Ecodim 05 Z4D missing widget
Houthakker
Post by Houthakker »
I'm having trouble with my ecodim 05 duodimmer.
For the life of me I can't get the second channel to work.
locally it works just fine but during pairing there is only one widged created, for the right channel. The left channel never registers. If I tell the plugin to recreate the widgeds it creates an extra widget for the left channel, but if i try to use it, there is never a response from the dimmer.
I tried resetting it, repairing it, telling the plugin to give it a full reset, repairing it again, and so forth.
Its this dimmer:
https://zigbee.blakadder.com/EcoDim_ECO-DIM.05.html
Version: "3"
ZDeviceName: ""
Status: "inDB"
SQN: "4a"
Ep:
01: Object {"1000":{},"0000":{"0007":1,"0004":"EcoDim BV","0005":"EcoDim-Zigbee 3.0","0000":3,"0001":1},"0003":{},"0004":{},"0005":{},"0006":{"0000":"01"},"0008":{"0000":238},"0019":{},"0b05":{},"Type":"LvlControl","ClusterType":{"375":"LvlControl","376":"LvlControl","378":"LvlControl"}}
f2: Object {"0000":{},"Type":"","ClusterType":{"377":"LvlControl","379":"LvlControl"}}
02: Object {"0000":{"0004":"EcoDim BV","0005":"EcoDim-Zigbee 3.0"}}
Heartbeat: "20374"
RIA: "1"
LQI: 168
Battery: Object {}
Model: "EcoDim-Zigbee 3.0"
ForceAckCommands:
MacCapa: "8e"
IEEE: "847127fffed893ad"
Type: "LvlControl"
ProfileID:
ZDeviceID:
App Version: 1
Attributes List:
DeviceType: "FFD"
HW Version: ""
Last Cmds:
0: Array[5] ["33","","09e0","0104 - 0008","08330b0a00"]
1: Array[5] ["35","","09e0","0104 - 0008","08350b0a00"]
2: Array[5] ["3a","","09e0","0104 - 0006","083a0b0a00"]
3: Array[5] ["3c","","09e0","0104 - 0008","083c0b0a00"]
4: Array[5] ["3d","","09e0","0104 - 0006","083d0b0a00"]
5: Array[5] ["3e","","09e0","0104 - 0006","083e0b0a00"]
6: Array[5] ["41","","09e0","0104 - 0006","08410b0a00"]
7: Array[5] ["43","","09e0","0104 - 0006","08430b0a00"]
8: Array[5] ["49","","09e0","0104 - 0008","08490b0a00"]
9: Array[5] ["4a","","09e0","0104 - 0006","084a0b0a00"]
LogicalType: "Router"
Manufacturer: "126a"
Manufacturer Name: "EcoDim BV"
NbEp: "3"
PowerSource: "Main"
ReadAttributes:
Ep: Object {"01":{"0000":{"TimeStamp":"04/06/2025 16:35:07","iSQN":{"0004":"0c","0000":"0c","0001":"0c","0005":"0c","0007":"0c","fffe":"0c"},"Attributes":{"0004":"00","0005":"00","0000":"00","0001":"00","0007":"00","fffe":"86"},"ZigateRequest":{}},"0019":{"TimeStamp":"04/06/2025 16:35:07","iSQN":{"0000":"06","0001":"06","0002":"06","0003":"06","0004":"06","0005":"06","0006":"07","0007":"07","0008":"07","0009":"07","000a":"07","fffd":"07","fffe":"08"},"Attributes":{"0000":"86","0001":"86","0002":"86","0003":"86","0004":"86","0006":"86","0007":"86","0008":"86","0009":"86","000a":"86","fffe":"86"},"ZigateRequest":{}},"0006":{"TimeStamp":"13/06/2025 10:52:49","iSQN":{"0000":"1b"},"Attributes":{"0000":"00"},"ZigateRequest":{}},"0008":{"TimeStamp":"13/06/2025 10:51:57","iSQN":{"0000":"1c"},"Attributes":{"0000":"00"},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":"04/06/2025 16:35:04","iSQN":{"0004":"03","0005":"03"},"Attributes":{"0004":"00","0005":"00"},"ZigateRequest":{}}},"f2":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}
ReceiveOnIdle: ""
Stack Version: ""
Stamp:
time: 1749804769.4455872
Time: "2025-06-13 10:52:49"
MsgType: "8102"
LastSeen: "13/06/2025 10:51:57"
ZCL Version: 3
Health: "Live"
Capability: Array[5] ["Full-Function Device","Main Powered","Receiver during Idle","Standard security","NwkAddr should be allocated"]
ZDPSQN: "2a"
ErrorManagement: 0
PairingInProgress: false
RSSI: -59
RollingRSSI: Array[10] [-59,-59,-59,-59,-59,-59,-59,-59,-59,-59]
RollingLQI: Array[10] [156,156,164,168,168,164,168,168,168,168]
Epv2: Object {}
ZCLSQN: "30"
ConfigSource: "DeviceConf"
Param: Object {"fadingOff":0,"moveToLevel":0}
PairingTime: "04/06/2025 16:35:04"
Bind:
01: Object {"0006":{"Target":"0000","Stamp":"04/06/2025 16:35:04","Phase":"binded","Status":"00","i_sqn":"05"},"0008":{"Target":"0000","Stamp":"04/06/2025 16:35:05","Phase":"binded","Status":"00","i_sqn":"06"}}
BindingTable: Object {"SQN":0,"Status":"Success","TimeStamp":"04/06/2025 16:35:06","BindingTableSize":2,"Devices":[{"847127fffed893ad":{"sourceEp":"01","Cluster":"0006","targetIEEE":"e0798dfffe9f0871","targetNickName":"Zigbee Coordinator","targetEp":"01"}},{"847127fffed893ad":{"sourceEp":"01","Cluster":"0008","targetIEEE":"e0798dfffe9f0871","targetNickName":"Zigbee Coordinator","targetEp":"01"}}]}
ConfigureReporting: Object {"Ep":{"01":{"0006":{"TimeStamp":"04/06/2025 16:35:04","iSQN":{"0000":"04"},"Attributes":{"0000":"00"},"ZigateRequest":{}},"0008":{"TimeStamp":"04/06/2025 16:35:04","iSQN":{"0000":"05"},"Attributes":{"0000":"00"},"ZigateRequest":{}}}}}
CheckParam: false
CertifiedDevice: true
_rawNodeDescriptor: "126a005200522c00008e524001"
Max Buffer Size: "52"
Max Rx: "0052"
Max Tx: "0052"
macapa: "8e"
bitfield: "4001"
