After migrate/reinstall cleanup
Varazir
Post by Varazir »
I just reinstalled my pi and then I switched to all docker setup with zigbee/zwave/MTT/Domoticz.
Now I see this, what's the easiest way to merge the new found devices? Do it in domoticz or change in zigbee ?
Why did Domoticz create new devices to start with ?
I lost data for my Philips lux sensor, how can I restore it from backup db file?
I tried to use the replace command, it should be a merge command not replace as in 99% you want to keep the data.
There should be a question asking what device to keep.
Not first time I mess it upp. Confusing function.
I get this message in the loggs
2025-06-01 09:36:38.889 dzVents: IKEARemote: ------ Start internal script: IKEA - Remote: Device: "IKEA Remote_toggle (Zigbee2MQTT)", Index: 468
2025-06-01 09:36:38.893 dzVents: Debug: IKEARemote: Processing device-adapter for RemoteDummyDimmer: Switch device adapter
2025-06-01 09:36:38.894 dzVents: IKEARemote: Unknown action requested; ignored
2025-06-01 09:36:38.894 dzVents: IKEARemote: ------ Finished IKEA - Remote
This is the script I'm using ( Got help here to built it )
-- Creater Varazir ( And big help from waaren and others on domotiz forum )
-- e-mail: varazir .. gmail.com
-- Version: 1.5
-- groups = {'group1', 'group2', 'group3', 'group4', 'group5', 'group6', 'group7' }
return  {
    on =        {
                    devices         = { '*IKEA Remote*' }
    logging =   {
                    level           = domoticz.LOG_DEBUG,
                    marker          = "IKEARemote"
    data =      {
                    currentGroup    = { initial = 1 }
    execute = function(dz, item)
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        control =
            'Taklampa Sovrum',
            group1 =
                IKEAlamp        = { idx = 287, toggle = true, blink = true, dimmer = true}
            'Uttag Sovrum',
			group2 =
                IKEAOutlet         = { idx = 217, toggle = true, blink = true },
            'Rullgardin Sovrum',
			group3 =
                Blinder         = { idx = 59, toggle = true, blinder = true },
            'Taklampa Hall',
            group4 =
                IKEAlamp        = { idx = 292, toggle = true, blink = true, dimmer = true },
                IKEAlampGrupp   = { idx = 308, toggle = true, blink = false, dimmer = true },
            'Taklampa Datorrum',
			group5 =
                IKEAlamp        =  { idx = 290, toggle = true, blink = true, dimmer = true}
            'Taklampa Vardagsrum',
            group6 =
                IKEAlamp   = { idx = 304, toggle = true, blink = true, dimmer = true }
            'TVbänk',
			group7 =
                Lamp            = { idx = 42, toggle = true, blink = true},
                TvGroup         = { idx = 2,  toggle = true, group = true}
            'Rullgardin Vardagsrum',
			group8 =
                Blinder         = { idx = 83, toggle = true, blinder = true },
        local selectedGroupNumber = dz.data.currentGroup
        local maxGroup = #control
        local dummyDimmer = dz.devices(82)
        local function doAction(action, direction)
            logWrite("10 Current group number........" .. selectedGroupNumber)
            selectedGroup = "group" .. selectedGroupNumber
            logWrite("11 Current selected group is..." .. selectedGroup)
            selectedControlGroup = control[selectedGroup]
            logWrite("12 Selected Control Group is a " .. type(control[selectedGroup]))
            switchSelectorGroupNumber = math.floor( selectedGroupNumber * 10)
            logWrite("13 Selected switchSelectorGroupNumber " ..  switchSelectorGroupNumber)
            dz.devices('IKEA Remote Groups').switchSelector(switchSelectorGroupNumber).silent()
            for device, attributes in pairs(selectedControlGroup) do
                logWrite("20 Current device is........." .. device)
                logWrite("21 Attribute type is........." .. type(attributes))
                logWrite("22 IDX is...................." .. attributes["idx"])
                currentIDx = attributes["idx"]
                if attributes["group"] then
                    logWrite("24 Current Device is group......." .. dz.groups(currentIDx).name)
                    currentDevice = dz.groups(currentIDx)
                    logWrite("25 Current Device is device......" .. dz.devices(currentIDx).name)
                    currentDevice = dz.devices(currentIDx)
                for attribute, value in pairs(attributes) do
