Device disappeared since update to 2025.1
Posted: Thursday 15 May 2025 10:12
Since the update to 2025.1, a certain dummy hardware device has disappeared and now only appears occasionally for a short time.
It is an energy counter / meter which gets the data from my electric meter via an infrared sensor with Tasmoa ("Hichi" infrared head). It worked perfect since the update.
What I have found out is this:
When I open the device list with the filter "all", it is not shown.
Then I switch to "unused" and reload the list. Of course it doesn't appear, as it is a used device.
Then I switch back to "all" and now the device is shown and obviously receives the data. See Screenshot.
After another reload it is away again and only appears shortly again with above mentioned procedure.
In the tab of "utilities" it never appears.
Maybe this log information can help to identify the problem:
Any idea?
2025-05-15 10:17:15.151 Error: Invalid Number sValue: '%' for device idx: '%'
2025-05-15 10:17:15.155 Error: Invalid Number sValue: '%' for device idx: '%'
2025-05-15 10:17:15.160 Error: Invalid Number sValue: '%' for device idx: '%'
2025-05-15 10:17:15.165 Error: Invalid Number sValue: '%' for device idx: '%'
2025-05-15 10:17:15.272 dzVents: Handling events for: "Zähler Import idx 4", value: "7188;7189.8"
2025-05-15 10:17:15.273 dzVents: ------ Start internal script: p1 dummy fuer energy dashboard: Device: "Zähler Import idx 4 (Dummy Hardware)", Index: 367
2025-05-15 10:17:15.278 dzVents: ------ Finished p1 dummy fuer energy dashboard
