings , remb0
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Filnet
Posts: 53 Joined: Tuesday 06 March 2018 13:55
Domoticz version: 2025.2 ß
Post
by Filnet » Tuesday 29 July 2025 8:15
During several years, my dzVents work fine but since 20/07/2025, it doesn't work.
Here is my actual code:
key = 'xxxxxxxxx'
dz.openURL({
url = URL,
method = 'GET',
headers = {
['accept'] = '*/*',
['apikey'] = key,
callback = nom_callback,
Response is not a json.
When i use Terminal with the same parameters:
curl -X GET 'https://public-api.meteofrance.fr/public/DPVigilance/v1/cartevigilance/encours' -H 'accept: */*' -H 'apikey: xxxxxxxx'
I have a json.
Posts: 6677 Joined: Monday 28 January 2019 18:48
Domoticz version: 2025.1
Post
by waltervl » Tuesday 29 July 2025 9:03
In the response header you see "application/json"?
If not, you have to convert it into json yourself with for example
local json = domoticz.utils.fromJSON(item.data)
Filnet
Post
by Filnet » Tuesday 29 July 2025 9:14
Hello Waltervi,
I already test it.
In domoticz:
The response with OpenURL is:
<html><head><title>Request Rejected</title></head><body>The requested URL was rejected. Please consult with your administrator.
Your support ID is: 16363103684453842932
In terminal:
$ curl -X GET 'https://public-api.meteofrance.fr/public/DPVigilance/v1/cartevigilance/encours' -H 'accept: */*' -H 'apikey: xxxx'
{"product": {"warning_type": "vigilance", "type_cdp": "cdp_carte_externe", "version_vigilance": "V6", "version_cdp": "1.0.0", "update_time": "2025-07-29T04:00:18Z", "domain_id": "FRA", "global_max_color_id": "2", "periods": [{"echeance": "J", "begin_validity_time": "2025-07-29T04:00:00Z", "end_validity_time": "2025-07-29T22:00:00Z", "text_items": {"title": "", "text": []}, "timelaps": {"domain_ids": [{"domain_id": "10", "max_color_id": 1, "phenomenon_items": [{"phenomenon_id": "1",
.... and so on.
My code was efficient before 20/7/2025. I dont change anything.
Parameters are exactly the same in the two process Terminal and dzvents.
Post
by waltervl » Tuesday 29 July 2025 11:02
From what version did you update? And to what version did you update to (latest beta or a stable version)? Did you also update the OS?
Are you running Domoticz in a docker container?
It seems the openurl is supplying not the correct data to the site. What is the log saying about the openURL action? Perhaps you can switch on dzvents debugging and see if you can find differences:
https://wiki.domoticz.com/DzVents:_next ... leshooting
FlyingDomotic
Posts: 463 Joined: Saturday 27 February 2016 0:30
Post
by FlyingDomotic » Tuesday 29 July 2025 11:34
This maybe comes from a different message sent by Domoticz and curl.
Should you have Wireshark (or some other network capture tool), it may be pertinent to capture both requests and post them here.
Filnet
Post
by Filnet » Tuesday 29 July 2025 13:50
domoticz beta updated (always on beta since 8 years)
No docker container for domoticz
NB: I use openURL (GET but without headers) in another events and they go fine.
In Debug, the format of the headers seems amazing to me... but I am not a specialist...
Debug:
2025-07-29 13:30:05.232 dzVents: Debug: - OpenURL = {["method"]="GET", ["_trigger"]="vigilance_MF", ["URL"]="https://public-api.meteofrance.fr/public/DPVigilance/v1/cartevigilance/encours", ["headers"]="!#accept: */*!#apikey: eyJ4NXQiOiJZV0kxTTJZNExxxxxxxxxxxxxxPV014TXpjek1UVmhNbU14T1RSa09ETXlOVEE0Tnc9PSIsImtpZCI6ImdhdGV3YXlfY2VydGlmaWNhdGVfYWxpYXMiLCJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiJ9.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.qAoNqndQV7NWJlnyRwh08_e25NjL1IkciaHWxmc_aJXTT_5lzmw1N1gK7ZNw0IaEK2gg468jZUiI3W0Zl9LHeSaMK7BSAQI4b0PtX13rKqv2yY6aZHHbwm-SjknSMNCj9l0WfvmgSWr9F0aMlIcA-Tvl-sSTykAh4yig34JGR54xz6wKLf7FBaCmZWs-hmyBX89xyVccVQsrWs64CO2Bip4_C_oYEkhyURkUPQsq7xuXQ7ae9Z-HeMUn_CUzoQPD8W4eT2gSerPVzyhTSjHk2Z0APIrZWZ1rBIAl9VvWTDPgaqV6Hm_7W74Q4BsoeT7qnc7-33xG5VkLBXCvX_yLrg=="}
2025-07-29 13:30:05.232 dzVents: Debug: =====================================================
Post
by waltervl » Tuesday 29 July 2025 14:51
The latest beta was released 7-july-2025 so nothing happened after 20 July. So perhaps some other change on your system impacted this?
Also recent updates on github seems to have no relation to dzvents , only MQTT AD changes.
https://github.com/domoticz/domoticz/co ... velopment/
And indeed some strange characters on the header ( ["headers"]="!#accept: */*!#apikey: ). Perhaps retype the header section in dzvents, make sure no hidden characters are there?
Post
by waltervl » Tuesday 29 July 2025 17:41
The logging seems to always show the header entry starting with !#
eg
headers = { ['x-access-token'] = 'kjdhcvnlkasjhkhaks' },
results in
Debug: urltest: OpenURL: headers = !#x-access-token: kjdhcvnlkasjhkhaks
Now it is the question what is really sent...