                    logWrite("30 Current attribute is......" .. device)
                    if attribute == action then
                        logWrite("31 Current acction is......" .. action)
                        -- Blinking
                        if action == 'blink' then
                            local blinkDevice = currentDevice
    						local blinkLevel = currentDevice.level
    						-- dz.utils.dumpTable(blinkDevice)
    						-- dz.utils.dumpTable(attributes)
    						logWrite("Device " .. blinkDevice.name .. " will blink")
    						if blinkDevice.state == "Off" then
    							blinkDevice.switchOn()
    							blinkDevice.switchOff().afterSec(0.5)
    							blinkDevice.switchOn().afterSec(0.5)
    			        elseif action == 'dimmer' then
    						local dimDevice = currentDevice
    						local dimLevel = dimDevice.level
    						local delay = 0
                            logWrite(dimDevice.name .. " direction is " .. direction)
    						if direction == "stop" then
    						    dimDevice.cancelQueuedCommands()
    						    logWrite('Stop dimming of ' .. dimDevice.name .. ' at ' .. dimLevel ..'%')
    						elseif direction == 'down' then
    							repeat
    								delay = delay + 0.1
    								dimLevel = dimLevel - 1
    								logWrite('Set ' .. dimDevice.name .. ' to dimLevel '.. dimLevel .. '%, after ' .. delay .. ' seconds')
    								dimDevice.dimTo(dimLevel).afterSec(delay)
    							until dimLevel <= 0
    					    elseif direction == 'up' then
                                repeat
                                    delay = delay + 0.1
                                    dimLevel = dimLevel + 1
                                until dimLevel >= 100
                        elseif action == 'toggle' then
                            -- dz.utils.dumpTable(currentDevice)
                            local toggleDevice = currentDevice
                                toggleDevice.toggleGroup()
                                toggleDevice.toggleSwitch()
        local action = 'blink'
        local direction = 'up'
        if item.state == 'Click' and item.name == '$IKEA Remote Left' then
            selectedGroupNumber = selectedGroupNumber - 1
            if selectedGroupNumber == 0 then selectedGroupNumber = maxGroup end
            dz.notify("Aktuell grupp",control[selectedGroupNumber],dz.PRIORITY_NORMAL,dz.NSS_HTTP)
        elseif item.state == 'Click' and item.name == '$IKEA Remote Right' then
            selectedGroupNumber = selectedGroupNumber + 1
            if selectedGroupNumber > maxGroup then selectedGroupNumber = 1 end
        elseif item.name == '$IKEA Remote New' then
            action = 'toggle'
        elseif item.state == 'Hold' and item.name == "$IKEA Remote Up"  then
            action = 'dimmer'
        elseif item.state == 'Hold' and item.name == '$IKEA Remote Down' then
            action = 'dimmer'
            direction = 'down'
        elseif item.state == 'Release' and item.name == '$IKEA Remote Down' or item.name == '$IKEA Remote Up' then
            action = 'dimmer'
            direction = 'stop'
        elseif item.name == '$IKEA Remote Groups' then
            selectedGroupNumber = math.floor( item.level/10 )
            logWrite("00 Group selected with IKEA Remote Groups" .. selectedGroupNumber)
            logWrite('Unknown action requested; ignored', dz.LOG_INFO )
            return
        if item.state == 'Click' or item.state == 'Release' then
            logWrite('Turning off ' .. item.name)
            dz.devices(item.name).switchOff().silent()
        dz.data.currentGroup = selectedGroupNumber
Raspberry PI 2 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Varazir
Re: After migrate/reinstall cleanup
Post by Varazir »
I have few DB entries that are messed up as well, I didn't use that much.
Varazir
Post by Varazir »
I added my html files to the template folder but I can't see the custom menu button, was there a setting ?
gizmocuz
Post by gizmocuz »
Did you restart Domoticz?
Varazir
Post by Varazir »
gizmocuz wrote: Tuesday 03 June 2025 14:20 Did you restart Domoticz?
yes even moved it to get a new Ikea lamp bulb to connect.
I restarted it several times while I as TS everything ells.
gizmocuz
Post by gizmocuz »
Strange folder... ~/domoticz/data/www/templates... should this not be ~/domoticz/www/templates ?
Varazir
Post by Varazir »
gizmocuz wrote: Tuesday 03 June 2025 16:29 Strange folder... ~/domoticz/data/www/templates... should this not be ~/domoticz/www/templates ?
