Kwh device data is not saved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Varazir
Post by Varazir »
Version: 2025.1 (build 16724)
Build Hash: a1c7883bd
Compile Date: 2025-06-10 08:57:28
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
Uptime: 1 Days, 19 Hours, 43 Minutes, 0 Seconds
Raspberry pi 3
MQTT zwavejsAD ( Rpie head)
Zigbee2MQTT ( USB device )
I have a zwave outlet device that isn't saving the data. Don't know how to describe it better.
It shows it's updated but when I look at the log it's empty.
I tested to remove it and let Domoticz re discover the device. But it didn't help.
Same physical device but the current watt device
Varazir
Re: Kwh device data is not saved
Post by Varazir »
I see this if I enable debug logs is this normal? It's only device that gives my this logs.
2025-06-17 14:29:20.530 dzVents: Debug: Event triggers:
2025-06-17 14:29:20.530 dzVents: Debug: - Device: NAS (NAS_electric_kwh_value)
2025-06-17 14:29:20.608 dzVents: Debug: Dumping domoticz data to /opt/domoticz/userdata/scripts/dzVents/domoticzData.lua
2025-06-17 14:29:20.685 dzVents: Debug: Processing device-adapter for Server: Current Watt Meter: Electric usage device adapter
2025-06-17 14:29:20.686 dzVents: Debug: dzVents version: 3.1.8
Users browsing this forum: Ahrefs [Bot] and 1 guest
