Total Energy via SolarEdge Modbus TCP
Posted: Friday 06 June 2025 11:50
by imautohuttraeger
Via Solaredge Modbus TCP I get these devices - see screenshot (inverter SE 10K). The "Total Energy" does not show the actual produced power. Batterie charging and maybe feeding into the house or grid are subtracted somehow (at the time of the screenshot the batterie was charged and pure production was much higher according to the MySolaredge App). That seems to makes sense for "Total Energy". But is there any possibility to get the pure production? And maybe even the batterie charging / discharging? Especially for usage with the energy dashboard.
Re: Total Energy via SolarEdge Modbus TCP
Posted: Friday 06 June 2025 11:55
by jvdz
Do you have the average calculation switched on in the hardware?
I am working on this plugin and was wondering why that is used at all. Understand it could average out wrong values but assume it could lead to what you observe.
Other than that what you see is what comes out of your solaredge inverter.
Posted: Friday 06 June 2025 12:23
by imautohuttraeger
Where can I adjust that? I can access the inverter direktly via http://172.16.0.1 and have the menu according to attaches secrrenshot. But I do not find something like average calculation.
Posted: Friday 06 June 2025 12:37
by jvdz
I meant in the domoticz hardware settings. ;-)
The plugin has a brunch of settings you can define.
Posted: Friday 06 June 2025 13:24
by imautohuttraeger
Hahaha - got it. Yes, avarage was enabled. Disabled it now.
Thank you!
Posted: Friday 06 June 2025 13:37
by jvdz
Does that help making more sense of the data?
Posted: Friday 06 June 2025 14:41
by imautohuttraeger
Yes, indeed. SE Energy Total and SE Power are now showing the very same figure as the MySolarEdge App.
"Enabled" is the default value of SE Modbus TCP - so I had neither thought about it during installation nor had it in mind as a possible cause for the strange numbers.
Still I don't really understand what kind of average is calculated here ... but so what - I don't need it obviously.