server_mask: "2c00"
descriptor_capability: "00"
WriteAttributes: Object {"Ep":{"01":{"1000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0003":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0004":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0005":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0006":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0008":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0019":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}},"0b05":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}},"f2":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
ReadConfigureReporting: Object {"Ep":{"01":{"0006":{"0000":{"TimeStamp":"13/06/2025 10:39:18","Status":"00","DataType":"10","MinInterval":"0001","MaxInterval":"012c"}},"0008":{"0000":{"TimeStamp":"13/06/2025 10:39:18","Status":"00","DataType":"20","MinInterval":"0005","MaxInterval":"012c","Change":"05"}}}},"TimeStamp":"13/06/2025 10:39:18"}
GroupMemberShip: Object {"01":{}}
Tuya: Object {}
OTAClient: Object {"ManufacturerCode":"126a","ImageType":"003d","CurrentImageVersion":"01006750"}
RoutingTable: Array[1] [{"SQN":0,"Status":"Success","TimeStamp":"13/06/2025 00:23:29","Time":"04/06/2025 23:52:14","RoutingTableTableSize":16,"Devices":[{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"add8"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"add8"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"00cf"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"add8"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"0000"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"de9b"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"34ec":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"4248":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"34ec":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"4248":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"34ec":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"4248":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"34ec":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"4248":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"bb2a":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"00cf":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"de9b"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"34ec":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"4248":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"bb2a":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"00cf":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"f0a1":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"d50d"}},{"ef47":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"ef47":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"0000":{"Status":"Active (0)","MemoryConstrained":1,"ManyToOne":1,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"34ec":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"4248":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"bb2a":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"00cf":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"f0a1":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"d50d"}},{"ef47":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"ef47":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"31e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"2ea8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"aa05":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":1,"RouteRecordRequired":1,"NextHopNwkId":"dffa"}},{"0000":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"0000"}},{"add8":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"add8"}},{"dffa":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"08e2":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"13fb":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"08e2"}},{"412d":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"5462":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"5462"}},{"34ec":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"4248":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"bb2a":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"de9b"}},{"00cf":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"00cf"}},{"f0a1":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"dffa"}},{"ef47":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}},{"ef47":{"Status":"Active (0)","MemoryConstrained":0,"ManyToOne":0,"RouteRecordRequired":0,"NextHopNwkId":"a425"}}]}]
NwkID: "09e0"
pipiche
Re: Ecodim 05 Z4D missing widget
Post by pipiche »
Looks like this device come has a single or dual channel with the same Zigbee Model.
can you try the following
(1) update the plugin to the recent version 7.1.022 [6.463]. - Make sure to have [6.463] to get the latest Device database loaded.
