Smart Meter replaced by Stedin - huge consumption recorded on day of replacement
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
hvanschaick
Stedin replaced my smart meter from a Landis and Gyr GPRS type to an iSKRA LTE version. All works fine, however since the new meter has a start value of 0.0 on all phases Domoticz shows a huge consumption on the day of replacement. How do I update the measurements cleanly in the database? I have looked in the tables MultiMeter and MultiMeter_Calendar but I am hesitant to change anything.... I am running Domoticz 2024.7
- Domoticz version: 2025.1
Re: Smart Meter replaced by Stedin - huge consumption recorded on day of replacement
When you remove the high value from the day of replacement with the delete action on the graph (Shift+mouse Click on the value in the month graph) it will be as before.
You only will miss the readings of that day.
Also see this topic if you want to poke around in the dtabase viewtopic.php?t=38410
and
viewtopic.php?p=314360#p314360
and
hvanschaick
Thanks, understood..