I'm running docker installation. It's why the path looks strange.
gizmocuz
Post by gizmocuz »
That is indeed strange, but did you map a folder to the template folder inside the docker like:
    volumes:
      - ./config:/opt/domoticz/userdata
      - ./config/www/templates:/opt/domoticz/www/templates
next you can place the files in your ./config/www/templates folder
Varazir
Post by Varazir »
gizmocuz wrote: Wednesday 04 June 2025 13:28 That is indeed strange, but did you map a folder to the template folder inside the docker like:
    volumes:
Hmm,
Didn't see anything about that here https://wiki.domoticz.com/Docker
No I didn't map the templates folder.
Edit: It helped thanks. One thing fixed on my issue list.
Varazir
Post by Varazir »
How can I restore data that is gone if I do it wrong ? ( I have a backup DB with all history)
Varazir
Post by Varazir »
Starting to nesting it up, the creation of new devices sucks. I hided several devices so I need go and rename them all and the replace then hide them again.
gizmocuz
Post by gizmocuz »
If you get new devices for your previous ones (because you switched from openzwave to zwavejs for example), you can press edit on your old device, and press the 'Replace' button and select the new one
So rename the new one to 'temp1_new', then press edit on 'temp1' and replace it with 'temp1_new', all history,timers,events everything stays the same
Yes you have to do this once
Varazir
Post by Varazir »
gizmocuz wrote: Thursday 05 June 2025 7:50 If you get new devices for your previous ones (because you switched from openzwave to zwavejs for example), you can press edit on your old device, and press the 'Replace' button and select the new one
This time it was from Docker to Docker but z2m was updated to v2 in the process.
Example this was the ID of the old device 0x90fd9ffffee8004b_action_zigbee2mqt
This was what Domoticz added after I reinstalled 0x90fd9ffffee8004b_identify_zigbee2mqtt
I have replaced the devices that needed to be replaced so that is in order now. I guess I'll find more to replace later but now I'm confident how it works.
Next is as I said some DB hacking to even out the history of some devices.
gizmocuz
Post by gizmocuz »
So you did not replace them via the 'Replace' button/option? Database hacking is never a good idea.
I also have device with a 'identify' , but here it is an airsensor from ikea.
This button is not needed as it is for internal usage only (to pair it)
All my other switches stayed the same
Varazir
Post by Varazir »
gizmocuz wrote: Thursday 05 June 2025 8:05 So you did not replace them via the 'Replace' button/option? Database hacking is never a good idea.
yes I have always used replace function but it's not clear if I should do it on the new or old device. So I wiped the data from my Philips Lux sensor.
I restored the data using python script.
In this case it was Ikea 5 button controller, one of the first they made for zigbee and all buttons got a new ID.
And it was the center button that got the identify tag.
Oh well I just have the spikes on some of the meters to fix now and I have done that before. Looks easy in SQLlite program
I had this before the reinstallation.
Varazir
Post by Varazir »
There should be a option replace in the device list.
Another example on new device just by upgrading the z2m docker
Varazir
Post by Varazir »
Something is wrong here or changed in a way that I need to re do all my automations and setup.
I have this 2 devices the 307 is my old before reinstallation working device and a new have been added. Now the old Just turns the device on and off.
I replace the old with the new, then the button keep turn on and off the device all time and next time I disable and enable the z2m hardware the new device getting added back again.
gizmocuz
Post by gizmocuz »
If you replace the 'switch' one (press edit in the light/switches page on this switch, make sure the IDX reads 307), press 'Replace' and select the new one (maybe rename the new one (569) to _new so you know you select the right one)
When you then go back into the devices overview, you should only see 307, and the ID should read *_identify_* instead of *_switch_*
Varazir
Post by Varazir »
gizmocuz wrote: Friday 06 June 2025 10:05 If you replace the 'switch' one (press edit in the light/switches page on this switch, make sure the IDX reads 307), press 'Replace' and select the new one (maybe rename the new one (569) to _new so you know you select the right one)
Ok,
Before
Replaced
After
After I updated the z2m hardware
Still it's only the new device that works, the old keeps turning the device on and then off again.
And I think identify is now used for be able to reset the device remotely.
Varazir
Post by Varazir »
LOL I hade bloky/event turning it off stupid me :)