Post
by waltervl » Tuesday 29 July 2025 17:55
I have done the same test in 2025.1 stable and see exactly the same result so it does not seem to be an issue in latest beta.
dzVents: Debug: urltest: OpenURL: headers = !#x-access-token: kjdhcvnlkasjhkhaks
Filnet
Post
by Filnet » Wednesday 30 July 2025 17:46
I don't understand why Script #3 (LUA) is OK and not in Script #4 (dzvents).
Script #3
local getHTTP = function(cmd)
local config=assert(io.popen('curl -m 8 '..cmd))
local location = config:read('*all')
config:close()
return location
apikey = 'xxxxxxxxxxxxx'
cmd = 'https://public-api.meteofrance.fr/public/DPVigilance/v1/cartevigilance/encours -H \'accept: */*\' -H \'apikey: '..apikey..'\''
print('Script #3')
print (getHTTP(cmd))
Script #4
timer = {'every 1 minutes'},
httpResponses = {'triggerMF'}
if (item.isTimer) then
print('Script #4 Timer')
key = 'xxxxxxxxxxxx'
domoticz.openURL({
url = 'https://public-api.meteofrance.fr/public/DPVigilance/v1/cartevigilance/encours',
method = 'GET',
headers = { ['accept'] = '*/*', ['apikey'] = key },
callback = 'triggerMF',
if ((item.isHTTPResponse) and (item.trigger == 'triggerMF')) then
print('Script #4 HTTP')
if (item.ok) then
if (item.isJSON) then
print('JSON reçu')
print(item.json.product.update_time)
print(string.sub(item.data, 1, 100))
domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
domoticz.log(item, domoticz.LOG_ERROR)
Post
by waltervl » Wednesday 30 July 2025 23:29
When I run your dzvents script #4 ( a little bit modified to see debug) it just works for me.
see attached log in spoiler
my test system:
Version: 2025.1 (build 16739)
Build Hash: c35b41d2d
Compile Date: 2025-07-07 13:32:28
dzVents Version: 3.1.8
Spoiler: show 2025-07-30 23:32:00.573 dzVents: urltest: ------ Start internal script: urltest: HTTPResponse: "triggerMF"
2025-07-30 23:32:00.659 dzVents: Script #4 HTTP
2025-07-30 23:32:00.659 dzVents: JSON reçu
2025-07-30 23:32:00.659 dzVents: Debug: urltest: {"product": {"warning_type": "vigilance", "type_cdp": "cdp_carte_externe", "version_vigilance": "V6", "version_cdp": "1.0.0", "update_time": "2025-07-30T14:00:15Z", "domain_id": "FRA", "global_max_color_id": "2", "periods": [{"echeance": "J", "begin_validity_time": "2025-07-30T14:00:00Z", "end_validity_time": "2025-07-30T22:00:00Z", "text_items": {"title": "Commentaire carte", "text": ["Orages encore actifs en Corse jusqu'en fin d'apr\u00e8s-midi."]}, "timelaps": {"domain_ids": [{"domain_id": "10", "max_color_id": 1, "phenomenon_items": [{"phenomenon_id": "1", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "2", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "3", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "6", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "5", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "4", "phenomenon_max_color_id": 1, "timelaps_items": []}]}, {"domain_id": "11", "max_color_id": 1, "phenomenon_items": [{"phenomenon_id": "1", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "2", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "3", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "6", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "5", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "4", "phenomenon_max_color_id": 1, "timelaps_items": []}]}, {"domain_id": "12", "max_color_id": 1, "phenomenon_items": [{"phenomenon_id": "1", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "2", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "3", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "6", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "5", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "4", "phenomenon_max_color_id": 1, "timelaps_items": []}]}, {"domain_id": "13", "max_color_id": 1, "phenomenon_items": [{"phenomenon_id": "1", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "2", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "3", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "6", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "5", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "4", "phenomenon_max_color_id": 1, "timelaps_items": []}]}, {"domain_id": "14", "max_color_id": 1, "phenomenon_items": [{"phenomenon_id": "1", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "2", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "3", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "6", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "5", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "4", "phenomenon_max_color_id": 1, "timelaps_items": []}]}, {"domain_id": "15", "max_color_id": 1, "phenomenon_items": [{"phenomenon_id": "1", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "2", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "3", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "6", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T14:00:00Z", "end_time": "2025-07-30T22:00:00Z", "color_id": 1}]}, {"phenomenon_id": "5", "phenomenon_max_color_id": 1, "timelaps_items": [{"begin_time": "2025-07-30T
2025-07-30 23:32:00.659 dzVents: urltest: ------ Finished urltest
This is the script I used
logging = {
level = domoticz.LOG_DEBUG,
marker = 'urltest',
key = 'xxxxxxxxxxxxxx'
domoticz.openURL({
method = 'GET',
if (item.ok) then
print('JSON reçu')
domoticz.log(item.data, domoticz.LOG_DEBUG)
Post
by waltervl » Friday 01 August 2025 23:36
@Filnet
Found your issue with your dzvents script already?
I have modified the token so it can not be misused anymore
Filnet
Post
by Filnet » Saturday 02 August 2025 7:36
I had created a token available during 72h.
No, my research is a failure.
Something is amazing: I leave the scripts #3 and #4 executing every minute during 48h.
On each call, URL response is effective.
Script #3 (LUA) : Always received a json, every minute.
Script #4 (dzvents): Sometime, 4 json in an hour, randomly. No json otherwise. During 24h, I received 12 jsons... When I didn't received the json, the message from URL is 'Bad credentials'.
Post
by waltervl » Saturday 02 August 2025 14:08
Perhaps there is a limit on requests to the host?
Filnet
Post
by Filnet » Saturday 02 August 2025 15:40
I don’t think so because the LUA script work fine in the same Time.
