Just to let you know that we have released 7.1.022 yesterday. If you are connected to Internet, the Plugin WebUI should let you know.
More information can be found
- https://github.com/zigbeefordomoticz/Do ... e7-7.1.022
- https://github.com/zigbeefordomoticz/Do ... seNotes.md
You should be able to use the WebUI > Plugin > Upgrade to do the update and then restart the plugin (or domoticz).
Here are some information on the plugin usage
Chipset using Zigbee4Domoticz plugin
And by Network size
Z4D plugin - new release
WouterO
Re: Z4D plugin - new release
Thank you, pipiche,
Update went without any problems via the webui on my RPi 4 bookworm, latest Domoticz version.
Fredom
- Domoticz version: 2025.1
Hi Pipiche,
Update done.
No error messages.
Everything works.
But unfortunately I have a blank screen in pulldown menu z4d
Update done.
No error messages.
Everything works.
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2025.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
Fred
Thanks, just updated without issues. Restarted the plugin and also Zigbee4Domoticz UI works just fine.
lost
Same for me: Updated from webUI 2 days ago & no issue. Just reloading the already opened webUI page a couple of minutes after restart was triggered (logs showing Z4D restart done) also lead to a blank page but closing the whole domoticz tab & re-opening the Z4D webUI custom page did the trick (Domoticz stable 2025.1 running on a P3B/64b Debian 11 lite).
Thanks Pipiche!
Thanks Pipiche!
