Z4D plugin - new release
Posted: Friday 30 May 2025 9:59
by pipiche
Just to let you know that we have released 7.1.022 yesterday. If you are connected to Internet, the Plugin WebUI should let you know.
More information can be found
- https://github.com/zigbeefordomoticz/Do ... e7-7.1.022
- https://github.com/zigbeefordomoticz/Do ... seNotes.md
You should be able to use the WebUI > Plugin > Upgrade to do the update and then restart the plugin (or domoticz).
Here are some information on the plugin usage
Chipset using Zigbee4Domoticz plugin
Screenshot 2025-05-30 at 09.55.34.png (86.2 KiB) Viewed 1260 times
And by Network size
Screenshot 2025-05-30 at 09.59.17.png (89.44 KiB) Viewed 1260 times
Re: Z4D plugin - new release
Posted: Friday 30 May 2025 15:21
by WouterO
Thank you, pipiche,
Update went without any problems via the webui on my RPi 4 bookworm, latest Domoticz version.
Posted: Friday 30 May 2025 15:52
by Fredom
Hi Pipiche,
Update done.
No error messages.
Everything works.
But unfortunately I have a blank screen in pulldown menu z4d
Posted: Friday 30 May 2025 18:13
by waltervl
Thanks, just updated without issues. Restarted the plugin and also Zigbee4Domoticz UI works just fine.
Posted: Monday 02 June 2025 16:18
by lost
Same for me: Updated from webUI 2 days ago & no issue. Just reloading the already opened webUI page a couple of minutes after restart was triggered (logs showing Z4D restart done) also lead to a blank page but closing the whole domoticz tab & re-opening the Z4D webUI custom page did the trick (Domoticz stable 2025.1 running on a P3B/64b Debian 11 lite).
Thanks Pipiche!