(2) remove the existing pairing
(3) redo the pairing
Zigbee for Domoticz plugin / RPI3B+ / Electrolama ZZH-P / 45 devices
If the plugin provides you value, you can support me with a donation Paypal.
Wiki is available here.
Zigbee for Domoticz FAQ
Houthakker
Hi Pipiche,
Thanks for your reply.
I updated it as per instructions and removed the device.
Redid the pairing.
Still only one channel.
If I try to recreate the widget it only gives me the single channel so something has definitely changed.
Version: "3"
ZDeviceName: ""
Status: "inDB"
SQN: "0e"
Ep:
01: Object {"1000":{},"0000":{"0007":1,"0005":"EcoDim-Zigbee 3.0","0004":"EcoDim BV","0000":3,"0001":1},"0003":{},"0004":{},"0005":{},"0006":{"0000":"01"},"0008":{"0000":183},"0019":{},"0b05":{},"Type":"LvlControl","ClusterType":{"378":"LvlControl"}}
f2: Object {"0000":{},"Type":""}
02: Object {"0000":{"0005":"EcoDim-Zigbee 3.0"}}
Heartbeat: "7"
RIA: "1"
LQI: 168
Battery: Object {}
ForceAckCommands: Array[0] []
MacCapa: "8e"
Type: "LvlControl"
ProfileID: "0104"
ZDeviceID: "0101"
App Version: 1
Attributes List: Object {}
DeviceType: "FFD"
HW Version: ""
Last Cmds: Array[10] [["None","","36cc","0104 - 0008","1013000000"],["14","","36cc","0104 - 0004","11140200"],["15","","36cc","0104 - 0006","111500"],["0c","","36cc","0104 - 0006","080c0b0a00"],["16","","36cc","0104 - 0006","111601"],["0d","","36cc","0104 - 0006","080d0b0a00"],["None","","36cc","0104 - 0006","1017000000"],["None","","36cc","0104 - 0008","1018000000"],["0e","","36cc","0104 - 0019","000e0b0100"],["0e","","36cc","0104 - 0019","190e0298"]]
NbEp: "3"
PowerSource: "Main"
ReadAttributes: Object {"Ep":{"01":{"0000":{"TimeStamp":"13/06/2025 11:41:27","iSQN":{"0004":"0f","0000":"0f","0001":"0f","0005":"0f","0007":"0f","fffe":"0f"},"Attributes":{"0004":"00","0000":"00","0001":"00","0005":"00","0007":"00","fffe":"86"},"ZigateRequest":{}},"0019":{"TimeStamp":"13/06/2025 11:40:45","iSQN":{"0000":"09","0001":"09","0002":"09","0003":"09","0004":"09","0005":"09","0006":"0a","0007":"0a","0008":"0a","0009":"0a","000a":"0a","fffd":"0a","fffe":"0b"},"Attributes":{"0000":"86","0001":"86","0002":"86","0003":"86","0004":"86","0006":"86","0007":"86","0008":"86","0009":"86","000a":"86","fffe":"86"},"ZigateRequest":{}},"0006":{"TimeStamp":"13/06/2025 11:41:18","iSQN":{"0000":"17"},"Attributes":{"0000":"00"},"ZigateRequest":{}},"0008":{"TimeStamp":"13/06/2025 11:41:18","iSQN":{"0000":"18"},"Attributes":{"0000":"00"},"ZigateRequest":{}}},"02":{"0000":{"TimeStamp":"13/06/2025 11:40:41","iSQN":{"0005":"06"},"Attributes":{"0005":"00"},"ZigateRequest":{}}},"f2":{"0000":{"TimeStamp":0,"iSQN":{},"Attributes":{},"ZigateRequest":{}}}}}
ReceiveOnIdle: "On"
Stack Version: ""
Stamp: Object {"time":1749807703.520052,"Time":"2025-06-13 11:41:43","MsgType":"8011","LastSeen":"13/06/2025 11:40:34"}
ZCL Version: 3
Health: "Live"
ZDPSQN: "08"
ErrorManagement: 0
RollingLQI: Array[10] [164,176,156,160,164,164,168,160,160,168]
