Domoticz Docker Container update trigger Topic is solved
acaonweb
Post by acaonweb »
i'm switching to have domoticz into a docker container and porting was good at the moment.
there is a difference regarding the update to a new version.
in the bare installation, in setting i can enable an alert so when a new domoticz version is available, a pop up appears and i could easly update.
In the docker container, i haven't is, so i'm wondering how a new version avaliable can be notified?
there is some setting i have to enable, or someone can show me the way to do it?
Thanx
Fabrizio
Domoticz version: 2025.1
Re: Domoticz Docker Container update trigger
There is no trigger as it is managed by Docker. There are some tools around docker to check if there is a new docker image. You have to google for that.
Or you can run a regularly update command:
docker compose pull && docker compose up --force-recreate --build -d && docker image prune -f
as indicated in the instructions on'
https://hub.docker.com/r/domoticz/domoticz
gizmocuz
Post by gizmocuz »
You also do not have to update every time.
If you want a good docker compose manager, you could install (via docker compose of course) DockGE, I like this one very much!
acaonweb
Post by acaonweb »
thanx to everyone
Kedi
Post by Kedi »
gizmocuz wrote: Wednesday 04 June 2025 13:30 You also do not have to update every time.
Unfortunately it states: "Debian/Raspbian Buster or lower is not supported"
gizmocuz
Post by gizmocuz »
@Kedi, sure that is very old... consider upgrading to bookworm!
Varazir
Post by Varazir »
I hade to install some extra libs to get docker running on Buster.
It's a drawback using docker as you need to SSH or install a docker manager. You can't just do it from the Domoticz interface as before.
Installed DockerGE, I should have started with it, now I need to redo everything, yes I can set it up in DockerGE and copy the config files.
But I don't want to mess with the setup again after I got all in place again.
gizmocuz
Post by gizmocuz »
Well, there are much more benefits:
- No system dependencies !
- Easy backup
- Easy restore
And yeah, DockGe is a very nice manager for that
You also don't have to update if you don't miss any features or fixes
Now you know how to use docker, you might check out:
https://github.com/Haxxnet/Compose-Examples
So easy to try/install and maintain!
Varazir
Post by Varazir »
gizmocuz wrote: Saturday 07 June 2025 15:40 Well, there are much more benefits:
- Easy backup
- Easy restore
Did you have all in the same compose?
Varazir
Post by Varazir »
I have setup as custom link
gizmocuz
Post by gizmocuz »
No, everything is in separate containers. You don't need to update some containers, or you might wish to spin up a new container for a test version etc.
Varazir
Post by Varazir »
gizmocuz wrote: Sunday 08 June 2025 9:11 No, everything is in separate containers. You don't need to update some containers, or you might wish to spin up a new container for a test version etc.
Do you have any good script or way to update the containers when here are a new update there?
Have you tested https://getwud.github.io/wud/ ?
gizmocuz
Post by gizmocuz »
I use DockGE. I don't want my containers to auto-magically update by itself... no way...
I have dockers I am depending on, and if I just let them update when there is a update, and something is not working, it could be a fault in one of these 20 containers...
Good luck hunting this down.....
For instance, Zigbee2MQTT, I update when I have a device that seems not implemented yet. (If it still is not, I try to make a config and submit)
Domoticz, I update when something visual appealing has changed, or something I really want.
Else, my production instance just keeps running.
All my others I do update, but one at a time, and not often.
You don't have to update because there is a update. It's a docker. Keeping your base system up2date (security patches) is way more important.
kalle
Post by kalle »
I use Watchtower for this
keeps all Docker instances up to date.
gizmocuz
Post by gizmocuz »
kalle wrote: Monday 09 June 2025 8:24 I use Watchtower for this
And as mentioned, doing this automatically is not ideal at all!
Using watchtower to update critical services is a very bad idea
