[SOLVED] no longer logging after 2025.1 install
hestia
Domoticz version: 2022.1
Post by hestia »
I've installed 2025.1
Version: 2025.1
Build Hash: 89d5c900d
Compile Date: 2025-05-05 09:02:49
dzVents Version: 3.1.8
and I've almost no longer log for dzVents script, even with the settings as Debug (everything).
I've tried the script template Logging
		devices = {
			203
	logging = {
		marker = 'log_script',
		level = domoticz.LOG_DEBUG
	    domoticz.log('none log line!')
		domoticz.log('INFO log line!', domoticz.LOG_INFO)
		domoticz.log('STATUS log line!', domoticz.LOG_STATUS)
		domoticz.log('ERROR log line!', domoticz.LOG_ERROR)
		domoticz.log('DEBUG log line!', domoticz.LOG_DEBUG)
		domoticz.log('FORCE log line!', domoticz.LOG_FORCE)
with this return only
2025-05-12 22:18:56.008 Status: dzVents: log_script: STATUS log line!
2025-05-12 22:18:56.009 Error: dzVents: log_script: ERROR log line!
An issue during the install?
A change as I saw ?
Version 2024.5 (July 7th 2024)
- Implemented: Currency Symbol in Location Settings
- Implemented: dzVents, Added historical data helper 'med' to calculate the median value
- Implemented: dzVents, Improved logging
Re: no longer logging after 2025.1 install
What is your dVents log level in menu Setup - settings, tab other?
hestia
Post by hestia »
and it was ok before the upgrade
I have tested the example script this morning and have no issues. I see all the log lines.
But did you filter correctly? I see more lines also when the script starts and stops. In the log search box type log_
It should show all the logging from the log test script.
hestia
Post by hestia »
Thanks for this reply.
Other testing:
I've changed the Settings to test all the possible values and the results are the same for all the Settings
2 log lines only
but no debug info and no log for the other values, perhaps the STATUS log in the only one working now ?
What do you have in your /etc/init.d/domoticz.sh
I've not changed mine since 2023
DAEMON_ARGS="$DAEMON_ARGS -loglevel status,error"
I have the default outcommented value for syslog:
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
hestia
Post by hestia »
Thanks for your reply
I've commented this line
and it's solved