Max Rx: "0052"
Max Tx: "0052"
macapa: "8e"
bitfield: "4001"
server_mask: "2c00"
Epv2: Object {"01":{"ProfileID":"0104","ZDeviceID":"0101","ClusterIn":{"1000":{},"0000":{},"0003":{},"0004":{},"0005":{},"0006":{},"0008":{},"0b05":{}},"ClusterOut":{"0019":{}}},"02":{"ProfileID":"0104","ZDeviceID":"0101","ClusterIn":{"0000":{},"0003":{},"0004":{},"0005":{},"0006":{},"0008":{}}},"f2":{"ProfileID":"a1e0","ZDeviceID":"0061","ClusterOut":{"0021":{}}}}
ZCLSQN: "18"
ZDeviceVersion: "0001"
RSSI: -58
RollingRSSI: Array[10] [-60,-60,-60,-60,-60,-60,-60,-60,-60,-58]
PairingTime: "13/06/2025 11:40:43"
Bind: Object {"01":{"0006":{"Target":"0000","Stamp":"13/06/2025 11:40:43","Phase":"binded","Status":"00","i_sqn":"05"},"0008":{"Target":"0000","Stamp":"13/06/2025 11:40:44","Phase":"binded","Status":"00","i_sqn":"06"}}}
BindingTable: Object {"SQN":0,"Status":"Success","TimeStamp":"13/06/2025 11:40:45","BindingTableSize":2,"Devices":[{"847127fffed893ad":{"sourceEp":"01","Cluster":"0006","targetIEEE":"e0798dfffe9f0871","targetNickName":"Zigbee Coordinator","targetEp":"01"}},{"847127fffed893ad":{"sourceEp":"01","Cluster":"0008","targetIEEE":"e0798dfffe9f0871","targetNickName":"Zigbee Coordinator","targetEp":"01"}}]}
ConfigureReporting: Object {"Ep":{"01":{"0006":{"TimeStamp":"13/06/2025 11:40:43","iSQN":{"0000":"07"},"Attributes":{"0000":"00"},"ZigateRequest":{}},"0008":{"TimeStamp":"13/06/2025 11:40:43","iSQN":{"0000":"08"},"Attributes":{"0000":"00"},"ZigateRequest":{}}}}}
CheckParam: false
ReadConfigureReporting: Object {"Ep":{"01":{"0006":{"0000":{"TimeStamp":"13/06/2025 11:40:46","Status":"00","DataType":"10","MinInterval":"0001","MaxInterval":"012c"}},"0008":{"0000":{"TimeStamp":"13/06/2025 11:40:46","Status":"00","DataType":"20","MinInterval":"0005","MaxInterval":"012c","Change":"05"}}}},"TimeStamp":"13/06/2025 11:40:46"}
Tuya: Object {}
NwkID: "36cc"
pipiche
Post by pipiche »
Can you share the plugin logs ?
Houthakker
Sure!
_PluginZigbee_18.rar
(52.72 KiB) Downloaded 160 times
pipiche
Post by pipiche »
This looks very strange , as it seems that it is trying to use Endpoint f2 as the 2nd channel.
kindly do the following
1- Enable Pairing debug via the WebUI
2- remove All widget created and make sure the device is removed from Domoticz and Plugin
3- Update again the plugin to get 6.464
restart the plugin
Redo the pairing
If not working, kindly provides the plugin log again and the device export.json
Houthakker
Still no luck unfortunuatly.
Turned on pairing debug and did the update. Attached the logs.
export(1).rar
(19.48 KiB) Downloaded 119 times
_PluginZigbee_18(1).rar
(36.7 KiB) Downloaded 119 times
pipiche
Post by pipiche »
Thanks for the informations, very useful.
Kindly do once more an update to move to 6.465 and then redo the pairing
Houthakker
Thanks for the work, the dimmer is functioning as expected. On both channels!
pipiche
Post by pipiche »
great news. thanks for your patience
